    BauHaus
    26 Posts 8 Posters 3.9k Views 8 Watching
    • Mike LuceyM Offline
      Mike Lucey
      Sounds like a really interesting project Csaba. I like the way you have handled the Bálványi House (see I got all the accents in 😉 ) Is there any possibility of actually showing the plans, even scans. Looking at a house and not knowing the layout is like looking at a car and not seeing what is under the bonnet 😄
      Mike
        Well, as I said, there is no such a thing as a consistent "one" design but there are a bunch of variations. Here are some of the plan, elevation and perspective "sketches" (and of course, one big mistake I made that I should have "inset" the windows but as they are 4 different components only, this will be some 5 minutes to fix)
        Different perspective sketches:
        This seems to be the one that has eventually been built (see some photos below)
        A plan that does not fit any of the elevations or perspective sketches but was good to sketch the site plan up
        Some elevation variations:
        Finally some photos of the ready building:
        You know Mike I had bigger plans with this project but eventually not everything (especially the "prizes" of the challenge) worked out and finally here is this bloody 3D BaseCamp, too, so maybe next time.
          Roger
          Is Forbat the guy who coined the phrase, "Think inside the box"?
          http://www.azcreative.com
            I don't know, Richard, sorry. This is the "top 20 cm" for me - I generally work with older stuff (from deeper).
            BTW we have just found a new Roman cemetery building (to add to the some 30 already known ones of our World Heritage site).
              sepo
              Gaieus, it is quite good render. My coment would be that window frames are never done in front of wall planes . They are always set back in the reveals. I would say 75 mm min. and maybe even 100mm. The only other thing is that kerbs read like ridge tiles. All in all nice render....believable. 👍
              • simon le bonS Offline
                simon le bon
                Dear Gaieus,
                What a good idea to initiate this architectural thread based on an extensive documentation.
                We are surely going to take fun with some plans to elevate.
                +++simon
                • EdsonE Offline
                  Edson
                  csaba,
                  please keep us posted on your progress with modeling and rendering this architecture. great stuff so far.
                  http://www.mahfuz.arq.br
                    Will do...
                    I think there is no much secret in these plans anyway so when I am done with them, I might even give away all the skippies, as well to the community to play around with them...
                    I will, Edson, so all the architects here can "enjoy".
                    • Bryan KB Offline
                      BauHaus and Le Corbusier were probably the most influential of the Modern architects in Europe and they continue to influence to this day. Arguments can be made for others, but these 2 are the most well known.
                      Enjoy the exhibit! Lucky you!
                        Mike Lucey
                        Well spotted Sid 👍
                          Another one - the so called "Zehmeister House" by Forbát again.
                          Even the two plan and elevation drawings do not perfectly match but what I really had to do was to combine those with a concept drawing that had one extra floor and a terrace on the flat roof.
                          The concept drawing
                          South and north elevation and ground floor plan
                          East elevation and basement plan
                          Some renders...
                            Another project - a whole block (also by Forbát). This has never been built however there are now similar "BauHaus-like" buildings on that corner.
                            No renders (yet). I really do not know what to do with this as it is right in the middle of the town and without its surroundings, it does not show too much.
                              Yet another one by Forbát. This was eventually built although not by his design but very similarly. The image is what it looks today, not my render... 😒
                              http://www.szallashelyajanlo.hu/szallas/406_1.jpg
                              and the design by Forbát:
                                sepo
                                First rendered model looks much better now. I have just one comment regarding that model and it is thickness of the coping. In your model it looks like 150mmm or 200mm although in reality it is usually about 50mm thick. 👍
                                  @sepo said:
                                  First rendered model looks much better now...
                                  Thanks 😄
                                  @sepo said:
                                  ...I have just one comment regarding that model and it is thickness of the coping. In your model it looks like 150mmm or 200mm although in reality it is usually about 50mm thick. 👍
                                  What? I can see no problem with that!
                                  Edit; just joking. Thanks for the crit; I have changed that coping
                                  • EdsonE Offline
                                    Edson
                                    csaba,
                                    keep an eye on those converging vertical lines. good photographers never allow them to happen.
                                      Yes, I read these suggestions... But that's actually how perspective would work!
                                      I could do two-point perspective (or at least lower the FOV) but the demand was to do the renders from street level (also there is nothing much in the background and I did not want that to be too apparent).
                                        sepo
                                        Reads correct now 👍
                                        • EdsonE Offline
                                          Edson
                                          if you make the observer look to a point exactly as high as his eyes tehre will be no convergence and the shot will still look natural. I do this by placing two equal edges as the point of view and the view. then I use the position camera tool, clicking on the first edge, keeping the mouse button pressed down and then release it over the second edge. I hope this helps in any way.
                                          • massimoM Offline
                                            massimo Moderator
                                            Gai I know that you can correct the perspective directly in SU, but if you are in hurry you could also try ShiftN a great, free little program to do that in post pro in just a couple of seconds. 😄
                                            perspective corrected
