    Challenge Chair
    57 Posts 19 Posters 10.5k Views 19 Watching
    • olisheaO Offline
      olishea
      wow great work! arail yes that is a cool image, almost like indian ink!
      very sensual massimo! tunnel of light!
      here is a heavy brushed stainless:
      http://i654.photobucket.com/albums/uu269/olishea/steel1copy.jpg
      oli
        Care to share those TWR settings? Especially the reflection value. I presume that's the brushed metal you shared awhile back?
        • olisheaO Offline
          olishea
          its the twilight scratchmap that Fletch posted, 0.05 bump strength (sometimes I use 0.1 if further from camera), brushed silver template. 450 shininess (play with this value, 600 looks good too). u need several light sources (or hdri) for the reflections to be convincing. I would post the skp but the scratchmap is for twi users etc.
          did bit photoshop with this one: duplicate layer>blending mode, soft light. duplicate layer, desaturate, change blending mode to overlay. some curves adjustments and then dof blur
          oli
          • arail1A Offline
            arail1
            Some thoughts:
            Different communities develop in different directions. For instance, in the modo community members often post video tutorials, generally for free but sometimes for sale. There are 'big' tutorials that are priced in the $30 range but there are also tutorials in the $8 to $10 range. Generally the price difference has to do with length.
            Sketchucation has nothing like that and I wonder why. It could be that Luxology sells tutorials and therefore sets the pattern for doing so but Google doesn't.
            For those of us who are real novices tutorials are a great benefit to learning. I have a dozen modo tutorials and there's only one that I regret buying, the rest I've watched numerous times and they've paid their way several times over.
            Olishea's description above veers from SketchUp to Twilight(?) and then into PhotoShop. I would gladly pay a reasonable fee to see a thorough treatment of the whole process beginning to end in a video tutorial. And I'd also pay for anything Solo or several others on this board would produce.
            It might not be profitable here. In modoland the entire community is geared towards these video tutorials and are ramped up to buy them when they come out. Introducing such a trend over here might not generate the same amount of buyers simply because Sketchucation Forum members aren't in the habit of doing so.
            But it might be worth giving it a shot and seeing what happens.
            • massimoM Offline
              massimo Moderator
              Nice brushed steel Oli πŸ‘
              Here you have some (already) vintage exemplars... πŸ’š
              Only a quick levels adjustment in post pro.
              • arail1A Offline
                arail1
                Great steel massimo. It's perfect.
                Here's one with a worn brass finish via modo presets.
                I should have worked on the grass more but it got late.
                • I Offline
                  inasia
                  Hi Every body,
                  Good morning, simply amazing, i am lost for words, APPLAUSE.......!!!!
                  Indeed this is an oasis of jewels, treasure gem of Sketchup, all contributing and sharing.
                  Have a good day, Thank you very much.
                  cheers
                  inasia
                  • olisheaO Offline
                    olishea
                    inasia, why not give it a go yourself? download the model from the first page of the thread. πŸ‘ πŸ˜„ just have some fun!
                    these modo presets are v nice, the vintage steel looks great massimo....nice soft blurry reflections. how much control do you get over the frequency and pattern of the rust/patina?
                    oli
                    • massimoM Offline
                      massimo Moderator
                      Thanks arail1 and Oli. πŸ˜„
                      arail1 good brass indeed. πŸ‘
                      Oli, that is a quite articulated layered material I've made some times ago in Kerkythea. The base is a NK chrome over a rusted texture with diffuse, specular and bump maps. In this case the rust patterns and the subtle patina are given by masks, so in KT you have only to scale, rotate, and change the UV of the masks in order to control the patterns. So I have to say a lot of control compatibly with the texture's pattern you use as mask. The material was applyed directly in KT on a flat colour from SU so without UV coordinates.
                      Don't know if you can use that kind of layered materials in Twilight, but If you are interested in playing with it just PM your e-mail and I'll send it to you. πŸ˜„
                      • N Offline
                        notareal
                        Here is we go...
                        Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                        • olisheaO Offline
                          olishea
                          sweet!
                          are they stacked, or just sharing an intimate moment?
                          nice materials πŸ˜„
                          oli
                          • FrederikF Offline
                            Frederik
                            🀣 Subject: 69 πŸ˜†
                            Cheers
                            Kim Frederik
                              teofas
                              great renders all, my favorite is the one with the man in the chair πŸ‘
                              http://www.spazioarquitectura.com
                                Here's a quick Octane Render - took 50 secs to export [using my new exporter] and ~60min to process, up to ~1200s/px with 83,300 faces, glossy/specular etc for shiny metallic-plastic and tiles [I threw in some newspapers to confuse things] - but it could have stopped much sooner [15mins?]- [but I went to the pub - it is Friday p.m. !] Chair.png
                                  martin-art
                                  Thought I would have a try in Shaderlight, it is rendered with IES lights and also GI.
                                  Martin
                                  http://i794.photobucket.com/albums/yy221/shaderlight/Shaderlight for SketchUp/nightchairsmall.jpg
                                    sepo
                                    Cool....is this shaderlight for Max or SU? If yes for SU, are you going to release new beta?
                                      martin-art
                                      The render was done in Shaderlight for SketchUp.
                                      The full release of Shaderlight for SketchUp which includes the artificial lighting features is planned for September so there’s not long to wait. We will be at Google Basecamp so if anybody is going, there will be a chance to get a sneak preview of the final release.
                                      Martin
                                      • olisheaO Offline
                                        olishea
                                        it looks good, although spot way too bright. will there be total control of point/spots/emitters? looks like a very appealing app, not had chance to do any testing though sorry. would be nice to have another weapon in the arsenal! what is expected price?
                                        oli
                                          sepo
                                          Thanks for reply Martin. I have ab invite but unfortunately I am not able to attend.
                                            martin-art
                                            Thanks for the feedback, there is full control of the lights including intensity, colour and direction. There will also be some new controls for HDR's and a new physical sky system.
                                            The cost is going to be $199 for the Pro version of the software, there will also be a free version.
                                            Martin
                                            • 2 / 3
