    [Plugin] 2D Tools
    791 Posts 178 Posters 725.8k Views 177 Watching
      TIG:
      Use none of them. Use the constants listed in the Tool class' description.
      http://code.google.com/apis/sketchup/docs/ourdoc/tool.html
      CONSTRAIN_MODIFIER_KEY = Shift Key
      CONSTRAIN_MODIFIER_MASK = Shift Key
      COPY_MODIFIER_KEY = Menu on Mac, Ctrl on PC
      COPY_MODIFIER_MASK = Alt on Mac, Ctrl on PC
      ALT_MODIFIER_KEY = Command on Mac, Menu on PC
      ALT_MODIFIER_MASK = Command on Mac, Alt on PC
        Michaelv
        @tig said:
        So are you saying id I change the '..==VK_CONTROL' tests to '..==VK_CONTROL or ..==VK_COMMAND' it'll work on both PC AND MAC?
        Please post or PM the files
        I need to prepare an update... πŸ˜’
        Well here is the thing, the control command on MAC should work but it didn't and I don't know why, sometimes it is said and written that the control function on PC is the command function on MAC, it didn't work in this case either.
        So I just substituted the Command key to the control key and left the ALT alone (which is option on MAC).
        I'm not sure what the VK_COMMAND corresponding key is on PC if any (maybe the window icon key).
        For the sake of information here is some I found: http://www.roughlydrafted.com/2007/08/11/how-apple-keyboards-lost-a-logo-and-windows-pcs-gained-one/
        So the "or" line may work but may introduce a second key on PC which may not be desirable.
        As for the generic commands that Thomthom listed they will work but beware. I thought about using those too, but in my particular case I work on a laptop and I don't have a "menu" key AFAIK, so again it's not as universal as they'd like.
        Copy_modifier_mask and Alt_modifier_mask would work fine here it seems but they reverse the use (ctrl and alt)
        As you saw from the story above the control key is really the command key on mac keyboard so I found it just simpler and more intuitive to modify all (text and variables), where option/alt remains such and command becomes the more global modifier. Much more logical and clean as the text match too.
        Files coming later tonight.
        On the 2D line, alt could be a 3 way toggle too but that's more work.
        The link that Thomthom posted has all the variables mentioned (VK_COMMAND, etc..) lower in the text. They claim it to be universal Mac/PC but I'm not sure. VK-ALT for sure (Option/Alt key on my keyboard)
          I can set a test for a PC or Mac OS and then use the appropiate VK_... πŸ˜‰
            "Menu" is the "Alt" key - I don't know why the manual says "Menu".
            I have that small wireless keyboard for my Mac, and I have all the keys required. And I expect you have an Alt key available.
            Those generic keys are the least work as they avoid having to test for Windows or Mac.
              But since Alt and Ctrl are effectively swapped over from PC to Mac using this method you'd need to test to change prompts and Help files, as Alt on the Mac is not Alt on the PC.
              PC Ctrl = Mac Cmd - = VK_CONTROL or = VK_COMMAND for PC/Mac respectively.
              PC Alt = Mac Opt - both = VK_ALT
              PC Shift = Mac Shift - both = VK_SHIFT
              In 2Dtools it's a simple fix to test for both key presses ? If a PC user presses 'command' [whatever that is?] then it's the same as pressing 'ctrl' anyway, as the 'command' key is not used otherwise on PC and there's no 'ctrl' key on a Mac to muddle us? The 2Dlinetool uses TAB to set Z value option, but it looks for two possible key press codes because TAB varies on the PC and Mac... if key == 9 or key == 15 ### 9 for PC and 15 for MAC...
                No, this is exactly why COPY_MODIFIER_MASK is for "Alt on Mac, Ctrl on PC"
                The *_MODIFIER_KEY and *_MODIFIER_MASK let you check for the various modifiers in a cross platform method.
                  The PC user presses Alt - a Mac user usually thinks of Mac's Opt == PC's Alt - so a Mac user should press Opt......... As I see it this suggested method is contra-logical......
                    Yea - names are confusing, mainly the ALT_* constants, but using these constants will match up the modifier key behaviour of native SketchUp. And I guess it matches common behaviour of the platform?
                    Since OSX has 4 modifier keys and Windows has 3 - things aren't mapped 1 to 1.
                      grim
                      tig
                      is it posible to get these 2d tools working in the layout portion of sketchup?
                      they would be a great help when preparing documentation drawings
                      regards
                      grim
                        @grim said:
                        tig
                        regards
                        grim
                        Sorry, but SUp's .rb isn't transferable to LO - there are lots of useful tools inside LO though ??
                        • kenK Offline
                          ken
                          On the 2D Text tool would it be possible to limit the color selection to just 8 colors. Right now the end of the list is off screen's bottom and this makes it impossible to select yellow or any other color that is be at the bottom.
                          Again thanks for the plugin.
                          Ken
                            Ken
                            You CANselect off any list that goes off the screen...
                            Select that list option...
                            Type the first letter of the color you want - say W for 'White'
                            The list jumps to 'Wheat' - because it's the first item starting with W...
                            Now use the down-arrow key to scroll through the list until you have 'White' selected
                            If you wanted 'Violet' use the up-arrow key to scroll up to that etc...
                            In your example pressing 'Y' would jump to 'Yellow' directly as that is the first item it finds...
                            The clunky 'inputbox' methods are not great but you can work through them...
                            A web-dialog based interface with proper-scrolling is on the to-do-list... πŸ˜’
                            • kenK Offline
                              ken
                              Thanks. That works for me. I was unaware of this feature.
                              Again, thanks for your plugins.
                              Onto another note, will you be at 3D Basecamp?
                              Ken
                                Ken
                                Unfortunately, it's a no.
                                Google arranged 3D Basecamp a verybad time...
                                I have a sick relative coming to live with us around then... AND I have to get things ready [like finish the new ground-floor bedroom/bathroom etc]... AND also it's aloooong way... AND it's a lot of money for a few days' junket AND... it starts on my wife's birthday AND it ends on our wedding-anniversary πŸ˜•
                                So all in all a resounding 'no' - though I would have loved to have gone πŸ˜’
                                • utilerU Offline
                                  utiler
                                  Ken
                                  Excuses, excuses, TIG.... πŸ˜‰
                                  Just Curious...
                                    gcp310
                                    does this plugin only work for SU porfessional, or will it work with the free version.
                                    i cant get it to load up.
                                    Glenn
                                      It works on SU Free. Have you extracted the zipped folder into your plugins directory? Making sure to keep the folder/file structure intact.
                                        Glenn, it works with both pro and free versions of SU. Perhaps you could be a little more specific about what you've done and what's happening.
                                          Also it's not to be found in the Plugins Menu... See Menu > Draw > 2D Tools > sub-menu items... AND you will need to activate the 2D Tools toolbar from Views > Toolbar > 2D Tools to see that too...
                                          Please read the instructions in the Help file...
                                            gcp310
                                            i feel like such an idiot, yes, they have been there all along.
                                            sorry, i had been so engrossed in trying to get them to appear in the plugins section.
                                            thanks for the info
                                            Glenn
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 39
                                            • 40
                                            • 13 / 40
