    Architectural models - untextured, unrendered
    33 Posts 13 Posters 3.7k Views 13 Watching
    • michaliszissiouM Offline
      michaliszissiou
      Excellent work, I enjoyed the traveling too. πŸ‘ πŸ‘ πŸ‘
      • brookefoxB Offline
        brookefox
        Robert and Michalis...thanks for taking the time. β˜€
        ~ Brooke
        • bazB Offline
          baz
          Brooke, great work and one of the best animations I have seen.
          I'm also a fan of NPR and native sketchup, I took your first post as an invitation, so here's my contributions.
          The first one was to demonstrate a safety barrier modification. (Native SU exported at 3000px wide and resized).
          The second I have shown here before in another context but it got some comments relevant to this post, I think. (Layout)
          Baz
            Robert
            Nice work Baz!
            Would be it possible for you to post your style settings for both of these images?
            Brooke, could I request the same from you also?
            I'm really enjoying this thread...it's quite inspiring πŸ˜„
            Robert
            • bazB Offline
              baz
              Hi Robert, saw your 'elevations' post. ( http://forums.sketchucation.com/viewtopic.php?t=29351#p256221 ) Nice stuff.
              As to your question: just standard settings apart from fog in the first image. I might have vectorized the layout image, can't remember, but in any case it doesnt affect the output at this size.
              Baz
              • Bryan KB Offline
                Very nice animations, brookefox. Very nice!
                  brookefox
                  Baz, thanks to you and ecofeco, and thanks to you for posting, and a nice model image at that. The thread is, as you observed, open and eagerly inviting more participation.
                  Robert, my style settings are nothing, really... I'll add a pic later.
                  ~ Brooke
                  • pbacotP Offline
                    Very neat views and videos. I like this sort of work too. A few questions and a comment.
                    1. With the illustration of many thinner elements such as decks and steel members, do you have problems with lines of the far sides of objects showing through? How do you prevent this? Is it due to all the round edges that you don't see this?
                    2. Are you an engineer? I.E. how do you develop your steel designs?
                    3. In the videos the shadows seem to advance evenly with the sequence of shot transitions. Did you time them to continue evenly over several scenes or are these simply long (and well designed) transitions? Works well.
                    4. I find most animations where the camera reverses itself, either zoom in--then out, or pan--then reverse pan... very distracting. I know this is common in SU animations including my own. BTW did you edit the animation after SU export?
                      brookefox
                      1. With the illustration of many thinner elements such as decks and steel members, do you have problems with lines of the far sides of objects showing through? Not particularly, though I do have plenty of probs often enough.
                      How do you prevent this? Lack of coincidental faces and edges, I guess.
                      Is it due to all the round edges that you don't see this? I don't think so.
                      1. Are you an engineer? No, I'm a architect fantasist.
                      They are not developed. My next step is to bring the engineer on board. The idea was to model it sufficiently to give him an idea of where I'd like to open the discussion. I hope I can report back at a future date with how things evolve. I must be open to change for reasons of poor concept and economic reality.
                      1. In the videos the shadows seem to advance evenly with the sequence of shot transitions. Did you time them to continue evenly over several scenes or are these simply long (and well designed) transitions? Works well.
                      Thanks. It's a nice set of bones, on a nice site. Nothing calculated, just eye-balled. In this case the east side (carport) shows morning shadows and the west (deck) side shows the afternoon shadows, with the camera moving around the south side.
                      1. I find most animations where the camera reverses itself, either zoom in--then out, or pan--then reverse pan... very distracting. I know this is common in SU animations including my own. BTW did you edit the animation after SU export?
                      No editing, and really too much and rather jerky camera movement. Not that easy for me to do precisely, with the transitions being somewhat unpredictable. Certainly practice and some learning would help (me).
                      ~ Brooke
                      • pbacotP Offline
                        Is it due to all the round edges that you don't see this? I don't think so.[/i]
                        Thanks, I guess you don't run into that problem. If I leave as much as 1-2" between a line and a covering surface--not coincident--and view the surface from some distance, the lines bleed through,looking dotty. So the answer I suppose, is not to zoom out too far in such a case.
                          brookefox
                          Oh yes, for what its worth, I have that problem, too.
                          ~ Brooke
                            brookefox
                            An even less polished attempt at a model of the existing structure. The railing really pretty much looks like that.
                            ~ Brooke
                            • daleD Offline
                              dale
                              Great work. It reminds me of a job I was involved in a while back. Although this ended up as a monster file colored, textured and rendered, in the early stages we presented them as simple line drawings. I was always fond of it, maybe because of a background in hand rendering. I had several, but could only find this one.
                              • bmikeB Offline
                                bmike
                                Nice to see other work that keeps it simple.
                                I posted these over in the LO discussion on construction documents: (size will hurt me here, these were 24x36" PDFs)
                                http://lh5.ggpht.com/_0jkA5M3PGcY/TAgS8rNOEfI/AAAAAAAAPRg/MLtHgfNq2Hw/s800/vww-6-2-10-presentation_14.jpg
                                http://lh4.ggpht.com/_0jkA5M3PGcY/TAgS7KlD9-I/AAAAAAAAPRI/aRoaJXwk38o/s800/vww-6-2-10-presentation_03.jpg
                                Another project:
                                http://lh5.ggpht.com/_0jkA5M3PGcY/S47R9usMzlI/AAAAAAAAOvI/pZzgrI8fwks/s800/millrd-presentation_01.jpg
                                http://lh4.ggpht.com/_0jkA5M3PGcY/S47VeCJZR7I/AAAAAAAAOvw/MATZLkwV90I/s800/millrd-presentation_03.jpg
                                http://lh6.ggpht.com/_0jkA5M3PGcY/S47RfUBqjNI/AAAAAAAAOug/yNobOMTAFok/s800/millrd-presentation_12.jpg
                                http://lh3.ggpht.com/_0jkA5M3PGcY/S47Ry5ItDNI/AAAAAAAAOuk/slcbzaoND3s/s800/millrd-presentation_14.jpg
                                • marvins_dadM Offline
                                  marvins_dad
                                  You guys have some great work. Love the play of the shadows and minimal textures.
                                  Here is a little dome I am working on for a Court House.
                                  My Gallery
                                    cheffey
                                    Wow, it's refreshing to see some native SU work. Excellent work. The simple style really works well on these very detailed models you are all showing.
                                    BROS RŌMAN BRΓ„UN
                                    • bazB Offline
                                      baz
                                      here's a couple of sculptures to mix it up a bit.
                                      baz
                                      300mm high, cast bronze from carved forms.
                                      3000mm high, cast bronze from carved form.
                                      • daleD Offline
                                        dale
                                        great stuff!
                                        Here's one that I did a while back to solve some framing and truss issues.
                                        • bmikeB Offline
                                          bmike
                                          A few quick shots of recent work (design by another firm):
                                          • Bryan KB Offline
                                            Looks great.
