    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 1.8m Views 329 Watching
    • I Offline
      InterArchi
      @gaieus said:
      Hi hichem and welcome!
      Indeed the one attached to the first post is the newest version. This plugin is a bit tricky to use (thus is is still called "Beta"). Are you sure you are doing everything right (or installed the script correctly)?
      Thanks brother for answering me, I guess I have fixed that out, the only problem is that I didnt copy the Jpeg files into the directory of plugins 😒 thus, the plugin didnt work properly any way thank you very much for your help,
      If I need anything arround, I will call for your help, I have just discovered this forum and I'm really learning from you guys I do really appreciate your efforts 😉
      • Chris FullmerC Offline
        Good, glad you got it working.
        The main problem with this plugin is that it was written by a no good hack of a programmer. Everytime this plugin works it surprises me. I love this plugin and I'm certainly proud of it. But it could use a major re-writing to get it to be more stable and more versatile.
        Thanks for using it,
          Allen Brown
          Hey Guys,
          Sorry if this has been covered already, but I am a complete noob with SU, and have never used scripts.
          First of all, I am using the free version 7.0.10247.
          I first downloaded progressbar.rb. This is where my first problem starts; I unzipped it to my desktop, but I don't know what to do with it from there. Double clicking on it brings up a window asking me what program to use to open it.
          Can someone point me in the right direction?
          Thanks,
          Allen
            Hi Allen,
            First off, welcome to SCF!
            I noticed you're using SU 7.0.1, Google released 7.1 awhile back it's alot faster, give it a go..
            As for plugins, Gaieus posted a little tutorial here
            Basically all plugins are placed in your plugins folder...
            Program Files>Google>Google Sketchup 7>Plugins
              Allen Brown
              Thanks Rich. I got both the progress bar rb & the shape bender rb's copied into my plugins folder. It appears to have worked somewhat, because I have the shape bender tool on my toolbar, and under the plugin menu I have the chris fulmer tools. However, I don't see anything about the progress bar rb in the plugin menu, should I?
              Anyways, I create some 3d letters, click the shape bender tool, and I would expect to see "Please select a single line..." down at the bottom of my screen, but I get nothing. It's as if it doesn't really activate. I also tried by going through the plugin menu, but I get the same behavior.
              Any ideas what I'm doing wrong?
              BTW, I did try exploding the letters, then shift selecting, right click and making "Component", but still the same.
              Thanks,
              Allen
                This loos like you probably just got some files in the wrong spot. In your base Plugins folder, there should be a file called clf_shape_bender_loader.rb and a folder called clf_shape_bender. All other files (a bunch of icons and and file called clf_shape_bender.rb) should all be inside the clf_shape_bender folder.
                If you feel like you have the files in the right spot, then you need to open the Ruby Console in the "Window" menu. Have that open, then try to run shape bender once. It will probably write a bunch of errors to the console. copy (ctrl-c) those and paste them back here. I'll look at what the error is and we'll go from there,
                • I Offline
                  InterArchi
                  I have the honor to have an answer from you mister Chris, I'm now in this forum, and in the plugins world,
                  But I really need some help, I started to add some plugins to my Plugins repertory but I sometimes have a problem with the loader file
                  for exemple with the 1001Bit it didnt work please see what the error message shown by sketchup
                  http://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs132.snc4/36962_1359064545183_1488620643_30957670_3783764_n.jpg
                  and this is the screenshot of the those files right indside the Plugins folder
                  http://sphotos.ak.fbcdn.net/hphotos-ak-snc3/hs201.snc3/20864_1359067105247_1488620643_30957672_1265033_n.jpg
                  THIS IS THE ERROR MESSAGE
                  http://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs130.snc4/36839_1359068385279_1488620643_30957673_5799759_n.jpg
                    You've put all of 1001bits files into the plugins root folder. All but one, 1001bit_tools.rb should be in a 1001bit folder.
                      Allen Brown
                      Awesome Chris! That was it.
                      Thanks so much for all you do!
                      • I Offline
                        InterArchi
                        Thanks Bro ..U have a heart of Gold
                          thelandscaper
                          Hey, you have no idea the way you are helping me my friend!!! Thank you Thank you Thank you!!!
                          keep on the gooooood work. 😍
                          "If life brings you lemons, get salt, Tequila and call me over"
                          • charly2008C Offline
                            charly2008
                            Yesterday I installed the beta version 0.55 and get the following error message.
                            The clf main folder is containing all files. the progressbar and the shape bender loader are in the plugins folder. Can anybody help.
                            Charly
                              Try replacing this file in the ../Plugins/clf_shape_bender/ sub-folder clf_shape_bender.rb - there was a potential error with the YouTube linking in part of its code [around line 1003] that got 'masked' if you have other clf tools loading it correctly before this one - this now fixes it in every case.
                                charly2008
                                Hi TIG,
                                thanks for your quick response it works now.
                                Charly
                                  mjsnyder80
                                  Hello out there. I'm new to the forum, but have been using sketchup for many years now. I just discovered the bender script, but am not able to get it to work. The progress bar at the bottom stops either at 1% or 5% depending ont he complexity of the group. The ruby console shows the following text:
                                  Error: #<NoMethodError: undefined method /' for nil:NilClass> C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender/clf_shape_bender.rb:676:in draw'
                                  As I am not a programmer, this is completely over my head. Can anyone help to get this script working?
                                  Many thanks.
                                    This sounds like you might be having a conflict with an old version of Component Spray plugin.
                                    If you have component spray installed, please uninstall it and re-install the newest version. THat should fix your problem. Let me know if works or not.
                                      mjsnyder80
                                      That did the trick. Thank you very much. And by the way, this is an awesome plugin. Nice work, and thanks again.
                                      Mike
                                        darkhelmet
                                        I've almost given up. Ran Ruby console while trying to use this plugin and this is what i got:
                                        Error: #<NoMethodError: undefined method all_connected' for nil:NilClass> C:/Program Files (x86)/SketchUp 7/Plugins/clf_shape_bender/clf_shape_bender.rb:307:in line_picker'
                                        C:/Program Files (x86)/SketchUp 7/Plugins/clf_shape_bender/clf_shape_bender.rb:239:in `onLButtonUp'
                                        WIN7 64bit
                                          Hmm, do you have component spray installed? If so, please update. There was a version that was around for a while that caused problems.
                                          If that does not work, please verify that you have the files in the right places. In the plugins folder you should have a file called clf_shape_bender_loader.rb and a folder called clf_shape_bender. All other shape bender files (another .rb file and a bunch of icons) should go inside the clf_shape_bender folder.
                                          So I guess verify those two things. If you do have the most current version of component spray instlled (please actually do re-download and install it again) and you do have your file structure set up correctly, then come back and we'll keep trying things.
                                          • Y Offline
                                            yna
                                            im having problems with the plug in. in the video after i click both the curved line and the straight line the red highlight appeared but the green diddnt and when i pressed enter, nothing happened. what did i do wrong? please help me
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 63
                                            • 64
                                            • 30 / 64
