    Easiest way to create 3-D home from plan view?
    17 Posts 7 Posters 2.4k Views 7 Watching
      Offset everything by 2" inside then offset the whole perimeter another 2" outside.
        mac1
        Also there are numerous TUTs on modeling a house here is some http://www.youtube.com/results?search_query=sketchup+model+house&aq=f
        • Mike LuceyM Offline
          Mike Lucey
          mgianzero,
          I have been using a very simple process for bringing a house plan, section and elevations to a 3D model for some time. I only produce the external skin initially which is what you seem to need. In most cases this along with 2D plans and a section is sufficient for most needs.
          Shoot me scans of the plan, section and elevation and I will produce a tut on my method as I've been meaning to do it for some time.
          Mike
          mike.lucey(at)gmail.com
            mgianzero
            Mike,
            I sent you an email of my plans and a Sketchup file I made thus far. I hope you can follow this.
            Thanks so much for helping. Please let me know what your shortcuts are for drawing plans with Sketchup.
            Marc
              Mike Lucey
              Hi Mark,
              I got the files okay. I see they are in imperial! It's been years and years since I worked (drawing) in feet and inches even though I still think in both metric and imperial.
              I will make a start tomorrow and post screen shots of the process I use. BTW, its a nicely designed house πŸ‘
              Mike
                mgianzero
                @mike lucey said:
                Hi Mark,
                Mike
                Sorry Mike, but we still, unfortunately, use the imperial system over here in the US. I wish we did use metric.
                Any ways, I am excited to see your technique for drawing such plans in Sketchup.
                To be honest, though, I am not so fond of this home design. The ceilings are too low and the entry way and staircase are too confining. I am hoping to try and remodel these aspects with Sketchup and show them to an architect to see if it can be remodeled fairly economically.
                  @mgianzero said:
                  ...To be honest, though, I am not so fond of this home design. The ceilings are too low and the entry way and staircase are too confining. I am hoping to try and remodel these aspects with Sketchup and show them to an architect to see if it can be remodeled fairly economically.
                  This seems to be an interesting project and I will be watching it.
                  Come on, Mike, you are an architect after all! πŸ˜‰
                    mgianzero
                    Hey Mike.
                    How are you doing with those tutorials on your Sketchup method for making a Sketchup model from my 2-D plans?
                    I haven't heard back and was wondering what you've come up with. Post whenever you get the chance.
                    Thanks again for helping me with this.
                    Marc
                      gealagie
                      I might as well tack my inquiries to this thread as I am about to try to do what mgianzero is/was doing a few months ago. I'm about to remodel a kitchen and adjoining utility (laundry) room/garage access. Some months ago I tape-measured and created a SU model of the utility room, but only of it's inside-facing surfaces (walls without thickness) and the project went no further. Now I've found our house plans and I'm thinking (as mgian--Marc did) that raising the house from those would be easier than measuring it out manually.
                      So Gaieus has suggested to import a raster file (.tif? .jpg? .gif?) and to scale it. Is there a video or tutorial for that? Does it come in as a lot of pieces of a group that you stretch together to a hand-entered length? My experience with SU is limited--I have one previous thread here, where I was creating an underground geological "landscape". You folks were great help to me finishing that project. Sadly, I have not had the time or need to do anything else with SU until now.
                      Gealagie, also a Mark
                        Import your plans as an image. Then use the measuring tape tool to measure an internal wall and then just type the actual length of the wall and hit enter. You'll be asked 'do you want to resize the model'. Choose yes, and now your imported image of the plan is to scale!
                        It's a case of happy modeling from here. I advise to use layers for different things like Walls, floors etc. It'll prove invaluable
