    [Plugin] Superglue
    81 Posts 18 Posters 51.4k Views 18 Watching
      What do you use to make the videos with annotations?
        YouTube itself has these annotation tools. The video was simply captured with CamStudio but I did not edit anything in it.
          Ah cool. I'm about to produce the videos for Vertex Tools now. Never uploaded to YouTube before.
            Let me know if I can help (although I myself am not a great YT'er either). Also, annotations/annotating can be shared so when you get to there, I can also help with doing that part.
            • EscapeArtistE Offline
              EscapeArtist
              Very useful. Saves the time of having to align things with the rotate tool when they're slightly off kilter.
                Ben Ritter
                Thank you Thomthom.
                  Version 1.1.0
                  Merged into one tool. Use Ctrl to toggle between Superglue and Solvent.
                    Thanks Thom πŸ‘
                    @gaieus
                    Warn Thom for spamming/bumping (spumping?)
                    @thom
                    Warn gaieus for bumping/spamming (bamping?)
                    @ rich
                      Sorry I am in total fog 😳
                      I believe that you must make another video more explicte πŸ˜’
                      (where are the axes of glue at the start and in which volumes...
                      I am waiting the Doh revelation πŸ˜„
                      As you can see these 2 components have at the start no special Glue plane between them
                      They are just aligned
                      After glue no changement... so...foggy mood 😳
                        The components must already be defined as Glue to components. If they don't have this property they won't be glued.
                        The tool doesn't turn components into GlueTo components - it just glue/unglues existing ones.
                          Here's my test file.
                          Superglue.skp
                            It's a wee bit tricker to define an arbitrary axis that yields predictable result.
                              CodyV1
                              I can't illustrate this, but I can try to explain it.
                              You can rotate (using SU's native rotating tool) components on a specific glue line. Basically so that components are angled at something other than 90, 180, 270, 360 degrees. πŸ’­ ❓
                              Be There
                              http://www.facebook.com/#!/profile.php?id=100000814922209
                                hehe this was not implicite! πŸ’š
                                Now I more understand! πŸ‘
                                So next version must create the new Plane Glueing when any don't exist!
                                and maybe also very useful πŸ˜‰
                                  @thomthom said:
                                  Version 1.1.0
                                  πŸ‘
                                  Works like charm!
                                    Sorry - I'm still not understanding this. "rotate one a glue line"?
                                      CodyV1
                                      You basicaly rotate the glue, and every component stuck together with the glue. Like making a group of those components, and then rotating the group.
                                      Be There
                                        Isn't that just selecting the components and using the rotate tool?
                                        I can't get a grip on what this "glue" is. πŸ˜•
                                          CodyV1
                                          Nevermind πŸ˜’
                                          Be There
                                            • 2 / 5
