    [Plugin] Superglue
    81 Posts 18 Posters 48.3k Views 18 Watching
      @tig said:
      I alwaysdownload the zip to the ../Desktop/,
      Ditto.
        @gaieus said:
        Also, I was planning this little "tutorial" on how to install zipped plugins (as many Windows users will just press the button to unzip the files/folders and Windows tends to put them into a separate folder) so now I finally made it using your plugin thus making it "immortal" ๐Ÿ˜„
        ๐Ÿ˜„ ๐Ÿ‘
          About the glue ๐Ÿ’š
          http://bruxelles.blogs.liberation.fr/coulisses/images/2008/12/10/haddock_2.jpg
          I used to be called Tintin at school. ๐Ÿ˜„
            About the glue ๐Ÿ’š
              @thomthom said:
              ...Solvent unglues.
              Makes sense...
              ๐Ÿ˜ณ
              @tig said:
              Putting zips directly into the ../Plugins/ folder just clutters it up... If you want to use a ../Download/ folder to keep your ../Desktop/ more tidy - then you can leave the zip behind in it for later reference ??
              I do have a download folder for everything else but have got used to saving plugins (zipped) straight to the Plugins folder. I have this external HD I regularly make backups on and beside my Documents folder, I included some of the folders under Program files (SU materials, components, plugins, KT materials, models, globals etc.) just in case. Much easier and faster to recover should anything go wrong.
              But you know, "de gustibus non (est) disputandum" at least as far as one does not screw up his system. ๐Ÿ˜„
                Superglue is supposed to work in SU6 ?
                Because nothing works! ๐Ÿ˜ฎ
                HAve you a little animation of what must the glue's pot must do?
                  I have not tested it. Can't remember if there was any SU7 specific code. I'll check.
                  A video of the plugin in use? Yes I'll make one once I make v1.1.0.
                    Same result in V7, so I must to miss something evident ๐Ÿ˜ณ
                      Do you get menus?
                      Can you start the tool?
                      Do you see the glue bottle cursor?
                      Are there error messages in the Ruby Console?
                        Works like a charm under SU6.
                          Here you go sir (especially, with the annotations it is pretty fast so pause it when needed):
                          YouTube - Superglue Plugin for SketchUp
                          [flash=480,385:3276ci3t]http://www.youtube.com/v/VS8-tjYTPXM&hl=en_GB&fs=1[/flash:3276ci3t]
                            ๐Ÿ‘ Cheers Gaieus!
                            I owe you a cookie.
                              ๐Ÿ˜ฒ
                              I forgot my Cookieware stamp!
                              I forgot the cookie!!!
                                @thomthom said:
                                :thumb: Cheers Gaieus!
                                I realised I could (should) add your name to the Title filed, too, not just into the description filed.
                                ๐Ÿ‘
                                I owe you a cookie.
                                How about a beer instead?
                                ๐Ÿ˜‰
                                  Beer also works! ๐Ÿ˜„ ...but I forgot! I'm worried about my mind now...
                                  • mitcorbM Offline
                                    mitcorb
                                    Wow!!
                                    This thread just started and already has two pages of replies.
                                      @mitcorb said:
                                      Wow!!
                                      hehe - inflated by my replies.
                                        Added some pauses when reading the annotation text seemed to be a bit fast. Gee, I like these features.
                                        @thomthom said:
                                        @mitcorb said:
                                        Wow!!
                                        And mine...
                                        ๐Ÿ˜†
                                          What do you use to make the videos with annotations?
                                            YouTube itself has these annotation tools. The video was simply captured with CamStudio but I did not edit anything in it.
                                            • 2 / 5
