    Looking for big table model
    17 Posts 7 Posters 1.9k Views 7 Watching
    • chrisglasierC Offline
      chrisglasier
      I want to get a table like this made but I want to be able to alter it a bit and make my requirements plain to the non English speaking joinery shop owner. If any one has a skp or knows of a source for something similar please help me. (I have no time right now to learn how to make the curvies - the top I can just about manage!)
      Thanks.
      • HieruH Offline
        Hieru
        Are you capable of creating a profile for the legs using a CAD programme or Adobe Illustrator?
        If that is possible then you could import the profile as a DWG/DXF file and then simply create the legs with the push-pull tool.
        www.davidhier.co.uk
          chrisglasier
          Thanks. I understand how to do it but I am going to the workshop on Wednesday and my Sketchup skills are really rather rudimentary. I always think that the quality of the real thing is influenced by the quality of the model/drawings, so I want to see if there is a way to achieve that.
            dedmin
            http://sketchup.google.com/3dwarehouse/search?q=TABLES&styp=m&btnG=%D0%A2%D1%8A%D1%80%D1%81%D0%B5%D0%BD%D0%B5
              Maybe there πŸ˜‰
              • brookefoxB Offline
                brookefox
                The obvious clarification may be that Chris is looking for help with the specific curves, given that the rest is relatively easy. I would offer some but I am not good with them either. You have tried the Fredo6's plug BZ_Toolbar, or no time for that?
                404 Not Found
                (forums.sketchucation.com)
                ~ Brooke
                • BoxB Offline
                  I'm a total noob to all this, but your table looked nice so I had a bit of a go, I just did it by eye, so measurements aren't good or anything like that.
                  It was a good learning experience for me.
                  Perhaps it will help you get further.
                  http://i155.photobucket.com/albums/s296/storeben/Sculpt/Table.jpg
                  I'd also be interested to know from anyone who does happen to look at my sketch, how to make the file smaller? it seems pretty big considering how little there is in it.
                  Table.skp
                    brookefox
                    Looks like you did a nice job. 8185 edges in each leg component is likely pertinent to size. When I unsmoothed/unsoftened the odd surface actions went away. Perhaps those settings could be refined if you like them. The modeling is better revealed without, to my eye. I should check the effect of smoothing on file size.
                    ~ Brooke
                    • BoxB Offline
                      Yes you are right about the softening, I think it's just me wanting to see everything smooth as I work with it. I'm too used to working in stone/glass/wood etc where every little bump is either something to remove or is part of the design. For me the form is the surface not the underlying geometry.
                      I guess my problem is I think in 3D reality and I need to think in 3 virtual D.
                      And thanks, that is some great feedback, it helps no end when you can see it from someone else's perspective.
                      Sorry, enough thread Hijack.
                        brookefox
                        I want to deal with my bumps, because if I don't they will haunt me (multiply insidiously) and so I want to see them as clearly as possible.
                        The smoothing in your model didn't look right to me, but the geometry was. See image. That's why I mentioned maybe adjusting the settings.
                        But I was wrong about the file size: it increased when I de-smoothed. ???
                        (And as for thread hijacking, you're the one who's done most of the work around here.)
                        ~ Brooke
                          chrisglasier
                          Thanks a lot for responding so quickly - especially Box with the splendid skp. I am going to try to smooth out the raised parts on the supports to make it less ornate (more farmhouse) and check the sizes. If successful will post the resulting skp and hopefully in due course a photo of the real thing ... n'shala!
                          Many thanks
                          • BoxB Offline
                            If you just want the plain curves then here it is,
                            You can scale to whatever size you want.
                            http://i155.photobucket.com/albums/s296/storeben/SU/LegPlain.jpg
                            Leg Plain.skp
                              chrisglasier
                              Thanks Box. I have been playing around with your model and came up with this more modestly sized version - 900 x 2000 x 750 high.
                              • BoxB Offline
                                Nice one Chris, I'm glad I was able to help.
                                  sheyue
                                  Thankyou,it's a very good big table,l love it.So,I have some collection of Chineses style furniture design by Chinese friend,but I don't known how to publish them.some one chould help me?
                                    chrisglasier
                                    Do you mean publish them here?
                                    If so start a new topic called "Chinese style furniture designs" and use the upload attachment device to post a few examples in the first post. It would be a good idea anyway if you want to gather some comments and critiques.
                                    Btw my big table has been ordered and work will start in the Zhongshan workshop in three weeks time.
                                      chrisglasier
                                      Delivered today ...
                                      same spirit I think even with though quite different support style.
                                      Also made a platform bed base with elephantine legs and demountable undercart ...
                                      and an experiment with kitchen unit units - this one for the back balcony (yet to be plumbed in) ...
                                      Note wood door and drawer furniture. Doors have dowels instead of hinges.
                                      All is camphorwood with raised grain and clear finish.
                                      More experiments in hand including sofa, armchairs, TV trolley, wardrobes and so on.
