    Various rendering choices? -- Challenge!
    108 Posts 27 Posters 23.7k Views 27 Watching
      Welcome Taff, not as if I would have ever used those techniques myself - just knew about those tuts.
      ๐Ÿ˜„
      This DOF render is cool however to experiment with the various blending modes of the two layers. This is about 50% with "Glow" mode.
        Rico91
        nice object!
        Render from hypershot
        rendertime 1:08 h
        http://lh5.ggpht.com/_rMc47FEl0fA/TCyF3aa7xiI/AAAAAAAACE4/2kYDRPEUz9g/untitled.11.jpg
        [img:y90a5vdg]http://lh5.ggpht.com/_rMc47FEl0fA/Sro-DozMGPI/AAAAAAAABwU/zZsLbdpwWAs/forum_onderschrift_r3d_30pxh.jpg[/img:y90a5vdg] [url:y90a5vdg]http://www.R3Design.nl[/url:y90a5vdg]
        • soloS Offline
          Taffgoch, I overlayed the SU lines (exploded) hence the joins are visible.
          Another quick play.
          • olisheaO Offline
            olishea
            nice renders here.
            Gaieus is right, you don't strictly need the smoky glass/fog materials. just use the depth render and play with different blending modes....overlay and multiply can be used to emphasize foreground/darken background. also try inverting your depth render to change what is/isn't in focus etc if you are using it as a depth mask (for DOF)
            will have a go at this soon hopefully, nice model ๐Ÿ‘
            oli
            • daleD Offline
              dale
              Although a little difficult to carve out of Jade, I'm sure there is a Chinese Master carver out there who would be tempted.
              Thea, IBL,SSS,TR1,1Hr 10 Min
              • TaffGochT Offline
                TaffGoch
                Every good photographer takes advantage of the depth-of-field, for sharp/blur and close/distant distortion. I used to be okay at it, back when I was in college. Your latest renders, solo, really demonstrate the extremes.
                I just have to get used to the Kerkythea settings. I only wish I had more time to play with KT.
                Without these effects, the distinction between close and distant elements "gets lost."
                No DOF adjustments
                With DOF blurring & darkening, the depth is more apparent:
                DOF blur & darken
                -Taff
                "Information is not knowledge." -- Albert Einstein
                • TaffGochT Offline
                  TaffGoch
                  dale,
                  I was thinking of, eventually, trying a sub-surface-scattering jade render, with a centrally-positioned light-source globe, about half the diameter of the weave.
                  I've got to go back to the SSS discussion, and experiment some. If someone else is quicker at it than I, it would be most appreciated if you could please share the KT parameters you used.
                  -Taff
                  • daleD Offline
                    dale
                    Taff
                    I was never able to get very good SSS in Kerkythea, and am still just fumbling and experimenting in Thea. I though I could export a file over to Kerkythea and have a look at the base settings, but realized that I have altered everything, and I'm trying a new rendering of your model. (Which is so much fun to play with by the way, Thanks) I'm not exactly sure if that would have worked anyway.
                    I have seen some really nice SSS work done in Kerkythea though, and I'm sure someone will come forward with some insights.
                    I'm really enjoying the dof discussion, as it is another area I really don't know much about.
                    Great challenge.
                    • HieruH Offline
                      Hieru
                      Great model - I imagine we'll see it turn up as an ornament in many interior renders, or even as a piece of garden sculpture.
                      Here's just a bit of sci-fi fun:
                      www.davidhier.co.uk
                      • david_hD Offline
                        david_h
                        i did one for fun here. Looks like candy.
                          remon_v
                          Octane render (Geforce 470) 10:01, but I don't see the difference after 5 min.:
                          http://i22.photobucket.com/albums/b336/remon_v/SU_challange.jpg
                          I haven't really played with Octane that much yet, but it's fast ๐Ÿ˜„
                            remon_v
                            I left it for 20:01 min now:
                            http://i22.photobucket.com/albums/b336/remon_v/SU_challange2.jpg
                            I do see the difference
                            • daleD Offline
                              dale
                              I think it's already popping up ๐Ÿ˜„
                              • TaffGochT Offline
                                TaffGoch
                                Yum!
                                I like the variations produced by transparent materials, having a moderate internal index-of-refraction,...
                                ...and really shiny materials with all the "self" reflections (like those in the renders posted by remon_v.)
                                Hieru,
                                Soccer? Really?
                                ...sepak takraw, maybe...
                                ...but, soccer ?? ๐Ÿ˜†
                                -Taff
                                • daleD Offline
                                  dale
                                  I thought they both looked rather surprised ๐Ÿ˜„
                                  • simon le bonS Offline
                                    simon le bon
                                    Hi Guys,
                                    %(#0000FF)[Sorry for disturbing with my digression (no render in the pocket ๐Ÿ˜ณ )]
                                    First I have searched to know what notion was covering " a geodesic"! " A geodesic is a generalization of the notion of a "straight line" to "curved spaces". In the presence of a metric, geodesics are defined to be (locally) the shortest path between points in the space." (may be better explain in the french wiki ๐Ÿ˜‰ )
                                    http://i274.photobucket.com/albums/jj245/Spendauballet/generalPicts/300px-Geodesiques.png
                                    ๐Ÿ‘
                                    Your drawing dear Taff Gosh (Taff: The Trans-Atlantic Fan Fund, also known as TAFF, was created in 1953 for the purpose of providing funds to bring well-known and popular members of science fiction fandom familiar to fans on both sides of the ocean, across the Atlantic(>>3D Basecamp 2010!!!!!).Goch (archaic spelling: Gog) is a town in the district of Kleve, in North Rhine-Westphalia, Germany.
                                    Your drawing reminds me an exercise I wanted to suggest some month ago and had forgotten under the pile..
                                    this was: " HOW TO DRAW A PARISIAN FENCE ? "
                                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/cloturetissee001.jpg
                                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/cloturetissee002.jpg
                                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/cloturetissee003.jpg
                                    In my mind the problem was "how to draw a sinusoid following the path of one element (component) and matching the good crossover at the various meeting points?"
                                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/cloturetissee003_b.jpg
                                    The solution you had applied to your geodesic weave sphere opens to me some idea to achieve this..
                                    -one element of answer is that each component goes with a neighbor mirrored one.
                                    clic to enlarge
                                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/TaffGoch001_th.jpg
                                    But it remains a difficult exercise I guess ๐Ÿ˜’
                                    ๐Ÿ’š simon
                                    PS: I'm completely found of your warehouse geodesic collection
                                      richcat
                                      A couple or tries with IRendernXt
                                      http://api.ning.com/files/vfMN9V8PR0jh2Er4N03QeVsxe7kQjomOZokL2j8CUsWOf4DkNpAAkv-pmv3DHSg3l52Gax14ennaAVJB81jpA8jxRSU4g*BL/test5.png?width=737&height=356
                                      http://api.ning.com/files/3Uoavia5AHrOXsnm6rQFcrL38kgFOCbNVLhtcd4dsWTE9KsXs8xFSF6-OxmDkLSIq45YKJ04t96SjOKWdVKvc1nIGGy3yQRB/test2.png?width=737&height=356
                                      http://api.ning.com/files/*LLApHlCatfS6FDJx28n33AfV*r69PLPTimAUfTFFNpB7WfF9TgC6xkE8YPyh5GPqVccvQE8gd5HBmxB4gInjA__/test1.png?width=737&height=356
                                        simon le bon
                                        end of the disturb ๐Ÿ˜Ž
                                        Here is the link for the exercise:
                                        An exercise: DRAWING A PARISIAN FENCE
                                        ++simon
                                          martin-art
                                          Good renders people, given it a try in Shaderlight for SketchUp
                                          http://i794.photobucket.com/albums/yy221/shaderlight/Shaderlight for SketchUp/poolweavesmall.jpg
                                          Martin
                                          • TaffGochT Offline
                                            TaffGoch
                                            Martin,
                                            I was shooting for "jade" last night (and missed.) What I got is similar to yours, in green, rather than red.
                                            Green apple
                                            -Taff
                                            • 2 / 6
