    Broken Curve Segents Selected
    7 Posts 3 Posters 1.4k Views 3 Watching
      Jim
      I don't remember this happening prior to version 7. Sometime when I click a segment of an exploded curve, SU sometimes selects other segments that do not physically touch the selected segment.
      (This is causing an error in CurviShear.)
      Image 1: One segtment clicked, 1 selected. (expected)
      Image 2: One segment clicked, 2 adjacent segments selected.
      Image 3: One segment clicked, 2 non-adjacent segments selected.
      curve_segments.skp
        Hi Jim,
        This has happened quite frequently with me too! I put it down to an error on my side, as in PEBKAC.
        Can replicate this usually after intersecting Becker curves with other geometry. But can't repeatable produce this selection issue on the same geometry after 'Undo'
          Try exploding them twice ?
            Jim
            Nice thought, but Entity Info says 2 Edges selected, and the option to explode is not available.
              Jim
              No I believe it's incorrect SU behavior.
                A curve made up of bits of other curves can rarely explode into these pseudo-curve bits which aren't continuous. It is a glitch in the current version.
                Try exploding the curve, then immediately welding the still highlighted resulting edges, and then exploding them again - I have a shortcut set to 'explode' [curves]... and weld...
                  Jim
                  Weld seems to create the same situation.
