    Circle intersect face *ugs
    16 Posts 6 Posters 1.7k Views 6 Watching
    • brookefoxB
      brookefox
      When circles are placed on a face through explosions of other entities (they themselves are not exploded), sometimes they intersect properly with the face on which they are coincident, often not. SU behaves oddly with regard to them. If I try to explicitly intersect the entities so as to be able to delete an unwanted face of the circle, the operation fails to intersect but doesn't return an error msg. If I redraw the circle nearby and move to the same problem location, it usually results in the circle face being distinct as I want it, but if I copy/move it does not (the face is whole across the circle edges)!!!
      I apologize for not explaining the images in detail but I thought it likely that experienced users are well familiar with this phenomenon. I'll get back if that is not the case.
      ~ Brooke
        SpookyChick1013
        Oh, I'm quite familiar with this little bug. It can be infuriating at times, can't it? 😆 I don't know if there is a solution beyond what you are already doing to compensate. If you find one, let me know? 😉
        https://kuromatsudriveyards.com
        Fo-su to tomo ni aran koto o...
        • brookefoxB
          brookefox
          I guess you and I are the only ones affected... and reading... and writing.
          ~ Brooke
            mac1
            Two out of x a bug does not make but possibly a model or application error. JPG does not tell the whole story post the model!
            • Chris FullmerC
              I'm quite familiar with it. I have grown to hate it. And I can't quite make it perfectly reproduceable. Just sort of sometimes it doesn't cut right.
                mac1
                FYI maybe some help?? http://forums.sketchucation.com/viewtopic.php?f=18&t=677
                • brookefoxB
                  brookefox
                  There is some info there, and it's appreciated, but not regarding this issue, which does not concern components and cutting out but rather proper intersecting of naked ungrouped geometry.
                  Thanks for the chime, Chris.
                  ~ Brooke
                    mac1
                    This is the orginal OP and the "other entities" they them selves are not exploded imply you are dealing with components
                    • Wo3DanW
                      Wo3Dan
                      Brooke, do you mean this issue (no proper intersecting) will occure even when placing the circle (or whatever shape) right in the middle of a face, not touching the face's perimeter? (I do understand the "explode" part of your explanation, to bring both shape and face in the same level (context).
                      Wo3Dan
                      • brookefoxB
                        brookefox
                        No, I don't recall it ever occurring on an initial, naked draw, if I understand you correctly; just when the circle is released there via an explosion.
                        Seems like intersect elsewhere is not foolproof either (where it should be - on perfect (coplanar), ungrouped stuff), but this may also have to do with entities previously bound up and released.
                        ~ Brooke
                        • brookefoxB
                          brookefox
                          Not to me, though it could have been clearer. 'They themselves' refers to the circles themselves, and that they were not exploded.
                          ~ Brooke
                          • Chris FullmerC
                            or via a pushpull that brings multiple circles up to intersect with a flat face.
                            • Wo3DanW
                              Wo3Dan
                              Sorry for the misunderstanding. What I meant to say is that this issue is "(ab-)normal" and reproducible behaviour in SU when creating a second smaller coplanar shape on a larger face (inside its perimeter) where the smaller perimeter touches the larger perimeter with just one single endpoint. I can't recall this happening when the smaller face is coplanar inside the larger face and NOT touching the larger perimeter.
                              The issue occures with newly created smaller faces in the same context or by exploding a coplanar component, as long as both faces share only one endpoint.
                              Intersect will not divide the larger overlapping face. Z-fighting remains on the smaller face.
                              The remedy is to delete the larger overlapping face and next trace a single edge of one of both perimeters. Both faces are now divided, no overlap.
                              Wo3Dan
                              • brookefoxB
                                brookefox
                                I'm still a little confused, but not significantly I think. In my cases there was no touching.
                                A circle (say 24 edges) inside a square face: they share 24 edges? or one curve? but seemingly more than one endpoint.
                                Well, thanks, and I appreciate that, even if the scrooge in me can't help but re-characterize it as: when confronted with buggy behavior, delete and redraw until satisfied. I will try to remember.
                                ~ Brooke
                                • Wo3DanW
                                  Wo3Dan
                                  @brookefox said:
                                  I can't recall this happeningwhen the smaller face is coplanar inside the larger face and NOT touching the larger perimeter.
                                  That's what I was looking for. Perimeters/outlines not touching. I can't recall the issue here. But I'm not saying it didn't happen in your model.
                                  The perimeters/outlines might not share a single endpoint, even with coplanar faces on top of eachother. Result: no z-fighting.(at least for me, so far)
                                  (One outline shared endpoint -> result: allways z-fighting (a definite bug))
                                  The remedyis .....
                                  I'll refrase: a remedy is.......
                                  I was just looking for clear reproducible situations for this bug to occure.
                                  Thereby explaining one situation.
                                  Wo3Dan
                                  • pyrolunaP
                                    pyroluna
                                    I get the same thing sometimes. Not only with circles. All kinds of shapes.
                                    My solution is usually to draw a line over one of the edges of the shape that needs to be cut out.. this usually solves the problem. if it doesn't, I draw a line from one side to the other, crossing the new face. sometimes this does solve the problem, sometimes it doesn't...
