    Smoothing
    renderpluginsextensions
    4 Posts 3 Posters 940 Views 3 Watching
    • arail1A
      arail1
      Not sure if this is the right thread for this but ...
      Smoothing questions:
      I work in modo which is a subd program so smoothing isn't an issue (see image on the right)
      But if I export out of modo as OBJ to go back into SketchUp for Vray or into Thea I have smoothing problems
      I can freeze the geometry in modo but at the expense of a much higher poly count and I still get a bit of faceting
      I can subdivide up to ridiculous levels and then freeze to overcome the faceting but that's just more of the same problem as above
      My questions -
      If I were to render the SketchUp image on the left in Vray, is there a way to smooth the object?
      And - I'm told there are smoothing controls in Thea but I can't find them - could someone tell me where they are?
      Thanks in advance for any info you might have
      • soloS
        In Thea, right click on the mesh you want smoothed, then select smoothing and choose degree.
        • arail1A
          arail1
          Thanks for the quick reply Solo
          I find the process of going back and forth between programs to be a real pain in the ...
            VfSU does not have tools to modify geometry - you need to use other SketchUp tools for that.
