    1.3k Posts 299 Posters 2.5m Views 297 Watching
    • fredo6F Offline
      @oxer said:
      Hi Fredo6,
      The plugin is fantastic, i'm modeling a XIV Century Church and it has a lot of organic details, your plugin will help me to finish it.
      I know that the plugin is a beta phase but i find a conflict with other plugin 'set.rb' requested for svg.rb (to import svg files to sketchup), it's a minor problem for me but i say it for inform to other users if they find that the plugin does not work and they have installed this plugin. (I work on Mac)
      Thanks for all your plugins!! πŸ‘
      Bye!
      Where can I find this plugin svg and set.rb? I'd like to see where the conflict comes from.
      • JClementsJ Offline
        JClements
        Fredo:
        Is there a possibility that coplanar surfaces would be created with Curviloft?
        • fredo6F Offline
          @jclements said:
          Fredo:
          Do you have an example?
            Joarek
            Simply amazing. Great work Fredo!
              arjunmax09
              WHOA........▐▀ β–„ β–ˆ β–Œ ▐ β–€ β–„ β–ˆβ–Œ ▐░ β–’ β–€ β–„ β–ˆβ–Œ ▐░ β–’ β–€ β–„ β–ˆβ–Œ ▐░ β–’ ..WHOAAAAAAAAAA!!!!β–‚β–ƒβ–…β–†β–‚β–ƒβ–…β–†β–‚β–ƒβ–…β–†β–‚β–ƒβ–…β–†β–‚β–ƒβ–…β–†β–‚β–ƒβ–…β–† FREDO.........YOU ARE ******* ٌ۩ﺴ ﺴ۩ٌ ٌ۩ﺴ ﺴ۩ٌ AMAZING..ٌ۩ﺴ ﺴ۩ٌ ٌ۩ﺴ ﺴ۩ٌ .PARDON MY LANGUAGE..BUT THIS PLUGIN IS REALLY OUT OF THE WORLD....HOLY______!!!!!!! MAN !!...You're not an ordinary human fredo....you have some calculators or electronic chips planted in your body...looking at your plugins ..it seems as if you're some cyborg or ....i don't know ..I don't have words to describe your talent...you rockβ–€ β–„ β–ˆ β–Œ ▐▀ β–„ β–ˆ β–Œ ▐ β–€ β–„ β–ˆβ–Œ ▐░ β–’ β–€ β–„ β–ˆβ–Œ ▐░ β–’ β–€ β–„ β–ˆβ–Œ ▐░ β–’ πŸ˜„
              when you fail at something....you haven't really failed...you've found one way the thing will not work out
                Jim
                @oxer said:
                Hi Fredo6,
                Bye!
                Fredo, it probably came from this thread:
                http://forums.sketchucation.com/viewtopic.php?f=180&t=13475&p=99818#p99542
                That was an old attempt at include rexml in the plugins folder, but rexml required a set.rb from the ruby language installation which is in direct conflict with the built-in Set class.
                  Yea, the Set class is one that does differ in SU from the native. Not exactly sure what the differences are - wish it was documented.
                  • fredo6F Offline
                    And using Sketchup::Set instead generates a lot of warning messages.
                    Anyway, I found a way to do without the Set class.
                      d12dozr
                      Karl, that's very neat, thanks for sharing πŸŽ‰
                      http://goo.gl/f7ooYh
                      • charly2008C Offline
                        charly2008
                        Hi to All,
                        three experiments with Curviloft and Perpendicular Square. Please show your ideas for what is possible with Curviloft. It's just fun to try out new ideas.
                        Karl
                          alangood
                          Hi Fredo,
                          Please excuse me with my newbie question.
                          I am trying to get your Curviloft plugin to work on my mac (OS X 10.6.3) in SU7. (Maybe it's working already, but I don't know how to access its functions.) I've only used SU about 100 hours over two years. But as I'm starting to design, manufacture and install concrete ping pong tables, SU is proving more and more useful!
                          I'm dying to create curved surfaces, so am grateful for what appears to be an ideal plugin.
                          I downloaded these plug ins: Driving Directions, Ruby Console, Curviloft, and others. I installed the .rb files on min Library/App Support/SU7. I restarted SU.
                          I saw that DD and RC added themselves to the top pull down menus. DD created a floating tool bar. But I couldn't find CL. I deleted all the plug ins from Library/App Support/SU7, and from Library/Internet PlugIns. I still see RC and DD in the pull down menus. I don't mind them there, but my goal is to start to use CL.
                          Do you have any suggestions? Next I'll try trashing SU and reinstalling it.
                          thanks,
                          Alan
                          Alan Good
                          President
                          hengetables.com
                          • fredo6F Offline
                            I don't think you need to reinstall SU.
                            Rather, check the footprint (2 files, 2 subfolders) which is indicated in the main post where you downloaded from (http://forums.sketchucation.com/viewtopic.php?f=323&t=28586#p248195).
                            If needed, unzip in a neutral directory and then move the two files and folders to the SU Plugins folder, which on Mac should normally be:
                            Macintosh HD/Library/Application Support/Google SketchUp 7/SketchUp/plugins
                            • fredo6F Offline
                              Although Sweep is not supported (i.e. loft along two rails), you can in some situations simulate it via the Skinning function.
                              Here the model posted previously by Diego, where you can generate the sweep shape by half.
                              • X Offline
                                xrok1
                                AWSOME! 😲
                                • ely862meE Offline
                                  ely862me
                                  I don't know what is going on in ur head...but what comes out is MAGIC. 😲
                                  Only if Waat would insert your editing method to his Subdivide and smooth tool. I think mixing SDS with this plugin will produce the most powerful plugin of sketchup .
                                  Thank you!
                                  Elisei (sketchupper)
                                  Come and See EliseiDesign
                                  • ken28875K Offline
                                    ken28875
                                    Wow!!!! 😲 😲 😲
                                    I have been busy and did not go to the forums lately, but what a surprise when I logged in today and saw that plugin.
                                    Genial! Merci beaucoup, Fredo.
                                    Best,
                                    _KN
                                    Follow Your Dreams.
                                      rachmatrf
                                      Fredo, I am a real newbie, as you can see, this is my first post.... I know you've produce many plugins. And those plugins are really helpful I believe. I just started to check this plugin section of the forum, and found that you're a master here. Thank you very much for bringing sketchup to a further stage as a modelling software... πŸ˜„
                                      I just downloaded your curviloft plugin and already installed it on my sketchup7 pro (windows7 platform). But, I got some real problem related to selection. I tried to follow the tutorial step by step. I tried the pre-selection mode. I selected the paths (two curves, I put one above the other), then click the "face icon" button. As we know, the curve is constructed by several connected lines (segment). And as I click the "face icon", just one segment can be selected, and I've no idea how to select the whole segment of the curve (or both curves).. I got the same problem also to apply the loft between two surfaces.. I just can select one segment.. 😒
                                      I can't even select the whole segment of the curve using manual selection mode... Forgive me if my problem is very basic thing... FYI, I Already tried the whole selection options... but nothing could worked it out. Do you know how to solve it? Please..., your help will be greatly appreciated..
                                      Thanks a lot.....
                                      • fredo6F Offline
                                        Rachmatrf,
                                        Can you post your model so that I get a better view of your situation.
                                        Also watch the videos to get some inspiration on how to select contours. Documentation is in my plan, but you can at least get some visual hints.
                                        • OxerO Offline
                                          Oxer
                                          Fredo wrote,
                                          Hi Fredo6, this is the plugin "svg.rb" for import svg files into sketchup, the plugin need other files included in the folder, the "set.rb" is the conflict file with Curviloft.
                                          svg.rb & set.rb, rexml folder, forwardable.rb
                                            rachmatrf
                                            Thank you very much for your quick reply, and forgive me for this late reply. I've just busy with the office and didn't notice if your reply was very quick.
                                            Well, I think it's not about the model. the problem is that I can't make the model using curviloft, because I can only select one segment of a curve. I can't select the whole curve/spline...
                                            I already watch the tutorial video on youtube. I just follow the given instructions. But, still I can't select the whole curve or the whole spline.
                                            Here I attach the situation of my "all curves selection disability"... I hope this will give you a better view of my problem.
                                            http://forums.sketchucation.com/download/file.php?id=50224
                                            Thanks before. And I do apologize if I just missed a basic setting to solve this...
                                            Any idea what's going on with this?
                                            • 65
                                            • 66
                                            • 4 / 66
