    Question: Render reduction as camera pans out
    28 Posts 7 Posters 3.1k Views 7 Watching
    • C
      Checker
      TIG - First off - again, I REALLY appreciate your immence patience! And thank you for taking the screen shot of my file ACTUALLY WORKING - it made my heart jump πŸ˜„
      Unfortunately I'm still getting no results, even though I just tested it on:
      *****Windows 7, running SU 7 (free)
      *****Windows XP, running SU 6 (Pro)
      *****Mac OSx 10.4.11, SU 6 (free)
      *****Mac OSx 10.4.11, SU 7 (free)
      I'm hoping I have an old / out of date plugin... is this the most recent version of the Matrix/Proximity plugin?
      #     Version ; 1.0  21/11/05	First release.
      #		1.6  20/12/05 Ditto - corrected...
      #   1.7  09/02/08 Glitch with Proximity Components directory finding
      #                 now fixed (Thanks to GreyHead)
      Edit 1:
      I see a comment in the Rubyscript itself that reads "require 'sketchup.rb'" And I looked in my plugin folder, and did not see a "sketchup.rb" - is this a file I need to find / download / place in the plugins folder? Is the "sketchup.rb" an essential file?
      EDIT 2:
      Only the Mac tests had a folder called "Proximity Components" in the components folder with all three "-" "~" "+" components .skp files in it - I just want to to be thorough - NONE of the testing it working, but just in case that part is essential, just thought I'd add that note.
      TIG is my hero, a true gentleman and scholar!
        One point at a time.
        Works on very similar set ups for me. No version or OS problems are known.
        v1.7 is the most recent.
        The require 'sketchup.rb' is the standard call to load the Sketchup code first - in case it hasn't already loaded. Don't worry about where the file is the system will find it - don't move or copy it either [actually it's in found in the ../Tools/ folder which auto-loads rubies as well as from ../Plugins/].
        Run it with the 'Ruby Console' open and see if you are getting error reports.
        I used your SKP just as it came with the +/~/- versions loaded - the way Proximity works is IF it needs them but it can't find them pre-loaded into your model it looks into the ../Components/Proximity Components/ folder to load from there... It is a good idea to have that folder made - even if it's left empty - not finding it when the code builds its data set might throw an exception. The guidance notes do say to make it πŸ˜•
        To recap: make the ../Components/Proximity Components/ folder, but leave it empty.
        Make sure you have the +/~/- versions in the skp.
        Run Proximity and enter the same values as I used [35m and 60m] and you should get results similar to mine ???
        πŸ€“
        • C
          Checker
          1. Okay, I have created the correct (but empty) folders for both versions 6 (free) and 7 (free)
          2. Still no effect
          3. With Ruby Console open - running the script - I got this message
          Error; #<NoMethodError; undefined method `+' for nil;NilClass>
          /Library/Application Support/Google SketchUp 6/SketchUp/Plugins/MatrixProximity.rb;550;in `proximity'
          /Library/Application Support/Google SketchUp 6/SketchUp/Plugins/MatrixProximity.rb;686
          /Library/Application Support/Google SketchUp 6/SketchUp/Plugins/MatrixProximity.rb;550;in `call'
          Does this mean anything to you? Or is this a generic error?
          I thank you again sir!
            OK we have some new info πŸ’­
            It's saying that it's having trouble finding a folder
            C:/Program Files/Google/Google SketchUp 6/Components/Proximity Components/
            (or 7 ?)
            I don't get those errors, so I can't see why you do... but...
            Here's v1.8 that MIGHT stop the error ???
            Try it and report backMatrixProximity.rb
            Check you have the folder correctly made...
            • C
              Checker
              Thank you for posting the revamped script! Half GREAT news! On Windows XP running SU6 (Pro) it WORKED!!!!!!
              IT WORKED on my WinXP SU6 (Pro) but NOT on my Mac SU6 (Free) or SU7 (Free)
              The Half BAD news, on my Mac (my primary computer) in both SU 6 (Free) and SU 7 (Free) I get a NEW error
              Error; #<TypeError; can't convert nil into String>
              /Library/Application Support/Google SketchUp 6/SketchUp/Plugins/MatrixProximity.rb;552;in `open'
              /Library/Application Support/Google SketchUp 6/SketchUp/Plugins/MatrixProximity.rb;552;in `entries'
              /Library/Application Support/Google SketchUp 6/SketchUp/Plugins/MatrixProximity.rb;552;in `proximity'
              /Library/Application Support/Google SketchUp 6/SketchUp/Plugins/MatrixProximity.rb;687
              /Library/Application Support/Google SketchUp 6/SketchUp/Plugins/MatrixProximity.rb;552;in `call'
              So, again, thank you for your patience (I owe you huge after this) - does this error (from my mac) tell you anything new?
              I've attached a screen shot of where I have my "Proximity Components" folder:
              1. Is there anything wrong (that you can tell) with this folder?
              2. Is this folder in the wrong place?
              ![The location of "Proximity Components" folder on my MAC](/uploads/imported_attachments/YEBw_Picture11.png "The location of "Proximity Components" folder on my MAC")
                Try this - the /Components/Proximity Components/ folder MUST now exist and if it doesn't you get an error message.MatrixProximity.rb
                • C
                  Checker
                  The folder structure is different on the MAC side. This is what it looks like:
                  "/Library/Application Support/Google SketchUp 6/Sketchup/Components/Proximity Components"
                  (note that the "Components" folder in not located in the Google Sketchup application folder itself)
                  Can you alter the .rb to work with both Mac and PC?
                    Why not make a folder within the Sketchup structure - the ../Components/ folder should be in the same relationship as the ../Plugins/ folder ??? To get it to work make an empty ../Components/ folder where it's looking and an empty ../Components/Proximity Componnets folder too... that'll fool it.
                    I think your Mac's folder structure is wrong... if you copy/paste these two lines into the Ruby Console they should return the same path ?
                    Sketchup.find_support_file("","Components") Sketchup.find_support_file("","Plugins")
                    • F
                      Freddie
                      Hey guys!
                      The folder path is different from PC to Mac.
                      I spoke to my coding friend, who took at TIG's code, and in addition to being really impressed with what you created, he was able to "Frankenstein" it and got it to work for both PC and Mac.
                      Now the script checks for platform first, and that effects where it looks for the "Proximity Components" folder
                      Tested on WinXP and MacOSX with πŸ‘
                      Hope this helps, and thank you for sharing!
                      Matrix Proximity for both PC and Mac
                      http://www.freddieart.com
                      • C
                        Checker
                        HOLY CRAP (the new one) WORKS FOR BOTH MY MAC AND PC!!!!
                        AWESOME! Thank you both Especially you TIG!!!
                        • 2 / 2
