    Horisontal AOV?
    37 Posts 6 Posters 4.0k Views 6 Watching
      Thanks for looking into this.
      I want to be able to make a tool where the AOV can be set in Horizontal, Vertical or Diagonal direction. So I need to be able to work this out.
        matteo
        the fov of a real camera is a function of the film frame dimensions. It is commonly related to a standard film with frames of 3624 mm - a 50 mm lens over a 3624 mm film frame is not the some of a 50 mm lens over a 60*60 mm film frame.
        i know, it's a bit confusing. all the new digital cameras have show an equivalent fov: that's because it would be too tricky to figure out the real angle of view, since there are somany formats. for more informations give a look to this on wikipedia: http://en.wikipedia.org/wiki/Image_sensor_format
        talking about the aov, it is not so difficult to find the horizontal angle when you have the vertical angle values and the aspect ratio.
        if you look at the first image, I extract half horizontal aov (1/2 Haov by now) + half vertical aov (1/2 Vaov by now) and unfold them.
        we have now quite a simple trigonometric problem. both triangles, blue and yellow, share the some radius: then 1/2 Haov tangent is equal to half screen length - and 1/2 Vaov is equal to 1/2 screen heigth. see figure two.
        now the formula is quite simple to obtain
        1/2 Haov = arctan [tan(1/2 Vaov)*(length/heigth)]
        let's suppose that you have a Vaov of 60° and a screen aspect ratio of 3/2, the Haov is equal to:
        Haov = 2* arctan [tan(60°/2)(3/2)] = 2 arctan [tan(30)1,5] = 2 arctan (0,577351,5) = 2 arctan (0,866025) = 2* 40,89339° =
        81,786789°
        i hope this can help you thom
        note: all angles are measured in degrees and not radiants or else.
        /matteo bignozzi
        hire me: http://www.nonsolo3d.it/ !
          It worked!
          The true test to if I understood this will be when I try to make functions that calculate between all directions of Vaov, Haov and Daov. At least I can go to bed now. 😄 👍
          • Chris FullmerC
            Oh good. have you got it all worked out then in Ruby Thom?
              def self.haov_from_vaov(vaov, ratio)
                  return (2 * Math.atan( Math.tan(vaov.degrees / 2) * ratio )).radians
              When (if) I get the other conversions worked out I'll post them back here in case anyone else should need them. (Plus, people with better math skills than me can verify if I did it right... 😳 )
                @thomthom said:
                Camera.fov returns the vertical AOV. But how do I get the horizontal or diagonal AOV?
                From Wiki I find this forumla: http://en.wikipedia.org/wiki/Angle_of_view
                http://upload.wikimedia.org/math/a/1/7/a172c67e0c1191e57fdc3e958f596628.png
                ( Math.atan == arctan, right?)
                Problem is, that assumes a film width and height... Which I don't have for the SU camera. So, how do you go about calculating the various AOV?
                After a year or so...
                I needed it - so here it is...
                ### acc is the active camera
                ### width is the screen width
                ### height is the screen height
                    fol=acc.focal_length
                    fovV=acc.fov
                ### fovV if the vertical fov in degrees
                    wid=width.to_f
                    hei=height.to_f
                    if acc.image_width != 0
                      wid=acc.image_width
                      if acc.aspect_ratio != 0
                        aro=acc.aspect_ratio
                      else
                        aro=wid/hei
                      end#if
                      hei=wid/aro
                    end#if
                    h=2*fol*Math;;tan(fovV.degrees/2)
                    w=h*wid/hei
                    fovH=(2*Math;;atan(w/(2*fol))).radians
                ### fovH is the horizontal fov in degrees
                  Ah! I'd forgotten about this! (yet another project in limbo. 😒 )
                  Thanks TIG - I'll play around with this when I get VE over with. 👍
                  • Chris FullmerC
                    Very odd, I also had to re-visit this to make similar code recently....are we all working on the same project?
                      I can't even remember exactly what it was any more.
                      I think it was in regard to making camera objects. But due to observers begin naughty it down-prioritised.
                      • DavidBoulderD
                        DavidBoulder
                        I did a quick little diagram, but its been a while since I have had to use any trig to write a formula.aov triangles.png
                        David Goldwasser
                        OpenStudio Developer
                        National Renewable Energy Laboratory
                          My seemingly convoluted code does return the correct horizontal fovH in degrees from the current fov [i.e. vertical] in degrees...
                          It uses the focal_length of the current camera to get this...
                          The results matches what appears [on a PC] with the code snippet Sketchup.send_action(10624) for the fovH value... so I am confident in its efficacy. 🤓
                          • Dan RathbunD
                            Dan Rathbun
                            On this subject.. FOV a registry question.
                            I noticed a setting in the registry Tools/FovDisplayMode
                            my setting is 0
                            What is this ?
                            I'm not here much anymore.
                            • Chris FullmerC
                              You can switch between horizontal and vertical in the dialog window that pops up with:
                              I wonder if that registry setting controls that? That would be nice to be able to switch the user back and forth from horizontal and vertical as needed maybe?
                              Otherwise, if its not that, I am out of ideas (for now).
                              • Chris FullmerC
                                Though FOV being horizontal or vertical seems to be associated with the model, not as an SU global setting. So it is probably not that then?
                                  The global default?
                                  • Chris FullmerC
                                    I suppose it could be, but if it is, the template file is overwriting it.
                                    • Dan RathbunD
                                      Dan Rathbun
                                      I changed the setting to 1, and see no difference, in the model or in any of the settings in that Camera dialog.
                                      Could be an orphan setting left over from some earlier version.
                                      Why is there no menu choice or constant string to bring up that dialog?? Is this a WIN only feature?
                                      • Chris FullmerC
                                        Yes, it seems to be Win only.
                                          Think it's a debug dialoge.
                                          But I do wonder why one can set vertical or horisontal AOV from the UI. And why camera.aspect_ratio isn't exposed in the UI.
                                            camera.fov always returns the 'vertical' fov. Many 3rd party apps you export to need the 'horizontal' fov - so fov = 30 degrees fovV >> ~52 degrees fovH...
                                            My method does return fovH in degrees correctly: it's worked out from the only available bits via the API - i.e. camera.fov [vertical, in degrees] & camera.focal_length & the screen's width [ view.vpwith] or the camera.image_width, if that's set [it's >0 if you are using a specific 'camera type']... which can then be combined to get it... 🤓
                                            You can get the camera.aspect_ratio as it's the ratio of the two fov's ??
                                            • 2 / 2
