    Horisontal AOV?
    37 Posts 6 Posters 4.0k Views 6 Watching
      @thomthom said:
      Camera.fov returns the vertical AOV. But how do I get the horizontal or diagonal AOV?
      From Wiki I find this forumla: http://en.wikipedia.org/wiki/Angle_of_view
      http://upload.wikimedia.org/math/a/1/7/a172c67e0c1191e57fdc3e958f596628.png
      ( Math.atan == arctan, right?)
      Problem is, that assumes a film width and height... Which I don't have for the SU camera. So, how do you go about calculating the various AOV?
      After a year or so...
      I needed it - so here it is...
      ### acc is the active camera
      ### width is the screen width
      ### height is the screen height
          fol=acc.focal_length
          fovV=acc.fov
      ### fovV if the vertical fov in degrees
          wid=width.to_f
          hei=height.to_f
          if acc.image_width != 0
            wid=acc.image_width
            if acc.aspect_ratio != 0
              aro=acc.aspect_ratio
            else
              aro=wid/hei
            end#if
            hei=wid/aro
          end#if
          h=2*fol*Math;;tan(fovV.degrees/2)
          w=h*wid/hei
          fovH=(2*Math;;atan(w/(2*fol))).radians
      ### fovH is the horizontal fov in degrees
        Ah! I'd forgotten about this! (yet another project in limbo. πŸ˜’ )
        Thanks TIG - I'll play around with this when I get VE over with. πŸ‘
        • Chris FullmerC
          Very odd, I also had to re-visit this to make similar code recently....are we all working on the same project?
            I can't even remember exactly what it was any more.
            I think it was in regard to making camera objects. But due to observers begin naughty it down-prioritised.
            • DavidBoulderD
              DavidBoulder
              I did a quick little diagram, but its been a while since I have had to use any trig to write a formula.aov triangles.png
              David Goldwasser
              OpenStudio Developer
              National Renewable Energy Laboratory
                My seemingly convoluted code does return the correct horizontal fovH in degrees from the current fov [i.e. vertical] in degrees...
                It uses the focal_length of the current camera to get this...
                The results matches what appears [on a PC] with the code snippet Sketchup.send_action(10624) for the fovH value... so I am confident in its efficacy. πŸ€“
                • Dan RathbunD
                  Dan Rathbun
                  On this subject.. FOV a registry question.
                  I noticed a setting in the registry Tools/FovDisplayMode
                  my setting is 0
                  What is this ?
                  I'm not here much anymore.
                  • Chris FullmerC
                    You can switch between horizontal and vertical in the dialog window that pops up with:
                    I wonder if that registry setting controls that? That would be nice to be able to switch the user back and forth from horizontal and vertical as needed maybe?
                    Otherwise, if its not that, I am out of ideas (for now).
                    • Chris FullmerC
                      Though FOV being horizontal or vertical seems to be associated with the model, not as an SU global setting. So it is probably not that then?
                        The global default?
                        • Chris FullmerC
                          I suppose it could be, but if it is, the template file is overwriting it.
                          • Dan RathbunD
                            Dan Rathbun
                            I changed the setting to 1, and see no difference, in the model or in any of the settings in that Camera dialog.
                            Could be an orphan setting left over from some earlier version.
                            Why is there no menu choice or constant string to bring up that dialog?? Is this a WIN only feature?
                            • Chris FullmerC
                              Yes, it seems to be Win only.
                                Think it's a debug dialoge.
                                But I do wonder why one can set vertical or horisontal AOV from the UI. And why camera.aspect_ratio isn't exposed in the UI.
                                  camera.fov always returns the 'vertical' fov. Many 3rd party apps you export to need the 'horizontal' fov - so fov = 30 degrees fovV >> ~52 degrees fovH...
                                  My method does return fovH in degrees correctly: it's worked out from the only available bits via the API - i.e. camera.fov [vertical, in degrees] & camera.focal_length & the screen's width [ view.vpwith] or the camera.image_width, if that's set [it's >0 if you are using a specific 'camera type']... which can then be combined to get it... πŸ€“
                                  You can get the camera.aspect_ratio as it's the ratio of the two fov's ??
                                    You do get camera.aspect_ratio via the ruby API. But I was wondering why it is not part of the Sketchup UI to control.
                                      The 'aspect_ratio' is both get-able and set-able using the camera methods... but it defaults to 0 and therefore the view's screen sizes come into play in setting other values...
                                      The complex interaction of fov/focal_length/image_width/etc will potentially change it - I was suggesting you could get the ratio from which setting you want to 'fix' and then set the aspect_ratio to suit from that ??
                                      • 2 / 2
