    Text , X , Y , Z import
    23 Posts 4 Posters 2.4k Views 4 Watching
    • K
      khallgren
      I cant get it to work properly , I only get this error message from the ruby console, And I get some errors when starting up SketchUp
      cptstxt
      Error: #<NameError: (eval):894: undefined local variable or method `cptstxt' for main:Object>
      (eval):894
      Your script says " require 'sketchup.rb' "
      Does that mean that I have to copy/paste the file from the "tools" folder and into the "plugin" folder?
      Regards
      Kristoffer
      • K
        khallgren
        Hi , I managed to fix it
        It was just missing the "#" on the 3 first lines
        The plugin works perfect 😄 Thank you so mutch for your help .
        Best regards'
        Kristoffer
          You need to 'select all' and copy/paste it - you must have missed something off ?
          The =begin...=end is the same as putting # at the start of each line - these are 'comments', not read by the Ruby interpreter. As there's only one line of 'comments' I could have omitted the =begin and =end lines completely and put a # at the start of the line of instructions - it'd been simpler! I just made the script from my own template that already has that format in it as multiple lines of comments/notes are often needed...
          Do not move sketchup.rb from the Tools folder. It loads automatically from there.
          It is good practice to add the line require 'sketchup.rb' at the start - most scripts need Sketchup's functions to run and will report an error if they load before it does; the ' require' waits for the specified file to load first... It's an instruction to the Ruby interpreter, not you !
          Glad it's working - did you notice that you can adjust the location of the text and leader length by playing with the vec=[1,1,1] numbers ?
          • K
            khallgren
            Hi , Thanks for the Text and Leader tip
            If I want to import Y, X ,Z rather than X,Y,Z
            Can I just switch around the
            x=data[1].to_f.mm
            y=data[2].to_f.mm
            z=data[3].to_f.mm
            pt=[x,y,z]
            To
            y=data[1].to_f.mm
            x=data[2].to_f.mm
            z=data[3].to_f.mm
            pt=[y,x,z]
            Best Regards
            Kristoffer
              Yes.
              The data[] order is the order typed in each line in the .dat file.
              The original code assumed the first was the 'text', then x, y and z values, as in the .dat file supplied.
              You can have the .dat file's entries in any order as long as the code's data[] values are adjusted accordingly - for example if the format were x,y,z,text then the values would all change around to suit with txt=data[3], and then x=data[0], y=data[1] and z=data[2]...
              The code I gave you was only a basis for .dat file reading - it's very flexible...
              PS: DON'T swap the point's values around use pt[x,y,z] always, no matter what the order they were read from the file ! 😒
              • K
                khallgren
                Hi again
                When I try to import a file Negative Co-ordinates I cet an error
                Is this an easy fix ?
                See the example file
                Best Regards
                Kristoffer
                Example_negative.txt
                  What's the error ? Please post examples...
                  The code x.to_f.mm should take the text 'string' of 'x' and make it into a 'number' [+/-] and then tell SUp it's in 'mm', not the default 'inches'?
                    Exactly what does the error say?
                    • K
                      khallgren
                      Hi , I tried to make my own file for testing and the negative co-ordinates workes fine, so the problem is not the negative co-ordinates. But when I export a file from my calculation program and try it import it I get an error, but the files sceems identical to me?
                      Here is the error i get
                      and the file is attached below
                      Error: #<Errno::ENOENT: C:/Programfiler/Google/Google SketchUp 7/Plugins/cptstxt.rb:14:in `readlines': No such file or directory - C:\Documents and Settings\krh\Skrivebord\BeregnetHøyderfile8.txt>
                      Best Regards
                      KRistoffer
                      • K
                        khallgren
                        I think I know what the problem is . Its the dicimales.... Its fine importing a file that says:
                        example: text,200.0,200.0,200.0
                        But when the file has a desimale value thats larger than 0 i get an error
                        example: text,200.5,200.5,200.5
                        Best regards
                        Kristoffer
                          Ah!
                          I know why that is - because you are Norwegian! Sketchup's ruby doesn't read files that has characters which isn't ASCII (A-Z). So our beloved æøå makes SU's file functions go belly up.
                          I struggled for ages with this some time ago. Found no good solution for that. You can work around be renaming your file.
                          Hilsen fra Bartehovedstaden! 😉
                            Best regards
                            Kristoffer
                            ?? With the same file you tried earlier? Or did you create a new test file with just ASCII chars in the file name & path?
                              As Thomthom said -
                              It's an 'unrelated' error to the code itself... you have 'special characters' in the filepath - this always causes Ruby / Sketchup problems [it can be trapped form but it's a bit complex for this simple example code!].
                              So please do it without the 'ø' etc in filename 'BeregnetHøyderfile8.txt' >>> 'BeregnetHoyderfile8.txt' ? it should then work !
                              • Didier BurD
                                Didier Bur
                                @Khallgren: I'm just about to modify my points cloud script to achieve what you want. Stay tuned....
                                DB
                                • K
                                  khallgren
                                  Hi , Oppps I missed that issue 😄
                                  Diddler Bur: It would be great if your point cloud importer had a "text" option
                                  Thanks for all your help 😄
                                  Berst regards "fra regn byen"
                                  Kristoffer
