    Text , X , Y , Z import
    23 Posts 4 Posters 2.4k Views 4 Watching
      And what unit is the data in?
      • K
        khallgren
        The unit is in millimeters.
        Regards Kristoffer
          Try this... copy/paste code into a file called cptstxt.rb in Plugins.
          =begin
          To run type 'cptstxt' into the Ruby Console...
          =end
          require 'sketchup.rb'
          def cptstxt()
            model=Sketchup.active_model
            ents=model.active_entities
            layers=model.layers
            lay=layers.add("CPTS")
            vec=[1,1,1]## change this to alter text-location/leader-length
            file=UI.openpanel("Select the DAT File...","*.dat")
            return nil if not file
            model.start_operation("cpointstxt")
            text=IO.readlines(file)
            0.upto(text.length-1) do |i|
              line=text[i]
              line.strip! if line
          	line.chomp! if line
              data=line.split(",")
              next if not data[3]
              txt=data[0]
              x=data[1].to_f.mm
              y=data[2].to_f.mm
              z=data[3].to_f.mm
              pt=[x,y,z]
              cp=ents.add_cpoint(pt)
              cp.layer=lay
              tx=ents.add_text(txt,pt,vec)
              tx.layer=lay
            end#do
            model.commit_operation
          • K
            khallgren
            I cant get it to work properly , I only get this error message from the ruby console, And I get some errors when starting up SketchUp
            cptstxt
            Error: #<NameError: (eval):894: undefined local variable or method `cptstxt' for main:Object>
            (eval):894
            Your script says " require 'sketchup.rb' "
            Does that mean that I have to copy/paste the file from the "tools" folder and into the "plugin" folder?
            Regards
            Kristoffer
            • K
              khallgren
              Hi , I managed to fix it
              It was just missing the "#" on the 3 first lines
              The plugin works perfect 😄 Thank you so mutch for your help .
              Best regards'
              Kristoffer
                You need to 'select all' and copy/paste it - you must have missed something off ?
                The =begin...=end is the same as putting # at the start of each line - these are 'comments', not read by the Ruby interpreter. As there's only one line of 'comments' I could have omitted the =begin and =end lines completely and put a # at the start of the line of instructions - it'd been simpler! I just made the script from my own template that already has that format in it as multiple lines of comments/notes are often needed...
                Do not move sketchup.rb from the Tools folder. It loads automatically from there.
                It is good practice to add the line require 'sketchup.rb' at the start - most scripts need Sketchup's functions to run and will report an error if they load before it does; the ' require' waits for the specified file to load first... It's an instruction to the Ruby interpreter, not you !
                Glad it's working - did you notice that you can adjust the location of the text and leader length by playing with the vec=[1,1,1] numbers ?
                • K
                  khallgren
                  Hi , Thanks for the Text and Leader tip
                  If I want to import Y, X ,Z rather than X,Y,Z
                  Can I just switch around the
                  x=data[1].to_f.mm
                  y=data[2].to_f.mm
                  z=data[3].to_f.mm
                  pt=[x,y,z]
                  To
                  y=data[1].to_f.mm
                  x=data[2].to_f.mm
                  z=data[3].to_f.mm
                  pt=[y,x,z]
                  Best Regards
                  Kristoffer
                    Yes.
                    The data[] order is the order typed in each line in the .dat file.
                    The original code assumed the first was the 'text', then x, y and z values, as in the .dat file supplied.
                    You can have the .dat file's entries in any order as long as the code's data[] values are adjusted accordingly - for example if the format were x,y,z,text then the values would all change around to suit with txt=data[3], and then x=data[0], y=data[1] and z=data[2]...
                    The code I gave you was only a basis for .dat file reading - it's very flexible...
                    PS: DON'T swap the point's values around use pt[x,y,z] always, no matter what the order they were read from the file ! 😒
                    • K
                      khallgren
                      Hi again
                      When I try to import a file Negative Co-ordinates I cet an error
                      Is this an easy fix ?
                      See the example file
                      Best Regards
                      Kristoffer
                      Example_negative.txt
                        What's the error ? Please post examples...
                        The code x.to_f.mm should take the text 'string' of 'x' and make it into a 'number' [+/-] and then tell SUp it's in 'mm', not the default 'inches'?
                          Exactly what does the error say?
                          • K
                            khallgren
                            Hi , I tried to make my own file for testing and the negative co-ordinates workes fine, so the problem is not the negative co-ordinates. But when I export a file from my calculation program and try it import it I get an error, but the files sceems identical to me?
                            Here is the error i get
                            and the file is attached below
                            Error: #<Errno::ENOENT: C:/Programfiler/Google/Google SketchUp 7/Plugins/cptstxt.rb:14:in `readlines': No such file or directory - C:\Documents and Settings\krh\Skrivebord\BeregnetHøyderfile8.txt>
                            Best Regards
                            KRistoffer
                            • K
                              khallgren
                              I think I know what the problem is . Its the dicimales.... Its fine importing a file that says:
                              example: text,200.0,200.0,200.0
                              But when the file has a desimale value thats larger than 0 i get an error
                              example: text,200.5,200.5,200.5
                              Best regards
                              Kristoffer
                                Ah!
                                I know why that is - because you are Norwegian! Sketchup's ruby doesn't read files that has characters which isn't ASCII (A-Z). So our beloved æøå makes SU's file functions go belly up.
                                I struggled for ages with this some time ago. Found no good solution for that. You can work around be renaming your file.
                                Hilsen fra Bartehovedstaden! 😉
                                  Best regards
                                  Kristoffer
                                  ?? With the same file you tried earlier? Or did you create a new test file with just ASCII chars in the file name & path?
                                    As Thomthom said -
                                    It's an 'unrelated' error to the code itself... you have 'special characters' in the filepath - this always causes Ruby / Sketchup problems [it can be trapped form but it's a bit complex for this simple example code!].
                                    So please do it without the 'ø' etc in filename 'BeregnetHøyderfile8.txt' >>> 'BeregnetHoyderfile8.txt' ? it should then work !
                                    • Didier BurD
                                      Didier Bur
                                      @Khallgren: I'm just about to modify my points cloud script to achieve what you want. Stay tuned....
                                      DB
                                      • K
                                        khallgren
                                        Hi , Oppps I missed that issue 😄
                                        Diddler Bur: It would be great if your point cloud importer had a "text" option
                                        Thanks for all your help 😄
                                        Berst regards "fra regn byen"
                                        Kristoffer
