    GML texturizer 2.0
    extensions
    33 Posts 18 Posters 23.6k Views 18 Watching
      tomislavm
      Thank You!
      • V Offline
        Vänsterbacken
        Me too is looking for the 2.0 version. Tried in a couple places to find it but I just get sent to the contact pages for two people of MSU.
        Does anyone know if this still available for download and if so where?
        Thanks,
        Stefan
          dedmin
          Some treasure here for Photoshop (not only) users
          http://graphics.cs.msu.ru/en/science/research/imageprocessing/matting
          • EdsonE Offline
            Edson
            i still have a copy of the installer. since it was distributed for free i am assuming there is no problem in posting it here for download.
            gmltexturizersetup.exe.zip
            http://www.mahfuz.arq.br
              dtrarch
              Hi All
              Here is the GML Undistorter. ☀
              GMLUndistorterSetup.zip
              Also GML GrowCut clipout plugin for PS and others.
              Similar to Fluid Mask and FREE.
              Really super for 2d face_me cutouts.
              dtr
              growcut_setup.zip
                dtrarch
                Good News 😍
                Just found
                GML Texturizer tutorial.(English)
                Bad News 💚
                Links to downloads are all in Russian.
                dtr
                How%20to%20cut%20around%20objects%20in%20Photoshop_Red3[2].pdf
                  danielito
                  I have installed 1.0 version. But nothing happens?
                  I have down loaded gmltexturizersetup.exe and I put it in the katalog: C:\Program\Google\Google SketchUp 7\Plugins. And install it in plugins katalog.
                  I have noticed that it missing an exe file to start the program in the directory.
                  how to find my 'GML Texturizer' toolbar button i Sketch Up 7.1?
                  Please guide me!
                  danielito12345@gmail.com
                    Hi Danielito,
                    When installing the plugin (with the exe file), it offers to install here:
                    Change that destination folder to SketchUp 7 (with the browse button on the right). It will then find the Plugins folder automatically.
                    If the toolbar is not activated automatically, find it under View > Toolbars (for some reason, the buttons do not appear for me).
                      danielito
                      tanks I did it like you said but the buttons do not appear for me to.
                      how do you start the plug in?
                      @gaieus said:
                      Hi Danielito,
                      [attachment=1:38jtuhen]<!-- ia1 -->GML1.png<!-- ia1 -->[/attachment:38jtuhen]
                        Hm. The buttons do not show up for me but also when I press the first button which should launch a window, everything loses focus (as if the window launched) but nothing can be seen.
                        Really weird.
                        Update; I also installed it under SU 6. There, I can see the buttons but the same problem happens when I try to launch it.
                          johnsenior1973
                          From my experience there seems to be some conflict between GML Text and some image editors. If I have SU and some image editors open at the same time then I have similar problems to Gaieus. The problems will persist even if the image editing program is closed. If I restart SU then the GML Text works fine.
                            tosiharuk
                            If an icon is changed into .png and a script is rewritten several lines, an icon will appear.
                              dtrarch
                              Hi ALL
                              Attached zip file has the info above, the edited GML Texturizer.rb and png files (in GML Texurizer folder.)
                              Works for me OK in SU 7.1 but not tested in other versions.
                              A really useful plugin and a small (very) payback.
                              Just install the original exe file and copy the edited folder and rb over the installed version.
                              FYI: version 2.0 was available as a shareware on the GML website but in Russian only.
                              This update is for GML Texturizer v1.0
                              dtr
                              GML TEXTURIZER FIX.zip
                                danielito
                                You are the best! It works!!!yeaaaaaaaa
                                @dtrarch said:
                                Hi ALL
                                dtr
                                  alhlhli
                                  Is it possible to modify the rb file
                                    To run on 2020
                                  Attachment is wrong
                                  Error Loading File GMLTexturizer.rb
                                  Error; #<LoadError; Exec format error>
                                  C;/Program Files/SketchUp/SketchUp 2020/Tools/RubyStdLib/fiddle.rb;47;in `initialize'
                                  C;/Program Files/SketchUp/SketchUp 2020/Tools/RubyStdLib/fiddle.rb;47;in `new'
                                  C;/Program Files/SketchUp/SketchUp 2020/Tools/RubyStdLib/fiddle.rb;47;in `dlopen'
                                  C;/Program Files/SketchUp/SketchUp 2020/Tools/RubyStdLib/Win32API.rb;25;in `initialize'
                                  C;/ProgramData/SketchUp/SketchUp 2020/SketchUp/Plugins/GMLTexturizer.rb;8;in `new'
                                  C;/ProgramData/SketchUp/SketchUp 2020/SketchUp/Plugins/GMLTexturizer.rb;8;in `<top (required)>'
                                    You should contact the author and see if they can help you with this ancient old plugin.
                                    From your error message it does look like you installed it into the wrong directory. Maybe it would help if you put it in the right one which should be User/App Data/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins. You shouldn't be installing extensions into the Program Data directory.
                                    • 2 / 2
