    Free PDF editor?
    13 Posts 6 Posters 1.1k Views 6 Watching
      Pg09
      This is not a SU question.
      I need to extend my portfolio with new pictures, CAD plans etc.
      Is there a free software that can do that?
      Any help is appreciated!!
      Thank you!
      • tridemT Offline
        tridem
        It's not very clear what you need...normally the pdf conversion is the last operation to do after having composed the page in other apps, there are some pdf virtual printers you can find in the web.
        Also OpenOffice suite has a good pdf exporter πŸ˜‰
        • honoluludesktopH Offline
          honoluludesktop
          You can use a image printer driver to pdf2(any image) and this to (any image)2pdf.
            I have also used PrimoPDF but eventually found PDFCreator a much better application. It can "print" (virtually of course, like PrimoPDF) not only into a pdf file but a bunch of image formats as well. However its main advantage is that it can compile several files into a single pdf file and those files do not even need to be the same file type so you can put a Word (or any text) document, some images, some other pdf's and all together into a single pdf file.
            And yes, of course, OpenOffice has a nice pdf export feature, too.
              Pg09
              Tridem sorry for the unclear phrasing.
              I have an old portfolio about 20 pages in PDF format.
              I have some new projects that i would like to add to the old portfolio.
              I can save the pdfs for sure, but i would like to merge the new pages with the old file...
                Pg09
                Thank you Honolulu and Gaieus i will check out both!
                  d12dozr
                  PDFillhas a good set of free tools, including splitting and merging PDFs. The UI sucks but the program works very well....just another option πŸ˜‰
                  http://goo.gl/f7ooYh
                    There is also a free program called PDFsam at http://www.pdfsam.org which allows you to split and merge PDFs quite easily!
                      Doe any of these allow one to create PDF forms?
                      In my Open Office it says something about forms but I have never been able to create any. 😳
                        I use Nuance which is lightweight and very user friendly. It allows forms to be filled out and saved but not created.
                        Invalid URL
                        (www.nuance.com)
                        oh and it's free which is a plus
                          Well, I would really like to create forms. Just once in a while so I don't think I should buy Adobe for a form in every half a year...
                            OK, so it will be OpenOffice.
                            πŸ˜‰
                            Damn... I should have looked earlier. Inserting a text field...
                            http://danilop.wordpress.com/2008/07/02/how-to-create-pdf-forms-with-openoffice/
                            And my ever first form:
                            πŸ˜‰
                            Form.pdf
                              You left out Bank account number ❓
