    Help Water fall
    10 Posts 5 Posters 592 Views 5 Watching
    • I Offline
      imabzeous
      Hello can any body help me in making a water fall? there is one method posted by EARTH MOVER i think but that's very difficult for me is there any other way of making it?
      • I Offline
        imabzeous
        CAN ANY ONE PLZZ 😒
        • Rich O BrienR Online
          Waterfall is a very generic term? They can be all shapes and sizes. Maybe post a pic of what you want to achieve?
          But Earthmover's example should do you as modelling a Waterfall isn't something that should be easy!
          Where exactly are you having difficulty so far? Maybe then members might be able to offer advice?
          • I Offline
            imabzeous
            well i am making a small water fall, actually its in my school design is in contour, its height is about 10', so i want to use this natural contour as a water fall and with it is senior section of school...
            • I Offline
              imabzeous
              and sorry for ma poor english
              • numbthumbN Offline
                numbthumb
                And you can take a look at Solo´s pool waterfall here http://forums.sketchucation.com/viewtopic.php?f=40&t=21835&p=183387#p183387
                Comfortably numb...
                  Would something simple like this be okay?
                  (Note that it always looks different when rendered)
                  Waterfall.skp
                  • I Offline
                    imabzeous
                    @Gaieus
                    waou thanks a lot yes its like that , but how you made the water?
                      It's not that difficult;
                      First I made a "patch" (for the Follow me) from two, tangent arcs:
                      Then I drew a circle at the bottom, scaled it about its centre to be a bit "flat" than used it as a face to do a follow me along the path.
                      Finally used FredoScale taper function to "flatten" the top part.
                      Of course, it could be improved further easily - this is just a "quick" example.
                      Ah, BTW if you are not planning to render it (and add some ore realistic water material), you can at least edit the material and add some transparency to it.
                      • brookefoxB Offline
                        brookefox
                        Nice look to the water, esp. reflections visible at top and distortions/refractions of the block wall through the water body, and also very magical forces applied which produce the narrowing of the flow.
                        ~ Brooke
