    SketchUp crashing on startup
    10 Posts 6 Posters 6.5k Views 6 Watching
    • F
      FilipAGuy
      Hi-llo guys. I was using skecthup 7.1.6087 for while, but now I have serious problem. After I run SU app it just show me bug splat report. I realy dont know why ? 😞 I running Windows 7 x64 Ultimate. Of course original one. My computer specs: ASUS G73JH-A1 (ASUS G73JH-TZ002Z)CPU: i7-720 QM, RAM 8GB DDR3 1333 MHz, HDD 1TB (2x 500GB 7200 rpm), Blu-ray Combo, ATI Radeon HD 5870 1GB
      ASUS G73JH-A1 (ASUS G73JH-TZ002Z) i7-720 QM, RAM 8GB DDR3 1333 MHz, HDD 1TB (2x 500GB 7200 rpm), Blu-ray Combo, ATI Radeon HD 5870 1GB
      • GaieusG
        Hi Filip,
        Just a quick test (if you can start SU at all); go to your Window menu (in SU) > Preferences > OpenGL settings and disable hardware acceleration.
        If this seems to fix your problems, you need to update your video card driver (or if it is not fully OpenGL compliant already, get a decent card).
        • F
          FilipAGuy
          @gaieus said:
          Hi Filip,
          Thats the problem. I cant start it at all 😞 I have last driver with which it was working before fine. Hm something went wrong πŸ˜• But thank you so much for such fast response πŸ˜‰
            Did you try downloading SU and performing a repair rather than an install. It might help?
            • F
              FilipAGuy
              Maybe this will help to identify my problem. In same time stoped working Vectoworks 2010, Photoshop CS5 and AutoCad 2011 😞 I cant even open VW and Photoshop and AutoCad show me this error: Unhandled Exception C0000005 (Acces Violation Reading 0x012c) at address 6F92AFFh Damn Im realy desperate 😞
                mac1
                Suggest you try to get back to a restore point where your system was working ok and then look at what changes were made at around the time the problem happened
                  mac1
                  Also according to this thread http://www.google.com/support/forum/p/sketchup/thread?tid=2e3e6d3534640db1&hl=en Su 7 and up does not have a repair capability
                  • Z
                    Zacchia
                    I had the same problem. Until SU 7.0 it worked well and with 7.1 it crashed after some seconds. It worked when disable hardware acceleration but working this way is not good. I use an ATI graphiccard and then i reseted the driver application to default. Since then it worked without any problems with hardware acceleration enabled. πŸ˜‰ I guess i had chanced something on anialiasing settings. On default it is "let the application decide". With this default settings it works.
                    • F
                      FilipAGuy
                      Hello guys. I had to reinstall all system. Now its working fine even with GPU aceleration.
                      • Chris FullmerC
                        A problem like that could be indicative of a hard drive that is on the verge of failing. You might consider backing up your hard drive.
