    Multi-threading inside SketchUp
    17 Posts 10 Posters 6.1k Views 10 Watching
      bcbas
      Has anybody else ever tried running some threads from a SketchUp Ruby script? I'm facing a strange behavior that can be easily reproduced by running the following command line in Ruby console:
      Thread.new { while(true); puts "Running..."; end; }
      You'll see some "Running..." messages printed to the console, but then it suddenly stops. One can argue that all subordinate threads are killed once the script finishes its execution. But then, try running the following code:
      Thread.list
      You'll see that the thread you've created by running the first ruby command still exists - and more interesting, SketchUp Ruby module says it's running! Again, one can argue that the thread IS REALLY running, just the console is not showing the messages anymore. But if we make our thread output to a file, we will see that the same thing happens.
      Even more interesting is to make a thread run, sleep for a second and observe it sleeps forever (it will never wake up again, even when the sleep time is reached):
      Thread.new { while(true); puts "Running..."; sleep(1); end; }
      So, what I'm wondering is why this happens? What are the multi-threading rules and concepts inside SketchUp?
        This is interesting topic to me. I asked around about multi-threading a couple of weeks ago: http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=16334 Didn't seem that there had been much success.
          tomasz
          There are no publicly known rules. I am not sure if even Scott from Google knows what is going on in the background.
          I have been using threads to open a Kerkythea, but it just has caused that SU has frozen after some time. When KT has been closed SU has been back on track.
          Tomasz
          Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
          • Tyler MillerT Offline
            Tyler Miller
            Hi bcbas -
            I've asked around a bit here and no one on the SketchUp dev team has attempted to use Ruby threads in our scripts (Sandbox, Dynamic Components, etc.). There are no "special" rules dictated by SketchUp, but SketchUp does own the main event loop. This could present some issues as there is the question of what happens to the thread when the script is "done" executing. From your description, the child thread sounds like it is being abandon, rather than killed, once the script is done executing. That could be bad on several levels.
            I wish we could be of more help. I think you're just going to have to experiment with it.
            -Tyler
            • tbdT Offline
              tbd
              my advice: don't do it, unless you want to spend lots of nights searching the reasons of crashes that have no explanations.
              also do not mix native threading with ruby threading - they don't like each other much.
              http://plugins.ro
                jhauswirth
                I have tried threads from a Ruby script in SU and found that the thread only gets executed when other Ruby commands are executed. Create your thread and then run some other Ruby commands (like a loop that prints out stuff) and you'll see that your thread will actually get executed. I don't think Ruby is actually creating a real thread, its just handling the time slices itself- which means you have to be giving the Ruby interpreter CPU time to do its business.
                  So after creating the threads, you have to start a loop that runs until your threads complete? And that means you can't do anything else in SU while the threads execute?
                    jhauswirth
                    That's what I found, but this solution wouldn't work for me because I needed the thread to always run.
                    • Dan RathbunD Offline
                      Dan Rathbun
                      NO... use Thread.join instead of a loop.
                      ` th1 = Thread.new {
                      code
                      th1.join`
                      Suggest always have an exit condition inside thread. Not like example in first post (ie, it's an endless loop.)
                      I'm not here much anymore.
                        MartinRinehart
                        @dan rathbun said:
                        ... Suggest ...
                        Dan,
                        I've played a lot with threads in SketchUp Ruby and have zero useful results. Could you post a small example that actually works?
                          cjthompson
                          This gets the best results for me so far. It's really slow, but it seems to be executing on a regular basis.
                          def testThread(times)
                          	timer = UI.start_timer(0,true){Sketchup.active_model.entities}
                          	thread = Thread.new{(0...times).each{|num| addBox};UI.stop_timer(timer)}
                          def addBox
                          	group = Sketchup.active_model.entities.add_group
                          	face = group.entities.add_face([0,0,0],[1,0,0],[1,1,0],[0,1,0])
                          	face.pushpull(-1)
                          	group.transformation = Geom;;Transformation.new([rand(500),rand(500),rand(500)])
                            Aidus
                            I need 64 bit support 😞
                            CPU: Intel Core i7 Extreme Edition 965
                            RAM: OCZ Gold DDR3 1600MHz 12Gb
                            Video: Asus Radeon HD4870 X2 2Gb
                            Mobo: Asus P6T Deluxe 1366 Intel X58
                              For what?
                                Dan Rathbun
                                This topic is about using Ruby "Green" threads, not native OS threads (which can run on several CPU cores.)
                                Ruby ver 2.0 "may" have native thread support, but current estimates of the work to be done, has 2.0 needing 17 years more work.
                                  cjthompson
                                  I thought 1.9 had basic support for native threads, but Sketchup can't connect to its hooks.
                                    Dan Rathbun
                                    Might be.. (I'd like to know for sure if you can post a link.)
                                    However Sketchup cannot currently load the 1.9.x interpreter DLL (... I've tried, and get an "entry point not found error." There seems to be some kind of difference between the 1.8.x and the 1.9.x DLLS, which I'd also like to know why this is. )
                                    Also, "basic support" I read as "beta" (and likely error prone.)
                                      Aidus
                                      I'm working with very large textures and I think su offten crashes because of that reason. It just can't work with very large files. You can operate inside sketchup but forget the export. Well that's just my guess. At home I have x64 bit os and there are no such problems - not so offten.
