OMG! fur plugin is AMAZING!
@fymoro said:
Please can you make a small tuto ?
It's really easy, Fred...
Like I wrote earlier... In my example, I used the English Ivy from Solo's Garden pack...
1.) I exploded the model and deleted everything except 2 ivy leaves.
2.) Make these two leaves into a component.
3.) Open the Fur setting dialog
4.) You'll need to play around with the settings. My input in the "Density" box was 1000
5.) In the "Make by ComponentInstance" you select the Ivy leaves from the list
6.) Select the surface where you want the leaves to be
7.) Click "Make Fur" button.Voila...!
Wow!! Massimo, very cool !!!
Thanks for the totu Fredy...
@massimo said:
5 min of work...and raw SU output. Really an amazing plugin
Mate when you look at images like that you wonder why SU cant have a better lighting environment, that would do us! Begone all renders!
Glad you like it.
Totally agree Richard!
@massimo: great modeling anyway
@richard: SU 2d export is my favorite too, especially combining 2-3 outputs in PP. You know this very well lol. Is it so difficult to write a plug-in that will just export one shadowed render mixed with another without shadows light from the opposite side, plus a z-map (via fog)... I suppose to do it manually is better.
The single models of ivy's leaf and grass's stem are from 3d warehouse, Michalis. I've used them in connection with the fur plugin to make the meadow and the climbing plant.
Yeah massimo, still a nice scene, not like this one. I just quick tested the plug-in, used the png from ivy generator. I'll paint something better, 3-4 leafs could be fine. What I have in mind is a fig tree (mediterranean), at last.
Ivy generator is fine but not for SU use.
heยดs got this Rod Stewart kinda feeling to me lol
Brilliant one.
Lucky Tiger
OMG!!!
Should be great for me...
As inspiration to take Make Fur in a totally different artistic direction, some of the sketches in this sketchbook make me think of Make Fur and Component Spray.
Here's the link to the whole sketchbook and a sample image from it is attached below.
As Jean says, Just Ideas...
Really nice mood in your render Gaieus, congrats...
Well, I only added the grass, ivy and background...
@olishea said:
...rendered with twilights "render all hidden layers"...
How do you do that, Oli?
I tried this way:
Hid the grass layer (was choking SU very much) and in Twilight I made sure that the grass layer was checked to render. But it did NOT render that layer.Then I made another scene where the grass layer was turned ON in SU but navigated in another scene where it was not. I made sure to set the scene containing the grass layer on, when in Twilight and also selected the grass layer to render but it does not render again.
A few too many plants showing up, so I thought I'd introduce something to keep them in check. (ants by museum maker)
Amazingly stable considering the amount of poly's.
Hey Dale very scary !!!
A dusky (or if you want, "Twilight") scene... Still vegetation, but the ants are also cool!
Still Kephalos' model, Majid's ivy and Oli's background.
