    OMG! fur plugin is AMAZING!
    168 Posts 44 Posters 71.6k Views 44 Watching
    • F Offline
      fymoro
      Yes Kim, It's great idea. This Plugin is awesome... 👍
      http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
      • RichardR Offline
        Richard
        @fymoro said:
        Here is a fake ivy...From far in a exterior scene It should work not ? And setup in 2 minutes... 👍
        Yep that will do the job and very well!!!
        [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
        • FrederikF Offline
          Frederik
          With this plug-in, I finally succeeded making my ivy pergola...
          I had never dreamed that I would be able to do it inside SU...
          I used two ivy leaves from the "English Ivy" in Solo's Garden pack 1, made it a component and used the fur plug-in to "distribute" it onto a frame... 😄
          Cheers
          Kim Frederik
          • F Offline
            fymoro
            Well done, thanks for the tips Kim... 👍
            Please can you make a small tuto ? 😒
            • massimoM Offline
              massimo Moderator
              5 min of work...and raw SU output. Really an amazing plugin 😄
              • FrederikF Offline
                Frederik
                It's really easy, Fred... 😄
                Like I wrote earlier... In my example, I used the English Ivy from Solo's Garden pack...
                1.) I exploded the model and deleted everything except 2 ivy leaves.
                2.) Make these two leaves into a component.
                3.) Open the Fur setting dialog
                4.) You'll need to play around with the settings. My input in the "Density" box was 1000
                5.) In the "Make by ComponentInstance" you select the Ivy leaves from the list
                6.) Select the surface where you want the leaves to be
                7.) Click "Make Fur" button.
                Voila...! 😄
                Cheers
                Kim Frederik
                • F Offline
                  fymoro
                  Wow!! Massimo, very cool !!!
                  Thanks for the totu Fredy... 👍
                  • RichardR Offline
                    Richard
                    Mate when you look at images like that you wonder why SU cant have a better lighting environment, that would do us! Begone all renders!
                    • massimoM Offline
                      massimo Moderator
                      Glad you like it. 😄
                      Totally agree Richard! 👍
                      • michaliszissiouM Offline
                        michaliszissiou
                        @massimo: great modeling anyway 👍
                        @richard: SU 2d export is my favorite too, especially combining 2-3 outputs in PP. You know this very well lol. Is it so difficult to write a plug-in that will just export one shadowed render mixed with another without shadows light from the opposite side, plus a z-map (via fog)... I suppose to do it manually is better. 😎
                        • massimoM Offline
                          massimo Moderator
                          The single models of ivy's leaf and grass's stem are from 3d warehouse, Michalis. I've used them in connection with the fur plugin to make the meadow and the climbing plant. 😉
                            michaliszissiou
                            Yeah massimo, still a nice scene, not like this one. I just quick tested the plug-in, used the png from ivy generator. I'll paint something better, 3-4 leafs could be fine. What I have in mind is a fig tree (mediterranean), at last.
                            Ivy generator is fine but not for SU use.
                              • N Offline
                                nektares
                                he´s got this Rod Stewart kinda feeling to me lol
                                lol
                                • soloS Offline
                                  Brilliant one.
                                  • F Offline
                                    flipya
                                    Lucky Tiger 🤣
                                    • F Offline
                                      fymoro
                                      OMG!!! 🤣 Should be great for me... 😳
                                        August
                                        As inspiration to take Make Fur in a totally different artistic direction, some of the sketches in this sketchbook make me think of Make Fur and Component Spray.
                                        Here's the link to the whole sketchbook and a sample image from it is attached below.
                                        As Jean says, Just Ideas...
                                        “An idea, like a ghost, must be spoken to a little before it will explain itself.”
                                        [floatr:v1mcbde2]-- Charles Dickens[/floatr:v1mcbde2]
                                          A very "rough" grass & ivy combo (Twilight Render until I came home from my "Corner Bar"...)
                                          Model by "Kephalos", ivy by Majid, background (#4) by Olishea (thanks all).
                                          • F Offline
                                            fymoro
                                            Really nice mood in your render Gaieus, congrats... 😉
                                            • 2 / 9
