    OMG! fur plugin is AMAZING!
    168 Posts 44 Posters 70.3k Views 44 Watching
    • michaliszissiouM Offline
      michaliszissiou
      @massimo: great modeling anyway 👍
      @richard: SU 2d export is my favorite too, especially combining 2-3 outputs in PP. You know this very well lol. Is it so difficult to write a plug-in that will just export one shadowed render mixed with another without shadows light from the opposite side, plus a z-map (via fog)... I suppose to do it manually is better. 😎
      • massimoM Offline
        massimo Moderator
        The single models of ivy's leaf and grass's stem are from 3d warehouse, Michalis. I've used them in connection with the fur plugin to make the meadow and the climbing plant. 😉
          michaliszissiou
          Yeah massimo, still a nice scene, not like this one. I just quick tested the plug-in, used the png from ivy generator. I'll paint something better, 3-4 leafs could be fine. What I have in mind is a fig tree (mediterranean), at last.
          Ivy generator is fine but not for SU use.
            • N Offline
              nektares
              he´s got this Rod Stewart kinda feeling to me lol
              lol
              • soloS Offline
                Brilliant one.
                • F Offline
                  flipya
                  Lucky Tiger 🤣
                  • F Offline
                    fymoro
                    OMG!!! 🤣 Should be great for me... 😳
                    http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
                      August
                      As inspiration to take Make Fur in a totally different artistic direction, some of the sketches in this sketchbook make me think of Make Fur and Component Spray.
                      Here's the link to the whole sketchbook and a sample image from it is attached below.
                      As Jean says, Just Ideas...
                      “An idea, like a ghost, must be spoken to a little before it will explain itself.”
                      [floatr:v1mcbde2]-- Charles Dickens[/floatr:v1mcbde2]
                        A very "rough" grass & ivy combo (Twilight Render until I came home from my "Corner Bar"...)
                        Model by "Kephalos", ivy by Majid, background (#4) by Olishea (thanks all).
                        • F Offline
                          fymoro
                          Really nice mood in your render Gaieus, congrats... 😉
                            Well, I only added the grass, ivy and background...
                              @olishea said:
                              ...rendered with twilights "render all hidden layers"...
                              How do you do that, Oli?
                              I tried this way:
                              Hid the grass layer (was choking SU very much) and in Twilight I made sure that the grass layer was checked to render. But it did NOT render that layer.
                              Then I made another scene where the grass layer was turned ON in SU but navigated in another scene where it was not. I made sure to set the scene containing the grass layer on, when in Twilight and also selected the grass layer to render but it does not render again.
                              • daleD Offline
                                dale
                                A few too many plants showing up, so I thought I'd introduce something to keep them in check. (ants by museum maker)
                                Amazingly stable considering the amount of poly's.
                                • F Offline
                                  fymoro
                                  Hey Dale very scary !!! 😄
                                    A dusky (or if you want, "Twilight") scene... Still vegetation, but the ants are also cool!
                                    Still Kephalos' model, Majid's ivy and Oli's background.
                                      Rico91
                                      very nice Plugin! 😛
                                      http://lh6.ggpht.com/_rMc47FEl0fA/S-hEjsJPg5I/AAAAAAAAB-c/pKLzFOjdoTY/R8_P.47.jpg
                                      [img:y90a5vdg]http://lh5.ggpht.com/_rMc47FEl0fA/Sro-DozMGPI/AAAAAAAABwU/zZsLbdpwWAs/forum_onderschrift_r3d_30pxh.jpg[/img:y90a5vdg] [url:y90a5vdg]http://www.R3Design.nl[/url:y90a5vdg]
                                        Rico91
                                        number 2 😄
                                        http://lh4.ggpht.com/_rMc47FEl0fA/S-hiucGiGNI/AAAAAAAAB-k/lBDp_IVwmrQ/R8_P.49.jpg
                                          Totally missed the possibility to "Make a Component instance"
                                          (a component must be first in the model for appear on the fur's list) 😳
                                          you can also replace selected by a component 😒
                                          http://forums.sketchucation.com/download/file.php?id=47832
                                            KarinaGM
                                            rico, very nice fury car.
                                            How did you achieve that soft look?
                                            My attempts look sharp
                                            **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminará perdiendo ambas"
                                            -Benjamín Franklin.**
                                            • 2 / 9
