    OMG! fur plugin is AMAZING!
    168 Posts 44 Posters 82.1k Views 44 Watching
    • RichardR
      Richard
      @fymoro said:
      Here is a fake ivy...From far in a exterior scene It should work not ? And setup in 2 minutes... ๐Ÿ‘
      Yep that will do the job and very well!!!
      BUILTBRAND.COM.AU
      • FrederikF
        Frederik
        With this plug-in, I finally succeeded making my ivy pergola...
        I had never dreamed that I would be able to do it inside SU...
        I used two ivy leaves from the "English Ivy" in Solo's Garden pack 1, made it a component and used the fur plug-in to "distribute" it onto a frame... ๐Ÿ˜„
        Cheers
        Kim Frederik
        • F
          fymoro
          Well done, thanks for the tips Kim... ๐Ÿ‘
          Please can you make a small tuto ? ๐Ÿ˜’
          http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
          • massimoM
            massimo Moderator
            5 min of work...and raw SU output. Really an amazing plugin ๐Ÿ˜„
            • FrederikF
              Frederik
              It's really easy, Fred... ๐Ÿ˜„
              Like I wrote earlier... In my example, I used the English Ivy from Solo's Garden pack...
              1.) I exploded the model and deleted everything except 2 ivy leaves.
              2.) Make these two leaves into a component.
              3.) Open the Fur setting dialog
              4.) You'll need to play around with the settings. My input in the "Density" box was 1000
              5.) In the "Make by ComponentInstance" you select the Ivy leaves from the list
              6.) Select the surface where you want the leaves to be
              7.) Click "Make Fur" button.
              Voila...! ๐Ÿ˜„
              Cheers
              Kim Frederik
              • F
                fymoro
                Wow!! Massimo, very cool !!!
                Thanks for the totu Fredy... ๐Ÿ‘
                • RichardR
                  Richard
                  Mate when you look at images like that you wonder why SU cant have a better lighting environment, that would do us! Begone all renders!
                  BUILTBRAND.COM.AU
                  • massimoM
                    massimo Moderator
                    Glad you like it. ๐Ÿ˜„
                    Totally agree Richard! ๐Ÿ‘
                    • michaliszissiouM
                      michaliszissiou
                      @massimo: great modeling anyway ๐Ÿ‘
                      @richard: SU 2d export is my favorite too, especially combining 2-3 outputs in PP. You know this very well lol. Is it so difficult to write a plug-in that will just export one shadowed render mixed with another without shadows light from the opposite side, plus a z-map (via fog)... I suppose to do it manually is better. ๐Ÿ˜Ž
                      • massimoM
                        massimo Moderator
                        The single models of ivy's leaf and grass's stem are from 3d warehouse, Michalis. I've used them in connection with the fur plugin to make the meadow and the climbing plant. ๐Ÿ˜‰
                        • michaliszissiouM
                          michaliszissiou
                          Yeah massimo, still a nice scene, not like this one. I just quick tested the plug-in, used the png from ivy generator. I'll paint something better, 3-4 leafs could be fine. What I have in mind is a fig tree (mediterranean), at last.
                          Ivy generator is fine but not for SU use.
                            ๐Ÿ˜„
                            • N
                              nektares
                              heยดs got this Rod Stewart kinda feeling to me lol
                              lol
                              • soloS
                                ๐Ÿคฃ
                                Brilliant one.
                                • F
                                  flipya
                                  Lucky Tiger ๐Ÿคฃ
                                  • F
                                    fymoro
                                    OMG!!! ๐Ÿคฃ Should be great for me... ๐Ÿ˜ณ
                                      August
                                      As inspiration to take Make Fur in a totally different artistic direction, some of the sketches in this sketchbook make me think of Make Fur and Component Spray.
                                      Here's the link to the whole sketchbook and a sample image from it is attached below.
                                      As Jean says, Just Ideas...
                                      โ€œAn idea, like a ghost, must be spoken to a little before it will explain itself.โ€
                                      [floatr:v1mcbde2]-- Charles Dickens[/floatr:v1mcbde2]
                                      • GaieusG
                                        A very "rough" grass & ivy combo (Twilight Render until I came home from my "Corner Bar"...)
                                        Model by "Kephalos", ivy by Majid, background (#4) by Olishea (thanks all).
                                        • F
                                          fymoro
                                          Really nice mood in your render Gaieus, congrats... ๐Ÿ˜‰
                                          • GaieusG
                                            Well, I only added the grass, ivy and background...
                                            ๐Ÿ˜‰
                                            • 2 / 9
