    SU2SLG Sketchup plugin for SmallLuxGPU v1.5beta 1 GPU+CPU
    extensions
    12 Posts 5 Posters 5.0k Views 5 Watching
    • E Offline
      exvion
      Result: 10min Nvidia GeForce 8600GT
      • jenujacobJ Offline
        jenujacob
        hi..
        thanks for the heads up.. is there a 64bit version for this yet?
          Khai
          hmm got it running but all I'm getting is a black screen.
          in the text window I'm getting the attached picture.
          running on Windows 7 64bit Home, as Admin. I've set SLG to run as admin but no effect. SLG is not in a UAC controlled folder plus UAC is off.
          • E Offline
            exvion
            Khai, do you open su2slg.skp or create own scene?
              Khai
              ah it only runs with the supplied scene?
              the black screen was with 2 planes and the default dude Sang...
              • E Offline
                exvion
                Khai, You have to add light source. Create material with name contain "light" ex. "leftlight", "toplight", "mylight1" and assign to mesh.
                • soloS Offline
                  What if you have a stone texture called 'lightgreymarble', will it become a light? 😲
                    Khai
                    doh. so not used to adding lights when rendering from SU.. you'd think after 10+ years in trueSpace I'd remember...
                    • E Offline
                      exvion
                      yes, It is temp solution.
                      • E Offline
                        exvion
                        New version SU2SLG 6 May 2010 for SLG 1.5beta3
                        • export textures
                        • export normals
                        • export sunlight and sunsky
                        • add setting editor (not all options work)
                        • and many other changes
                        http://www.luxrender.net/forum/viewtopic.php?f=34&t=3691&start=10#p38274
                        Test new UI of Setting Editor http://exvion.ru/ui-su2slg/
                          Masta Squidge
                          Is this rendering plugin no longer a viable option with SU8?
                          Or have I simply "installed" it incorrectly?
