    SU2SLG Sketchup plugin for SmallLuxGPU v1.5beta 1 GPU+CPU
    extensions
    12 Posts 5 Posters 4.9k Views 5 Watching
    • E Offline
      exvion
      Hi.
      SmallLuxGPU is GPU+CPU render.
      About SmallLuxGPU
      SU2SLG
      Features:
      • export ply-files, scn, cfg in "SLG folder/scenes/tmpscene"
      • after export you can start render with start.bat
      • default material type - 'matte'
      • if material name contains 'light', then material type = 'light'
      Unstable version. Tested on Windows XP. Not work on Mac.
      Test scene attached.
      Install.
      Extract SLG-v1.5beta1.zip to folder.
      Extract su2slg.zip. Copy su2slg.rb in folder "Plugins".
      Discussion about SU2SLG on Luxrender forum. Request registration.
      Any ideas you can post me exvion@gmail.com
      su2slg.zip
      SLG-v1.5beta1.zip
      • E Offline
        exvion
        Result: 10min Nvidia GeForce 8600GT
        • jenujacobJ Offline
          jenujacob
          hi..
          thanks for the heads up.. is there a 64bit version for this yet?
            Khai
            hmm got it running but all I'm getting is a black screen.
            in the text window I'm getting the attached picture.
            running on Windows 7 64bit Home, as Admin. I've set SLG to run as admin but no effect. SLG is not in a UAC controlled folder plus UAC is off.
            • E Offline
              exvion
              Khai, do you open su2slg.skp or create own scene?
                Khai
                ah it only runs with the supplied scene?
                the black screen was with 2 planes and the default dude Sang...
                • E Offline
                  exvion
                  Khai, You have to add light source. Create material with name contain "light" ex. "leftlight", "toplight", "mylight1" and assign to mesh.
                  • soloS Offline
                    What if you have a stone texture called 'lightgreymarble', will it become a light? 😲
                      Khai
                      doh. so not used to adding lights when rendering from SU.. you'd think after 10+ years in trueSpace I'd remember...
                      • E Offline
                        exvion
                        yes, It is temp solution.
                        • E Offline
                          exvion
                          New version SU2SLG 6 May 2010 for SLG 1.5beta3
                          • export textures
                          • export normals
                          • export sunlight and sunsky
                          • add setting editor (not all options work)
                          • and many other changes
                          (www.luxrender.net)
                          Test new UI of Setting Editor http://exvion.ru/ui-su2slg/
                            Masta Squidge
                            Is this rendering plugin no longer a viable option with SU8?
                            Or have I simply "installed" it incorrectly?
