    Vray not for me ?
    renderpluginsextensions
    31 Posts 10 Posters 6.5k Views 10 Watching
      arjunmax09
      @thomthom said:
      @arjunmax09 said:
      Can you give any tips here that you've discovered through your experience??pleeeeeeez, pleeeeeeez, pleeeeeeez, pleeeeeeez, pleeeeeeez?? πŸ˜„
      I've written down some topics for some blog posts I've been thinking of writing.
      so the work is in progress..you've noted down them on paper ....it's all in the mind...only the thing is to be executed yeah?? πŸ˜‰
      when you fail at something....you haven't really failed...you've found one way the thing will not work out
      • F
        frv
        Thomthom is actually a reliable source here on the forum. Thomthom for me was one of the reasons to get into Vray.
        Well, since I have to hang on to my license I wil follow his findings and who know's I might reinstall VfSU. Once I get the feeling things for VfSU have turned around.
        Hope to see your posts and tips on Vray ThomThom. I will surely read them.
        Francois
          Thank you.
          I can fully understand your frustration in regard to the last VfSU. It's been rough to say the least. Though personally I've avoided most of the big problems others have reported, I even started to use it at the office because it took care of some of the problems I had with the previous version. I guess the mileage depends on the model and one's usage of SU.
          What they have done is rewrite the whole VfSU plugin - so everything has been a massive change. But, from what I understand, the new structure of the app makes it much easier for them to add new features. After this patch they will be working on V-Ray for Rhino - basing it on VfSU. And any advances made during development of VfR can be transferred back to VfSU much easier than before. At least if I have understood it all correctly.
          It's good to see more VfSU users here at this forum. I find it much easier to use as one can embed images at the forum. And the people here are great help as there's always someone to tackle a challenge.
          As I've mentioned a little earlier, I have plans to write some topics on the use of VfSU. Some will be describing how I work with VfSU, and some will the posing questions on challenges I face. I hope to hear feedback from other VfSU users, or even V-Ray users of any variants. Even users of other render engines - in most cases concepts are transferable.
            steel.monkee
            Francois,
            My suggestion is to keep your VRay. If you hate it now just put it in the shelf in the mean time. I am sure those bugs can be fixed by ASGVIS. Btw, I am using an old VfSU and have not experienced crashing every 30 minutes. But I tell you that material panel can be a real pain.
            Learning VRay is not really a walk in the park. You have to learn through tutorials in the Web as its manual is practically useless. Put a little more time in it. I am sure users that are happy with the product have put hundreds if not thousands of hours testing it. It took me months before I was satisfied with my output.
            You say that you work faster with Maxwell but I think VRay users out there will agree with me that VRay is way way faster. Maybe your problem is you got comfortable with the Maxwell workflow that you think you can do the same with VfSU. VfSU is a totally different environment, and you must realize that if you want to learn VfSU.
            I can actually relate to your frustration because I have tested VfSU in 2008 and I was not really impressed with its output. Aside from being cranky at the time, concepts like VRay Sun, Sky and Camera are alien to me. And there's just to many buttons. So I just quit and focused on Kerkythea, which in my opinion is easier to learn.
            But I picked up VfSU a few months back as I had issues with the rendering time of the unbiased calculation. And the forums really helped a lot. Still learning it as I have hopes for the future of VRay.
            I hope you'd reconsider.
            Keith
            Kapag maiksi ang kumot, matutong mamaluktot.
              Which manual do you refer to?
              Note that the VfSU manual never has intended to be a completely manual of V-Ray.
              That's because Chaosgroup makes the V-Ray manual. http://www.spot3d.com/vray/help/150SP1/
              The VfSU manual is more to explain how the plugin works within SU and only briefly touches upon the concepts of V-Ray itself.
              On a slight sidenote I can recommend the book "V-Ray - The Complete Guide" - covers all aspects of V-Ray and are packed with images showing the results of each adjustable setting. Big mammoth size, but you don't need to read it all the way through, just look up the sections you want to learn more about.
              • StinkieS
                Stinkie
                For those who don't know: a downloadable pdf version of the book has been released. It's far cheaper than the book itself: €25 as opposed to €119.
                http://www.francescolegrenzi.com/blog/static.php?page=vray_guide_eng
                  What..? Doh!
                  I actually requested a digital copy of that book when I bought it. I do feel that considering the price that owners of the book should get the digital copy for free... πŸ˜•
                  • StinkieS
                    Stinkie
                    People who own the book can get the pfd at a reduced cost of €15, I believe.
                      steel.monkee
                      I meant the ASGVIS manual. Too bad I can't afford that Legrenzi manual. But I have had accumulated a collection of pdf tuts from the Web.
                        Look for the main V-Ray manual to learn V-Ray. V-Ray is V-Ray no matter what software it hosted by.
                        • N
                          nomeradona
                          funny. i have the same with other engines. because i have used vray and i could say comfortably that i started understanding it and be mindful on what others have been successful or not. now when i tried other render engines, i become frustrated and always compare them with vray. i guess its all about having that comfort level whenever you start another software.
                          I guess one thing that i have learned from this thread...
                          Shine and be creative with the software where you are comfortable and used to, and if you want to use another one try the trial version before you buy it.
                          • F
                            frv
                            yes, the demoversion.
                            But Vray remains very limited as a renderengine for SU. Simply because all you can render is one SU-file. With Maxwell you render as much as you like SU files combined in one MXS file out of Maxwell's Studio. This means you can can do so much more than is possible with VfSU. Regardless of how comfortable you are with either render app's. Especially with todays plugin's and their generated high polygon organically shaped objects.
                            Francois
                            • soloS
                              I think Vray is an awesome render engine, once you get it, you love it.
                              The problem is that it's not studio, that is the ONLY reason I cannot use it in my workflow any longer, I like Twilight and Podium and they also are SU restricted (rumor is they are going studio soon)
                              • FrederikF
                                Frederik
                                Don't know if Podium is going studio soon, but you can say that Twilight already have two studio options...
                                You can setup materials, lights etc. in TWR, export to XML and use Kerkythea or the new Thea Render as Render Studios, where you can adjust things, merge with other models etc...
                                What I find "funny" with all this is, that users seem to have prefered a "build-in" solution in the past...
                                I believe Podium was the first to intergrate with SU, then came VfSU and Twilight Render was released for about a year ago...
                                Reason for the "build-in" preference was that users didn't want all the hazzle with exporting, importing etc...
                                Now this seem to have changed again...
                                Cheers
                                Kim Frederik
                                  I still prefer built-in vs studio. But, since SU is stuck at 32bit, which works fine for SU itself, render engines really need to be 64bit these days to make use of modern hardware. And it's most likely because SU doesn't appear to be moving towards 64bit that people want to go studio to get rid of the 32bit restraints.
                                  • broomstickB
                                    broomstick
                                    @frv said:
                                    I startup SU frequently and startup got very slow with Vray installed. Up to the point I got frustrated with my regular workflow that does not requires rendering all the time.
                                    If you bought it in the last three months, you have bought the new version which is very buggy, as of now. In order for you to not waste your money, give Vray a chance once a new update comes out. I tell you this because I'm in the betatesting program of vray, and since the release numbered 1.48.66 the beta has now gone up to .83. In the meanwhile, a lot of problems have been addressed, and I think hopefully in the near future the upgrade will be released to paying customers too.
                                    Don't get too discouraged: if you have spent money on it you should at least try to make it work once! πŸ˜„
                                    P.s: The fact that you cannot re-sell the license is really a bugger, I admit that!
                                    • StinkieS
                                      Stinkie
                                      Yeah? Interesting.
                                      Yeah. It's a restriction that serves no purpose anymore, nowadays.
                                        Yea - the patch will sort out many issues.
                                        Ad for loading time - I also find VfSU takes longer than I can bother to wait every time I want to start a new SU instance. I often have one SU window open where I render, and a couple of other windows where I do not need SU loaded. I use my V-Ray Toys plugin the keeps VfSU disabled all the time - and let me load it on a per session basis.
                                        • soloS
                                          Frederik wrote:
                                          What I find "funny" with all this is, that users seem to have preferred a "build-in" solution in the past...
                                          I believe Podium was the first to integrate with SU, then came VfSU and Twilight Render was released for about a year ago...
                                          I guess it is a little funny, but unfortunately this change is not by choice or preference, but rather necessity. With a competitive market one needs to up ones game and that usually involves more elaborate modeling, high poly trees,vegetation, cars, etc.
                                          With Sketchup being so poly restrictive one needs to compile render scenes outside of SU and what better than a studio based render solution to do so.
                                          Personally I prefer the simplicity of an in-house render solution, but alas those days are gone, unless SU can attend to their vintage core and get it in-line with this millennium.
                                          • F
                                            frv
                                            According to most betatesters for SU, Google has set its mind on keeping SU as it is.
                                            In other words, SU will last just as long as it takes for the competition to catch up or unill the plugins have taken over the whole app.
                                            Highend rendering is rather normal these days, even for students in their second year. Sketchy edges and "profiles" are no longer meant for clients, just for indoor use within the office. SU has become just a modeller instead of the presentation tool it was. Therefore a Studio solution to render is these days much more acceptable and even needed.
                                            Francois
