    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 1.8m Views 329 Watching
      benjamin22
      Ok no worries.
      New Design.skp
      • Chris FullmerC Offline
        Hi Ben, I wrote the script with the intention that the bendy shape would be lying flat. If you just rotate the arc 90 degrees so its flat on the ground, then the bending will work as expected. Hope that helps!
          August
          Hi Ben,
          @benjamin22 said:
          ... The circular parts of the pipe are staying vertical rather than arraying around the arc, thus crushing the pipe and flattening it out!
          Thanks for uploading the sample file.
          Back in March, I showed an example of using Shape Bender with vertical curves, in this post, where I attached a picture that shows the target curve in the Green-Blue plane and not flat at all.
          In that sample, the vertical faces of the original shape stay vertical, they don't fan out on the convex curves and compress on the concave curves. That's what's happening to your pipe too.
          Shape Bender slices up the Original Object with vertical slices, according to how many segments there are in the Target Curve. One of the keys to predicting how it is going to work is that it will keep those slice faces vertical. It will rotate them in the Red-Green plane, but the slices will stay vertical.
          The result is that for vertical curves Shape Bender projects the shape onto the curve vertically, for horizontal curves, it fans out and compresses, which is typically what you expect.
          Also how can I get more segments into my circle to smooth it out?
          The number of segments in the Shape Bender Result is exactly the number of segments in your Target Curve. So you just need to draw your Target Curve with more segements. Whether you are using a Circle and cutting it or if you are starting with an Arc, when you select the tool, you can tell it the number of segments by typing a number and following it with an "s" to tell SU that the "units" for the number is segments.
          Sometimes you can get away without the "s" if you have not started drawing yet, but SU can quickly decide that you are drawing at which point any number with no units will be the radius in the default units. So I always put the "s" in. I'm already typing the number anyway.
          I hope this helps,
          August
          โ€œAn idea, like a ghost, must be spoken to a little before it will explain itself.โ€
          [floatr:v1mcbde2]-- Charles Dickens[/floatr:v1mcbde2]
          • X Offline
            xrok1
            rotated:
            on the first one i shortened the straight line to the same length as the pipe/tube.
            โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
              benjamin22
              Chris, August & xrok thanks a lot! you guys are legends, very helpful. Keep up the good work, I'm in my 3rd yr of architecture and always looking to do more and more complicated things on sketchup and its good to know there is this great site to go to when I get stuck!
              Cheers guys.
                August
                @benjamin22 said:
                ... you guys are legends ...
                I am honored and humbled that you put me in the same category as Chris and Xrox.
                August
                • X Offline
                  xrok1
                  August
                  ditto ๐Ÿ˜ณ
                    mbattler
                    I have down loaded the shape bender files but can not figure out how to get into the program to work. Does anyone know the steps?
                      Haven't you watched the movie on the same page as the download ?
                      http://forums.sketchucation.com/viewtopic.php?p=147395#p147395
                      • H Offline
                        huckrorick
                        I can't seem to get the ruby to work.
                        All I get is a line at the bottom that says "5%. End @ ? (1 of 5) Searching for objects to explode."
                        Nothing more happens.
                        Here is what I did:
                        I downloaded the zip file, unzipped, copied the folder and the 1kb ruby file to my plugin directory, started Sketchup, made a rectangular component, drew a line on one edge of the component, drew an arc, selected the component, started the plugin, selected the line, then the arc, go the line noted above and nothing else.
                        I attached a screen shot of what I get.
                        Can anyone suggest what I am doing wrong?
                        Thanks,
                        Huck
                          Move the cube on the green axis or anywhere on the positive xy space
                          Don't draw the line // red axis on the cube edge but on an empty space!
                          press the up arrow for select the Bender result form ๐Ÿ˜‰
                          If that don't work like this, there is a problem because I make that you say and that is working and that is instanteneous! ๐Ÿ˜„
                          Post your file!
                            Huckrorick
                            Have you installed ' progressbar.rb' as instructed on the page with the main download link ?
                              Looks like it's still in the process of running according to the bottom edge of his screen grab.
                              • H Offline
                                huckrorick
                                I tried all the suggestions:
                                1. I did as Pilou suggested.
                                2. I reinstalled progressbar.rb
                                3. It does appear that the program is still running considering the message at the bottom. However, I waited one half hour with no result. I thought the cube and arc would be a very simple test.
                                Is there some setting in Sketchup that could affect this?
                                Any other help?
                                I attached the screen shot of the new test.
                                I also am attaching the Sketchup file.
                                ShapeBenderProb.skp
                                  Well, it isn't a problem with your SKP file. I was able to run the plugin with no problem.
                                  Out of curiosity, is clf_shape_bender.rb is the the clf_shape_bender folder?
                                    August
                                    @august said:
                                    ... Shape Bender slices up the Original Object with vertical slices, according to how many segments there are in the Target Curve. One of the keys to predicting how it is going to work is that it will keep those slice faces vertical. It will rotate them in the Red-Green plane, but the slices will stay vertical. ...
                                    It's a little more complicated than that. The slices stay vertical, but it's not a straight linear projection, as I was implying.
                                    Based on the attached drawing, I think the Guide Line gets evenly divided into the number of segments in the Target Curve, so if the segments in the Target Curve are not evenly spaced, different segments in the Result will be stretched or compressed horizontally.
                                    In the drawing, a straight projection of the Target Curve onto the Guide line results in uneven spacing, but where the Source Object is divided is different, those places are evenly spaced along the length of the Guide line.
                                    I hope this helps,
                                    August
                                    Shape Bender with Vertical Curve
                                      August
                                      Here's a similar drawing for a horizontal (red-green plane) Target Curve.
                                        Do you by chance have component spray installed? That plugin seems to be breaking progressbar. If you have it installed, remove it and then restart SU and then try to run shape bender again.
                                          Maybe but I have both and no problem ๐Ÿ˜‰
                                          • H Offline
                                            huckrorick
                                            Yes, clf_shape_bender.rb is in the clf_shape_bender folder.d
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 63
                                            • 64
                                            • 16 / 64
