    How do you make individual components
    12 Posts 5 Posters 1.9k Views 5 Watching
      I see.
      The reason you're not getting any components are because you are not creating any.
      You must explicitly create a group or component and add the entities to it.
      You are doing it once in the script:
      group = entities.add_group
      http://code.google.com/apis/sketchup/docs/ourdoc/entities.html#add_group
      Here you are creating a group. You must do this for each object you want and add the entities to that group.
        I looked at the link Thomas but I didn't see the answer. If you want to make a component instead of a group, would you replace
        with
        component = entities.add_component
          To to create a component you first need to create a component definition and add the entities to it. Then place instances of that definitions entities.add_instance.
          I deliberately just explained groups as they are more straight forward. So that Brendon could see the concept of creating isolated geometry via Ruby.
            Thanks Thomas.
            I was just asking because I downloaded Dan's revision of box.rb and was wondering about changing it to make components instead of groups. I was thinking that it might be a tool to speed up some of my drawing processes but in thinking about it, I decided it will just replace one operation with another.
            Thanks again.
              Brendon5374
              Thank you Thomas and Dave for your replies. I was pretty sure there had to be more script for each piece (object). I'm not too familar with the syntax. And reading all this is daunting for me. Basically, I was just cannabalizing open files to suit my purpose; and beyond what I understood from doing that, I'm a bit lost when off the beaten track. I read the links you gave, and I tried, but came up lacking.
              I do not know what to put with say,
              ls=[] #left panel
              ls[0] = [0, depth, kick]
              ls[1] = [0, depth, height-thick]
              ls[2] = [0, thick, height-thick]
              ls[3] = [0, thick, kick]
              ls_base = entities.add_face ls
              ls_base.pushpull thick
              to turn it into a component. I pasted every line you gave, this way and that- front and back. But I couldn't figure it. Monkey see-monkey do, has it limits. ha ha.
                Doi
                My first post, so before anything else, hello πŸ˜„
                A bit of background on my component issue...
                I have a model that I have 'inherited' (approximately 130 buildings) that need to be cleaned up - basically lots of unconnected entities, and components with materials applied to the back face etc. I have thrown together a quick and dirty script to fix these issues (I was a little surprised at how easy it was to fix all that; ruby is very nice to use) πŸ˜‰
                Where things have gone a little screwy, is when I try to re-create the individual components.
                All my searching keeps pointing me back to the API documentation, which is fine, but I must not be interpreting it correctly, and am now just going round in circles?..
                The basic process I am trying to do is:
                temp_group = exploded_entities.add_group
                adjusted_component = temp_group.to_component
                The API docs state that calling the explode method on a ComponentInstancewill return an Entitiesobject. I read this as an Entities container (array?) filled with the individual Entityobjects that make up the building - the Entities container class is the only one with the add_group method!?
                Functionally I am able to access the exploded building as expected, as I said above the clean up steps work no worries, what I am finding is that the exploded_entities object is of type Array and as such throws a no method error when calling add_group?
                Here is the code in question:
                # output working component
                puts e.typename + "; " + compname
                if exploded_component = e.explode
                  puts "Exploded into; " + exploded_component.class.to_s
                  # parse component entities
                  exploded_component.each do |ce|
                    ...fixing stuff here
                  end #end do
                #re-create component
                temp_group =  exploded_component.add_group
                adj_component = temp_group.to_component
                puts "Recreated; " + adj_component.name
                puts "Total Faces; " + totalfaces.to_s + ";;Adjusted; " + adjusted.to_s
                Here is the console output:
                I know it'll be something really simple - it usually is πŸ˜•
                Thanks in advance
                  When you explode a ComponentInstance it returns an Array of Entities NOT an 'Entities' object.
                  There are several ways to get available 'entities'
                  Sketchup.active_model.entities
                  ALL model's entities
                  Sketchup.active_model.active_entities
                  accessible entities in this 'edit' session - if not edit it is == previous example
                  definition.entites
                  the entities in the definition
                  group.entities
                  the entities in the group.
                  The add_... methods apply to Entities.
                  So to add a group to the model use
                  new_group=Sketchup.active_model.entities.add_group()
                  then get that group's entities and add to them
                  new_group.entities.add_cpoint([1,2,3])
                  So in your case let's assume the grouped building is done something like this...
                  ### we have already somehow got an array of the required 'bits'...
                  group=Sketchup.active_model.entities.add_group(an_array_of_entities)
                  ### this method can lead to Bugsplats BUT with the recent SUp MR it seems more stable
                  ### now you have group in the model that holds the 'bits'...
                  inst=group.to_component
                  defn=inst.definition
                  defn.name="defn_name"
                  defn.decription="defn_desc"
                  ### you could then  erase the 'inst' and reinsert an new one if needed, or just transform! it to anew location etc...
                  πŸ€“
                    Doi
                    Hi TIG,
                    thanks for the clarification, it is nice to know I wasn't completely lost and was heading down the right track in one of my circular attempts - when I encountered an "All entities must have a common parent" error I went back to my initial attempt for my first post... πŸ˜‰
                    The current issue now seems to be that my exploded_entities need a reference to their 'parent' before being added to the group, yet I thought this is what add_group/to_component process was doing? From what I understand from the API, you must have a Component Instance first, then use it to create the Component Definition - then multiple Instances can be created under the Definition?
                    Using your example, my code becomes:
                    orig_entities = Sketchup.active_model.entities
                    ### Note; there is (correctly) no difference between calling .entities, or .active_entities here
                    temp_group =  orig_entities.add_group(exploded_component)
                    adj_definition = adj_component
                    adj_definition.name= orig_definition.name
                    adj_definition.description= orig_definition.description
                    The console throws:
                    Line 42 is the temp_group = orig_entities.add_group(exploded_component) method call.
                    If it helps, here is the entire script:
                    require 'sketchup.rb'
                    def parsecomponents
                    	# containers
                    	adjustedcomps = Sketchup;;Entities.new
                    	# data
                    	model = Sketchup.active_model
                    	orig_entities = model.entities
                    	layers = model.layers
                    	unattached_layer = layers.add "Unattached Elements" #anything that ends up here to be deleted...
                    	puts "Starting-----------------------------"
                    	orig_entities.each do |e|
                    		case e
                    			when Sketchup;;ComponentInstance
                    				totalfaces = 0
                    				adjusted = 0
                    				orig_definition = e.definition
                    				orig_transform = e.transformation
                    				puts e.typename + "; " + orig_definition.name
                    						# swap material if required
                    						if ce.is_a? Sketchup;;Face
                    							totalfaces += 1
                    							if !ce.material && ce.back_material
                    								ce.material= ce.back_material
                    								ce.back_material= nil
                    								adjusted += 1
                    							end #end if
                    						end #end if
                    					end #end do
                    					temp_group =  Sketchup.active_model.entities.add_group(exploded_component)
                    					puts "Recreated; " + adj_definition.name
                    				else
                    					UI.messagebox "Failed to Explode Component!"
                    			else
                    				# anything other than a component is not wanted...
                    				e.layer= unattached_layer
                    				puts e.typename + " moved to Unattached Layer!"
                    			end # end case
                    	end # end do
                    	puts
                    	puts "Completed----------------------"
                    end # end parsecomponents
                    if(file_loaded("swapmaterials02.rb"))
                    	menu = UI.menu("Plugins");
                    	menu.add_item("Parse Model") {parsecomponents}
                    Cheers Doi! πŸ’š
                      Try this...
                          def parsecomponents
                             # containers
                             ###adjustedcomps = Sketchup;;Entities.new ###NOT USED LATER ???
                             # data
                             # model.start_operation("parsecomponents") ### SEE BELOW...***
                             layers = model.layers ###???
                             unattached_layer = layers.add "Unattached Elements" #anything that ends up here to be deleted... ???
                             orig_entities.to_a.each do |e| ### NOTE HOW I MADE IT AN array FOR SAFETY
                                  if e.class == Sketchup;;ComponentInstance ### PROBABLY EASIER THAN class ???
                                      totalfaces = 0
                                      adjusted = 0
                                      if exploded_component = e.explode ### THIS IS AN array
                                               totalfaces += 1
                                                  adjusted += 1
                                               end #end if
                                            end #end if
                                         end #end do
                                         temp_group =  orig_entities.add_group(exploded_component) ### ADD it were it was
                                         adj_definition = adj_component.definition ##### POINT TO THE DEFN !!!!!
                                         # name=orig_definition.name ### USED below***
                                         adj_definition.name= orig_definition.name ##### THIS will add [1] to the end as the original exists
                                         ### YOU COULD remove the original definition too...
                                         ### neeeds start/commit ### ***
                                         # orig_definition.name = orig_definition.name+rand.to_s ### rename temporarily
                                         # orig_definition.entities.erase_entites(orig_definition.entities)
                                         # adj_definition.name = name
                                         ### the orig_defn is now emppty and will go from the browser after the 'commit' ***
                                         ### the new definition has it's name
                                      else
                                   else # anything other than a component is not wanted...
                                      ### alternatively ADD erase! HERE AND AVOID layer COMPLICATIONS
                                      # e.erase! if e.valid?
                                      # puts e.to_s+" ERASED."
                                      ### valid? traps if you delete an edge that had aface that's then not available to erase next!
                                   end # end IF ###
                             end # end do
                             puts
                             # model.commit_operation ###***
                      BUT to be honest I think you are making it overly complicated, as you can edit the definition's contents directly thus
                      def parsecomponents
                        model.start_operation("parsecomponents",true)
                        ### makes it undobale
                        ents = model.entities
                        ents.to_a.each{|e|
                            totalfaces = 0
                            adjusted = 0
                            defn = e.definition
                            begin
                              defn.entities.each{|e|
                                if e.class==Sketchup;;Face
                                  totalfaces += 1
                                  if !e.material && e.back_material
                                    e.material= e.back_material
                                    adjusted += 1
                                  end #end if
                                end #end if
                            rescue
                              UI.messagebox "Failed to Edit Component!"
                            end#begin
                          end # end IF ###
                        puts "Recreated; " + defn.name
                        puts "Total Faces; " + totalfaces.to_s + "; Adjusted; " + adjusted.to_s
                        Doi
                        Wow TIG,
                        thank you so much! Both edits work a treat πŸ˜„, but yes yours is definitely more succinct - I have always had issues with my code being a tad too verbose, and possibly missing the trees for the forest... 😳
                        After my previous post, I was thinking it did seem odd that I wasn't working directly with the definition, but I'm sure I would never have found it without the help β˜€
                        Thanks again - now onto the next tweak...
                        Cheers,
                        Doi!
