    Corner Cubby
    42 Posts 12 Posters 5.7k Views 12 Watching
    • Mike LuceyM
      Mike Lucey
      Karlheinz,
      You have hit the nail on the head ... 'disturbs the harmony'! I find that a lot of home workers, especially in open-plan living areas, often are under pressure to keep their office work space nice and tidy! Personally I am a slob when it comes to work space but with a Corner Cubby, I could just close the doors and no one would see the mess πŸ‘
      To extend / improve the storage space the shelves could run on both back panels. This may make things overcrowded but when the screen doors are open it should okay.
      Mike,
      When I have all the bits and pieces figured out I will post the model with a full parts and fittings list. It would be nice also if I could have the prototype put together. Dermot's headsup on Hafele http://www.hafele.com/ie/ was just the source I needed, it has all the fittings I think I need and some that I was not aware of πŸ‘
      The only fitting I need now is some kind of a spring loaded 'glider' / caster that would fix to the leading folding door. I think it probably would have to be spring loaded to cater for uneven floors. Maybe Hafele have something, will have to check fully.
      • G
        GoldenFrog
        Wow, Mike, that's a great idea! πŸ˜„
        Remember, great minds think alike, and fools never differ.
        • stefanqS
          stefanq
          I think this is what you need. Be careful with the hinges (170 degree or so) for full opening. Still. I'm not sure if the doors will stay closed. Hafele used to have this product in my country. The product is wing line 170 from hettich (manufacturer)
          • stefanqS
            stefanq
            Sorry about my last post. I didn't payed attention about how the doors will work, my mistake. So, forget about my recommendation, I'm feeling kind of dumb right now. Apologies! 😳
            • Mike LuceyM
              Mike Lucey
              No need for apologies Stefanq. I really appreciate your comments and suggestions.
              Mike
              • Mike LuceyM
                Mike Lucey
                I've found a little time to progress the Corner Cubby a little further. It's just a PDF outlining the idea and including the optional L Shelves that were suggested.
                Corner Cubby Presentation.pdf
                • G
                  GoldenFrog
                  I like it! Is this a real project? Is there space for you to sit in it when the door is closed?
                  • Mike LuceyM
                    Mike Lucey
                    No. The idea is to use the folding doors as a privscy screen while working.
                    • X
                      xrok1
                      corner chubby! with privacy screen! 🀣
                      i'm sorry but i had to 😳 . everytime i saw this thread title it made me laugh.
                      i hope it has internet connection. πŸ˜†
                      • G
                        GoldenFrog
                        Oh. Is it just a concept, or are you going to make it real?
                        • Mike LuceyM
                          Mike Lucey
                          @xrok1 said:
                          :roflmao:
                          Just the reaction to the name I was looking for Rocky πŸ˜‰ The name is suppose to be a 'fun' name for a Corner / Cupboard / Office which I hope it will turns out to be. Internet connection should be no problem at all provide the user has a service πŸ‘
                          But on a slightly more serious note, can you think of other things that might be incorporated OR the unit might transform into?
                          GF, Yes its a real project. I will be putting it together soon as I need one.
                          • G
                            GoldenFrog
                            Neat. I like the satisfaction of design-to-real-life. I've designed several projects in SU and made 'em in real life.
                            GF
                            • Mike LuceyM
                              Mike Lucey
                              I've had a little more time to progress the Corner Cubby. The frame members have been reduced to ex 75 x 19 and look better / lighter I think.
                              I have also eliminated the infill panel (white hardboard) on the two back panels. This raised a problem of pens etc rolling off the desktop and shelves. I am getting around this by fitting a 12mm lip to the rear of the desktop and shelves. Once I had this done I extended the lip 12mm below the surfaces also as this allowed to possible fixing space and reversing the desktop and shelves.
                              In the area of fabrication we will be using tongues and 'gorilla glue'. I have located the door hinges but can't find a suitable glider for the lead folding door. What I need is a fitting that fits under the leading edge (approx. 19mm - 3/4") and allows the door to glide on the floor surface. I have found a few possibilities but nothing that is ideal. On option would be Automatic Leveling Glides http://www.superior-components.com/automatic_leveling_glides.htm The ideal solution (I think) would be a side mounted spring loaded plastic ball roller! Any suggestions on if or where this might be obtained would be most welcome.
                              We have decided to make the framing in beech and am now starting on the cutting list.
                              • G
                                GoldenFrog
                                To be honest, I have hardly an idea where you might find it, but, have you tried McMaster-Carr?
                                Really taking shape there, I'm liking it!
                                • Mike LuceyM
                                  Mike Lucey
                                  Thanks FG for the link. I actually found a few options there πŸ‘
                                  • G
                                    GoldenFrog
                                    πŸ˜„
                                    • X
                                      xrok1
                                      i think it needs FUR! πŸ˜‰
                                      but seriously... looks good. is there room to change into your superman outfit in there? πŸ˜†
                                      • Mike LuceyM
                                        Mike Lucey
                                        Rocky, wait until you see the finished piece. You mention fur! Yep, that can be done πŸ˜„ All joking aside, it is possible to use whatever infill fabric the owner wants in the side and door panels. The idea behind this is the keep weight / cost down and offer the possibility to coordinate with the room's colour scheme πŸ‘
                                        • Mike LuceyM
                                          Mike Lucey
                                          Here you go Rocky ..... Corner Cubby with fur fabric infill panels πŸ˜„
                                          • G
                                            GoldenFrog
                                            πŸ˜† LOL.
                                            • 2 / 3
