    Corner Cubby
    42 Posts 12 Posters 4.6k Views 12 Watching
    • chrisglasierC Offline
      chrisglasier
      Mayoral Tardis?
      • RichardR Offline
        Richard
        Mate it is all darn tight in there! I can imagine some swearing when the knees hit!
        almost a shame the chair doesn't host somewhere within the fabric of the cabinet!
        BUILTBRAND.COM.AU
        • Mike LuceyM Offline
          Mike Lucey
          Thanks for the leads Dermot. I will check them out. I squeezed in a 500mm lead desktop and a 425mm 'elbow' layout area. So probably would be enough room. The mobile Storage unit can also offer extra layout space if rolled out, although it can remain under within the Cubby at still have access to the two drawers and file. Its cheating the brief a bit by having it as a roll out but as long as it can be tidied away that's okay.
          Chris, πŸ˜† 'Time And Relative Dimension In Space'! Would hope so πŸ‘
          Hi Richard, I would hope that there would not be too much knee banging at all πŸ˜„ I actually designed the unit around the Jules desk chair http://www.ikea.com/gb/en/catalog/products/S29856865 as it had a flat back. I wanted to be able to store a chair within the unit when closed and the Jules was the best I could find for this job.
          Talking about fabric! I propose to use some sort of semi transparent fabric on the folding doors and side panels (not back ones) as it will keep the doors lightweight and also allow some light / visibility when in the 'privacy position'.
            chrisglasier
            Will you be setting it to go back in time to show it to Richard?
              Mike Lucey
              πŸ˜† It's on its way!
              • stefanqS Offline
                stefanq
                Just a small suggestion, if I may....I would move those shelfs above the monitor.
                • N Offline
                  notareal
                  I see one possible issue with ergonomics; the left arm and the right arm will have different support.
                    Mike Lucey
                    Stefanq, Yes, good suggestion. It would look less 'busy'.
                    Notareal, As I have shown it there is no support for the left arm really. This suits me as I am right handed and just need the mouse area on the right. I can keep my left hand in my pocket πŸ˜‰ The design is totally reversible so could suit a left handed person also. The shelves mentioned by Stefanq can also be on either side as they will fit either way.
                    Thanks for all the feedback, much appreciated πŸ‘ This is something I miss over the past couple of years since semi retiring and working by myself.
                    • charly2008C Offline
                      charly2008
                      Hi Mike,
                      a beautiful design and a good idea. I would give up the sideboard, which disturbs the harmony. Instead, I would extend the two ends for a little storage space.
                      Karlheinz
                        Mike Lucey
                        Karlheinz,
                        You have hit the nail on the head ... 'disturbs the harmony'! I find that a lot of home workers, especially in open-plan living areas, often are under pressure to keep their office work space nice and tidy! Personally I am a slob when it comes to work space but with a Corner Cubby, I could just close the doors and no one would see the mess πŸ‘
                        To extend / improve the storage space the shelves could run on both back panels. This may make things overcrowded but when the screen doors are open it should okay.
                        Mike,
                        When I have all the bits and pieces figured out I will post the model with a full parts and fittings list. It would be nice also if I could have the prototype put together. Dermot's headsup on Hafele http://www.hafele.com/ie/ was just the source I needed, it has all the fittings I think I need and some that I was not aware of πŸ‘
                        The only fitting I need now is some kind of a spring loaded 'glider' / caster that would fix to the leading folding door. I think it probably would have to be spring loaded to cater for uneven floors. Maybe Hafele have something, will have to check fully.
                          GoldenFrog
                          Wow, Mike, that's a great idea! πŸ˜„
                          Remember, great minds think alike, and fools never differ.
                          • stefanqS Offline
                            stefanq
                            I think this is what you need. Be careful with the hinges (170 degree or so) for full opening. Still. I'm not sure if the doors will stay closed. Hafele used to have this product in my country. The product is wing line 170 from hettich (manufacturer)
                            • stefanqS Offline
                              stefanq
                              Sorry about my last post. I didn't payed attention about how the doors will work, my mistake. So, forget about my recommendation, I'm feeling kind of dumb right now. Apologies! 😳
                                Mike Lucey
                                No need for apologies Stefanq. I really appreciate your comments and suggestions.
                                Mike
                                  Mike Lucey
                                  I've found a little time to progress the Corner Cubby a little further. It's just a PDF outlining the idea and including the optional L Shelves that were suggested.
                                  Corner Cubby Presentation.pdf
                                    GoldenFrog
                                    I like it! Is this a real project? Is there space for you to sit in it when the door is closed?
                                      Mike Lucey
                                      No. The idea is to use the folding doors as a privscy screen while working.
                                      • X Offline
                                        xrok1
                                        corner chubby! with privacy screen! 🀣
                                        i'm sorry but i had to 😳 . everytime i saw this thread title it made me laugh.
                                        i hope it has internet connection. πŸ˜†
                                          GoldenFrog
                                          Oh. Is it just a concept, or are you going to make it real?
                                            Mike Lucey
                                            @xrok1 said:
                                            :roflmao:
                                            Just the reaction to the name I was looking for Rocky πŸ˜‰ The name is suppose to be a 'fun' name for a Corner / Cupboard / Office which I hope it will turns out to be. Internet connection should be no problem at all provide the user has a service πŸ‘
                                            But on a slightly more serious note, can you think of other things that might be incorporated OR the unit might transform into?
                                            GF, Yes its a real project. I will be putting it together soon as I need one.
                                            • 1 / 3
