    Corner Cubby
    42 Posts 12 Posters 4.4k Views 12 Watching
    • Mike LuceyM Offline
      Mike Lucey
      Thanks for the leads Dermot. I will check them out. I squeezed in a 500mm lead desktop and a 425mm 'elbow' layout area. So probably would be enough room. The mobile Storage unit can also offer extra layout space if rolled out, although it can remain under within the Cubby at still have access to the two drawers and file. Its cheating the brief a bit by having it as a roll out but as long as it can be tidied away that's okay.
      Chris, πŸ˜† 'Time And Relative Dimension In Space'! Would hope so πŸ‘
      Hi Richard, I would hope that there would not be too much knee banging at all πŸ˜„ I actually designed the unit around the Jules desk chair http://www.ikea.com/gb/en/catalog/products/S29856865 as it had a flat back. I wanted to be able to store a chair within the unit when closed and the Jules was the best I could find for this job.
      Talking about fabric! I propose to use some sort of semi transparent fabric on the folding doors and side panels (not back ones) as it will keep the doors lightweight and also allow some light / visibility when in the 'privacy position'.
      • chrisglasierC Offline
        chrisglasier
        Will you be setting it to go back in time to show it to Richard?
          Mike Lucey
          πŸ˜† It's on its way!
          • stefanqS Offline
            stefanq
            Just a small suggestion, if I may....I would move those shelfs above the monitor.
            • N Offline
              notareal
              I see one possible issue with ergonomics; the left arm and the right arm will have different support.
                Mike Lucey
                Stefanq, Yes, good suggestion. It would look less 'busy'.
                Notareal, As I have shown it there is no support for the left arm really. This suits me as I am right handed and just need the mouse area on the right. I can keep my left hand in my pocket πŸ˜‰ The design is totally reversible so could suit a left handed person also. The shelves mentioned by Stefanq can also be on either side as they will fit either way.
                Thanks for all the feedback, much appreciated πŸ‘ This is something I miss over the past couple of years since semi retiring and working by myself.
                • charly2008C Offline
                  charly2008
                  Hi Mike,
                  a beautiful design and a good idea. I would give up the sideboard, which disturbs the harmony. Instead, I would extend the two ends for a little storage space.
                  Karlheinz
                    Mike Lucey
                    Karlheinz,
                    You have hit the nail on the head ... 'disturbs the harmony'! I find that a lot of home workers, especially in open-plan living areas, often are under pressure to keep their office work space nice and tidy! Personally I am a slob when it comes to work space but with a Corner Cubby, I could just close the doors and no one would see the mess πŸ‘
                    To extend / improve the storage space the shelves could run on both back panels. This may make things overcrowded but when the screen doors are open it should okay.
                    Mike,
                    When I have all the bits and pieces figured out I will post the model with a full parts and fittings list. It would be nice also if I could have the prototype put together. Dermot's headsup on Hafele http://www.hafele.com/ie/ was just the source I needed, it has all the fittings I think I need and some that I was not aware of πŸ‘
                    The only fitting I need now is some kind of a spring loaded 'glider' / caster that would fix to the leading folding door. I think it probably would have to be spring loaded to cater for uneven floors. Maybe Hafele have something, will have to check fully.
                      GoldenFrog
                      Wow, Mike, that's a great idea! πŸ˜„
                      Remember, great minds think alike, and fools never differ.
                      • stefanqS Offline
                        stefanq
                        I think this is what you need. Be careful with the hinges (170 degree or so) for full opening. Still. I'm not sure if the doors will stay closed. Hafele used to have this product in my country. The product is wing line 170 from hettich (manufacturer)
                        • stefanqS Offline
                          stefanq
                          Sorry about my last post. I didn't payed attention about how the doors will work, my mistake. So, forget about my recommendation, I'm feeling kind of dumb right now. Apologies! 😳
                            Mike Lucey
                            No need for apologies Stefanq. I really appreciate your comments and suggestions.
                            Mike
                              Mike Lucey
                              I've found a little time to progress the Corner Cubby a little further. It's just a PDF outlining the idea and including the optional L Shelves that were suggested.
                              Corner Cubby Presentation.pdf
                                GoldenFrog
                                I like it! Is this a real project? Is there space for you to sit in it when the door is closed?
                                  Mike Lucey
                                  No. The idea is to use the folding doors as a privscy screen while working.
                                  • X Offline
                                    xrok1
                                    corner chubby! with privacy screen! 🀣
                                    i'm sorry but i had to 😳 . everytime i saw this thread title it made me laugh.
                                    i hope it has internet connection. πŸ˜†
                                      GoldenFrog
                                      Oh. Is it just a concept, or are you going to make it real?
                                        Mike Lucey
                                        @xrok1 said:
                                        :roflmao:
                                        Just the reaction to the name I was looking for Rocky πŸ˜‰ The name is suppose to be a 'fun' name for a Corner / Cupboard / Office which I hope it will turns out to be. Internet connection should be no problem at all provide the user has a service πŸ‘
                                        But on a slightly more serious note, can you think of other things that might be incorporated OR the unit might transform into?
                                        GF, Yes its a real project. I will be putting it together soon as I need one.
                                          GoldenFrog
                                          Neat. I like the satisfaction of design-to-real-life. I've designed several projects in SU and made 'em in real life.
                                          GF
                                            Mike Lucey
                                            I've had a little more time to progress the Corner Cubby. The frame members have been reduced to ex 75 x 19 and look better / lighter I think.
                                            I have also eliminated the infill panel (white hardboard) on the two back panels. This raised a problem of pens etc rolling off the desktop and shelves. I am getting around this by fitting a 12mm lip to the rear of the desktop and shelves. Once I had this done I extended the lip 12mm below the surfaces also as this allowed to possible fixing space and reversing the desktop and shelves.
                                            In the area of fabrication we will be using tongues and 'gorilla glue'. I have located the door hinges but can't find a suitable glider for the lead folding door. What I need is a fitting that fits under the leading edge (approx. 19mm - 3/4") and allows the door to glide on the floor surface. I have found a few possibilities but nothing that is ideal. On option would be Automatic Leveling Glides http://www.superior-components.com/automatic_leveling_glides.htm The ideal solution (I think) would be a side mounted spring loaded plastic ball roller! Any suggestions on if or where this might be obtained would be most welcome.
                                            We have decided to make the framing in beech and am now starting on the cutting list.
                                            • 1 / 3
