    Corner Cubby
    42 Posts 12 Posters 5.4k Views 12 Watching
    • Mike LuceyM Offline
      Mike Lucey
      @xrok1 said:
      :roflmao:
      corner chubby! with privacy screen! 🀣
      i'm sorry but i had to 😳 . everytime i saw this thread title it made me laugh.
      i hope it has internet connection. πŸ˜†
      Just the reaction to the name I was looking for Rocky πŸ˜‰ The name is suppose to be a 'fun' name for a Corner / Cupboard / Office which I hope it will turns out to be. Internet connection should be no problem at all provide the user has a service πŸ‘
      But on a slightly more serious note, can you think of other things that might be incorporated OR the unit might transform into?
      GF, Yes its a real project. I will be putting it together soon as I need one.
        GoldenFrog
        Neat. I like the satisfaction of design-to-real-life. I've designed several projects in SU and made 'em in real life.
        GF
        Remember, great minds think alike, and fools never differ.
          Mike Lucey
          I've had a little more time to progress the Corner Cubby. The frame members have been reduced to ex 75 x 19 and look better / lighter I think.
          I have also eliminated the infill panel (white hardboard) on the two back panels. This raised a problem of pens etc rolling off the desktop and shelves. I am getting around this by fitting a 12mm lip to the rear of the desktop and shelves. Once I had this done I extended the lip 12mm below the surfaces also as this allowed to possible fixing space and reversing the desktop and shelves.
          In the area of fabrication we will be using tongues and 'gorilla glue'. I have located the door hinges but can't find a suitable glider for the lead folding door. What I need is a fitting that fits under the leading edge (approx. 19mm - 3/4") and allows the door to glide on the floor surface. I have found a few possibilities but nothing that is ideal. On option would be Automatic Leveling Glides http://www.superior-components.com/automatic_leveling_glides.htm The ideal solution (I think) would be a side mounted spring loaded plastic ball roller! Any suggestions on if or where this might be obtained would be most welcome.
          We have decided to make the framing in beech and am now starting on the cutting list.
            GoldenFrog
            To be honest, I have hardly an idea where you might find it, but, have you tried McMaster-Carr?
            Really taking shape there, I'm liking it!
              Mike Lucey
              Thanks FG for the link. I actually found a few options there πŸ‘
                GoldenFrog
                πŸ˜„
                • X Offline
                  xrok1
                  i think it needs FUR! πŸ˜‰
                  but seriously... looks good. is there room to change into your superman outfit in there? πŸ˜†
                    Mike Lucey
                    Rocky, wait until you see the finished piece. You mention fur! Yep, that can be done πŸ˜„ All joking aside, it is possible to use whatever infill fabric the owner wants in the side and door panels. The idea behind this is the keep weight / cost down and offer the possibility to coordinate with the room's colour scheme πŸ‘
                      Mike Lucey
                      Here you go Rocky ..... Corner Cubby with fur fabric infill panels πŸ˜„
                        GoldenFrog
                        πŸ˜† LOL.
                        • X Offline
                          xrok1
                          ah, the 70's model. πŸ˜„
                            Mike Lucey
                            I visited a local timer merchants today with my friend Val and we hand selected 4 cubes of European Cherry. I think we got a good deal a €120. At least the production process has started πŸ˜„
                            I will post a few pics of the cutting and planing, seeing as there are a few following this topic.
                            • Bryan KB Offline
                              • honoluludesktopH Offline
                                honoluludesktop
                                Or this πŸ™‚
                                • dermotcollD Offline
                                  dermotcoll
                                  Mike
                                  Be prepared for major change in colour if you use cherry. The timber reacts incredibly quickly to UV light and darkens quite alot so if you are trying to tie the colour in with other pieces in the room you should be aware of it. Maybe use a UV resistant lacquer on the finish to prevent. Dont get me wrong - I love cherry, but it has a tendency to change colour rapidly. Can't wait to see the finished article.
                                  When you burn your arse - you gotta sit on the blisters!!
                                    Mike Lucey
                                    Thanks for that advise Dermot. I had read up on Cherry and was aware of the colour change in time. It was the best available timber so we went with it. That UV resistant lacquer coat you mention sounds like a good idea. Can you recommend a brand?
                                      dermotcoll
                                      I use Becker Acroma lacquers and stains for my work but they come in industrial size containers. You should be able to get a smaller jar for your project from some of the good painting and decorating business in Ennis or try the homevalue store, they should do it too.
                                        Mike Lucey
                                        Thanks Dermot. Val is cutting today but I am not allowed near him while is is working. He says I would only slow him up. I'll drop in later and buy him a couple of beers ...... only if he does not make a balls of my cherry πŸ˜†
                                          Mike Lucey
                                          Well, we are making some progress. Here are a couple of shots of Val's workshop and work in progress.
                                            dermotcoll
                                            Now thats what you call a workshop!!! If he is in that way of going he doesnt need me to tell him anything!
                                            • 2 / 3
