    GIMPplugin Resynthesizer
    extensions
    12 Posts 6 Posters 3.2k Views 6 Watching
    • mitcorbM Offline
      mitcorb
      Do any of you use GIMP?
      If so, have any of you added the Gimp plugin "Resynthesizer"?
      Alan Brito, on Blender 3d Architect reviewed it. Supposed to be a workalike to Photoshop Content Aware Rescale and Fill. He provided a link to the author's page(logarithmic.net/pfh/resynthesizer) and the zip file (resynthesizer .13b)
      I have attached a screenshot of the files list in the zipfile.
      The problem is I am not sure where to place the zip to extract the files so that they path to the right folders, and the standard instructions are not clear enough to me on the Gimp plugins FAQ. Not as easy as deploying plugins for Sketchup.
      By the way, Brito also reviewed TIG's Extrude Tools for Sketchup and showed one of Pilou's illustrations as an example for the tools.
      Any assistance you folks can provide would be appreciated.
      filelist of zip
      • EscapeArtistE Offline
        EscapeArtist
        x 2
        I'm interested as well.
          Download the zip file to your Desktop.
          Extract its folder/files into a similarly named folder...Capture.PNG Now open that and the contained 'GIMP 2.0' folder and copy/paste the two folders called 'lib' and 'share' into the programs files 'GIMP 2.0' folder, merging these folders/files with its existing contents...Capture2.PNG
          Worked OK for me... 🤓
          • mitcorbM Offline
            mitcorb
            Ok TIG,
            Thanks, I'll give it a shot.
            I was preparing a followup post horror story with more info on how my first attempt following the GIMP faq on plugin downloads failed when your reply showed up.
            This plugin doesn't just deploy to the plugin folder, but also sends something to the script folder. My attempt buried the files way down too deep in the Gimp application directory, and the command was not available in the Filters menu.
            • X Offline
              xrok1
              i'd like to hear a report on how well this works. preferably side by side comparison to pshop if anyone has both. 🤓
                miikka1978
                Thanks for explanation TIG.
                I get the plugin working but the results are nothing like it should be. The removed part is filled with sky in my case. I believe that there was some kind fix for this problem but I can't get it working (I can find any Heal selection- alternative in my filters). When they talk about Fix, they tell to:
                "Download the second file and copy it to C:\program files\gimp-2.0\share\gimp.0\scripts"
                But, I don't have this folder structure. Has anybody else had similar problems?
                http://img153.imageshack.us/img153/4843/gimp2s.jpg
                This is where they talk about Fix (Heal selection):
                http://newslily.com/blogs/96
                  Where are your Gimp 'scripts' ? they should be there ?
                  • X Offline
                    xrok1
                    mikka i'm not too familiar with gimp but it seems to me in your screeny that you have your whole image selected except for the piece on the road. i don't think thats a proper selection for the result you want.
                      miikka1978
                      Thanks again for help guys. Now I got one step further.
                      This is what I have done so far:
                      1.I uninstaled my Gimp 2.0
                      2.I downloaded Gimp (gimp-2.6.8-i686) and installed it on my computer
                      3.I downloaded (resynthesizer-for-Windows-0.13b) and copied (resynthesizer.exe) from extracted files (Program Files\GIMP-2.0\lib\gimp\2.0\plug-ins) to Gimp plugins folder (C:\Program Files (x86)\GIMP-2.0\lib\gimp\2.0\plug-ins)
                      4.I saved the script from the webpage (http://newslily.com/blogs/96)to(C:\Program Files (x86)\GIMP-2.0\share\gimp\2.0\scripts)
                      5.Now I find Heal selection option in filters but when I run it I get error message:
                      Does anybody else get this error message?
                      http://img263.imageshack.us/img263/4936/gimp2.jpg
                        miikka1978
                        I finally got it working. I just downloaded the script from (http://registry.gimp.org/node/15118)and replaced the script that I had downloaded from (http://newslily.com/blogs/96), and now it is working just fine.
                        • mitcorbM Offline
                          mitcorb
                          I have not been able to get back to this, yet. But thanks to all respondents.
                          • utilerU Offline
                            utiler
                            Hi guys, not sure what I'm doing wrong here with this resynthesizer plugin...
                            2012-02-09_1355.swf
                            For some reason it is not finding the adjacent content; rather the trees!!!
                            Just Curious...
