Dra a tensile tent
a want to draw a tenile tent with in de bottum a square en in the top a circle i tried it white a loft but it didn't get the tensile look that i want.
and with the soap skin plugin you only can get a tnsile between edges en not between 2 profiles what i wantdoes some one know how to do this
tank you
Try Extrude edges by rail by face by TIG
(just take same number of segments between rails, and between profilsor better Extrude edges by Loft by TIG
You also try2faces+path by kirill2008
that is nog what i mean more like a circus tent
@unknownuser said:Try Extrude edges by rail by face by TIG
it has to calculate the form by it self wihtout the have self the controle over it i wanna have a tensile liek structure only between 2 profiles but the problem is with the soup skin you only can get is between a closed line group
So the Extrud edges by Lath? always by Tig
that looks like what i mean how did you used that options by tag
OR with EEbyRails in two halves like this
ik only have lathe is that the same as lath becease i did not get it right with this tool and the one with two halves will not work becease you controle the tensile force in the material by the tho guide lines and they are not the naturel way of tensile force
So the Extrude edges by Lath? always by Tig
