    Dra a tensile tent
    8 Posts 3 Posters 1.0k Views 3 Watching
      meikkemij
      a want to draw a tenile tent with in de bottum a square en in the top a circle i tried it white a loft but it didn't get the tensile look that i want.
      and with the soap skin plugin you only can get a tnsile between edges en not between 2 profiles what i want
      does some one know how to do this
      tank you
        Try Extrude edges by rail by face by TIG
        (just take same number of segments between rails, and between profils
        http://forums.sketchucation.com/download/file.php?id=42810&t=1
        or better Extrude edges by Loft by TIG
        http://forums.sketchucation.com/download/file.php?id=44365&mode=view
        You also try2faces+path by kirill2008
          meikkemij
          that is nog what i mean more like a circus tent
            meikkemij
            it has to calculate the form by it self wihtout the have self the controle over it i wanna have a tensile liek structure only between 2 profiles but the problem is with the soup skin you only can get is between a closed line group
              meikkemij
              So the Extrud edges by Lath? always by Tig
              that looks like what i mean how did you used that options by tag
                  meikkemij
                  ik only have lathe is that the same as lath becease i did not get it right with this tool and the one with two halves will not work becease you controle the tensile force in the material by the tho guide lines and they are not the naturel way of tensile force
                    So the Extrude edges by Lath? always by Tig
