    Metal Spiral Stairs - how to do it?
    48 Posts 15 Posters 7.9k Views 15 Watching
      To repeat an earlier thread...
      When making spiral steps there are often rules/codes to adhere to..
      In the UK on narrower flights <1m [typically domestic or small commercial flights] you must have at least 50mm of plan-tread at the innermost part and the plan-tread on the centerline should be even for every step, and follow the rule 2R+G >=550mm <=700mm - where R is the Rise and G is the Going [plan-tread].
      If you draw this in plan it limits the relative angle of adjacent nosings and effectively sets a limit on the taper angle between them = ~15degrees depending on the configuration etc...
      For wider stairs you measure in from both edges [strings] 270mm and the same max/min pitch applies, 2R+G >=550mm <=700mm to the two locations
      Any landings shall be the same length as their width measured along their centerline.
      The minimum/maximum allowable Rise and Going varies with the building type too.
      'Private Stair'[one dwelling] R >=155mm <=220mm and G >=223mm <=300mm [vertical pitch is also limited to 42 degrees - usually trapped by 2R+G rules]
      'Institutional and Assembly Stair' R >=135mm <=180mm and G >=280mm <=340mm
      'Other Stair' R >=150mm <=190mm and G >=250mm <=320mm
      BUT AD-Part-M [accessible/disabled=all commercial/public building etc] R <= 170mm G >= 250mm
      So it's best to draw some test treads and place rotate a couple to see it they are right before committing to a complex 3D assembly...
      • EdsonE
        Edson
        do you know this mythical thread? 😉
        i wish i had access to it. according to ppb i do not have permission to access that page. i wonder how they expect me to participate more if i am not allowed to access certain threads.
        http://www.mahfuz.arq.br
        • jeff hammondJ
          randomly thought of this earlier today.. i drew it pretty darn fast though it could use a little fine tuning.
          shape bender by chris fullmer..
          • jeff hammondJ
            gotta admit.. this is one area where bonzai3D is far superior to sketchup.. parametric stair building!
            [flash=660,405:2pgaictc]http://www.youtube.com/v/_zgK8YYYoLo&hl=en_US&fs=1&rel=0&border=1[/flash:2pgaictc]
            • EdsonE
              Edson
              gotta admit.. this is one area where bonzai3D is far superior to sketchup. parametric stair building!
              jeff,
              i agree with it up to a point. it is true that out of the box sketchup surely lacks some tools other apps offer as a matter of fact. (i wonder if parametric tools are not on the list for v8.)
              on the other hand, i have not heard of any development of plugins for b3d. perhaps it does not need them but can an app be so perfect it foresees all possible users' needs?
              but at the same time as it is great to have such a great group of people creating plugins for sketchup, it is enough for one of them to lose interest in it or be too busy to keep them updated for a whole bunch of plugins to become unusable.
              • EdsonE
                Edson
                1001bits Stairs case 😉
                thanks, pilou, but if you read this thread with some attention you will notice that i posted a stair made with 1001bit tools, and even said it was the best solution i had found.
                  1001bits Stairs case 😉 (video)
                    ah yes 😳 this last was for the video 😉
                    • EdsonE
                      Edson
                      never mind. cheers. 😄
                      • charly2008C
                        charly2008
                        I have also tried the 1001 bit tools. For a standard spiral staircase, it's wonderful. You can quickly change the dimensions and gets in a very short time, a spiral staircase but always with the same design.
                        Sure that a commercial working architect will have a different view because time is money.
                        Will you have a custom design, then GROW along with a staircase component is the best choice. At the beginning you have to calculate and construct a little more but in the end you have an individual design.
                        Karl
                        Spiral stair.skp
                          charly
                          Here's my original Grow tutorial [GrowHelicalSteps2] updated for handrailsGrowHelicalSteps2.pngGrowHelicalSteps2.skp
                          • charly2008C
                            charly2008
                            Hi TIG,
                            thanks for this nice tutorial.
                            Charly
                            • 3 / 3
