⌛ Sale Ending | 30% Off Profile Builder 4 ends 30th September
Displacement noise / render error
renderpluginsextensions
7 Posts 2 Posters 868 Views 2 Watching
    agattila
    Hi Everyone,
    Please help, I have a problem with displacement renders.
    I'd like to render a standing seam metal wall panel with a displacement map. I've tried many different images for disp. map and different render settings but those strange spots and noisy lines were always there.
    http://img709.imageshack.us/img709/4487/displacementerror.th.jpg
    http://img695.imageshack.us/img695/4605/displacementerror2.th.jpg
    Sometimes the noisy area disappears when I change the viewpoint, but in most cases only the "position" of the noise changes.
    How can I get rid of those spots and lines?
    Thanks a lot!
    Attila
      I think higher rendering settings would do the trick. What setup do you have? Irradiance Map + Lightcache?
        agattila
        Yes, irradiance + light cache. I tried to change subdivs, samples but that noise is still there...
        This is my displacement map:
        http://img707.imageshack.us/img707/885/panel2f.th.png
        I've tried different images and different image sizes with the same result...
        Here is my visopt
        displacementtest.zip
          Can you post the sample file? Easier to investigate by looking at the actual model.
            agattila
            I hope everything is in the zip 😛
            disptest.zip
              Ah - should have picked up on this earlier.
              try decreasing Edge Length under Displacement. By default the displacement is view based.
                agattila
                Ok, so here is my correction for the first post:
                I've tried many different render settings, except this one... 😄
                Edge length 1px solved the problem.
                Thank you thomthom!!
