    Skp files into skb
    13 Posts 4 Posters 2.7k Views 4 Watching
      sketchup_fan
      Hi guys. Recently i opened a skb file with sketchup. When i clicked the skb file a window message was opened, and wrote to me if i want to open the skb file with a program from my computer. I chose sketchup and i did the mistake and checked the box in the left down corner that said 'always use the selected program to open this kind of file'. Now all the skb files can be opened with sketchup,
      and when i click on them the window message that said 'select a program from the list to open this file' doesn't appear any more.
      I want skp files to be skb again, and when i click on them i want the message window to appear to me again. Can you help me?
        Jim
        So what happens when you double-click a .skp? You should be able to change it back using the exact same process by double-clicking a .skp. Of course, I'm talking theoretically, and your actual results may vary. 😄
        Here is the official Microsoft instructions for changing the file association.
        http://support.microsoft.com/kb/307859
          sketchup_fan
          At this point when i double click a skp or skb file it automatically opens the model. Normally when i double click the skb file it should open the message window where it woull say with which program i want to open the skb file. This is what i'am trying to achieve. Is it any way to achieve it?
            Jim
            Yeah, you can remove the association:
            (This is for XP, is Vista different?)
            Open My Documents.
            Select Tools > Folder Options.
            Select File Types tab.
            Locate the .SKB in the list.
            Select it.
            Press the Delete button.
              Here .skb has been set to 'nil'...
              Now to open a .skb first rename it with .skp on the end and SUp will open it...
                Here's how to do it definitely [the 'old-fashioned' way]
                1. Click on Vista 'Start' button.
                2. Locate the 'Command Prompt' menu item (buried deep inside 'Accessories' under All Programs or appear on program access history).
                3. Right click on 'Command Prompt'.
                4. On the pop-up right click context menu, select “Run as Administrator”.
                In the Command Prompt type...
                assoc .skb
                You should now get the current setting listed - something like ".skb=SketchUp.Document".
                Reset it to 'nil' by typing thus...
                assoc .skb=.
                This will remove the current file association [where . is =nil]...
                Now a .skb file won't auto-open in SketchUp, but it will still offer SketchUp as a possible application to try and open it - just don't use it !
                Use cmd's like this carefully ❗
                  sketchup_fan
                  Tig, I tried the cmd approach as administrator but nothing happened.
                  In Vista control panel / associate files how do I proceed? I mean there is no
                  delete function as in XP.
                    If you type in
                    assoc .skb
                    what's returned ? - it should be ".skb=." after you've reset it ??
                    Then it won't open it SUp automatically ?
                      sketchup_fan
                      After i type in assoc .skb it shows me .skb=. ,then i type assoc .skb=. it shows me again .skb=. . Sketchup does not open automatically and still skb files open with sketchup. What am i doing wrong?
                      • X Offline
                        xrok1
                        if you right click a file you should get a open with option in the right click menu.
                        you can also go to default program in control panel and set it there. it does make no sence however that you want this, isn't SU the only program that will open these files anyway?
                          First...
                          assoc .skp
                          should return
                          .skp=SketchUp.Document
                          if not type
                          assoc .skp=SketchUp.Document
                          Next...
                          assoc .skb
                          should return
                          .skb=.
                          if not type in
                          assoc .skb=.
                          If you right-click on a skb file what do you get to open or open_with... ?
                          If you right-click on a skp file what do you get to open or open_with... ?
                          At the admin cmd prompt test this
                          ftype SketchUp.Document
                          it should return
                          SketchUp.Document="C:\Program Files\Google\Google SketchUp 7\SketchUp.exe" "%1"
                          if not type in
                          ftype SketchUp.Document="C:\Program Files\Google\Google SketchUp 7\SketchUp.exe" "%1"
                          Hope this helps...
                            sketchup_fan
                            I entered: assoc .skp
                            it returned: .skp=SketchUp.Document
                            then: assoc .skb
                            it returned: .skb=.
                            then i entered: ftype SketchUp.Document
                            and got:C:\Program Files\Google\Google SketchUp 7\SketchUp.exe" "%1"
                            Then the file had stayed the same and the sketchup application didn't open automatically
                              sketchup_fan
                              Never mind about the problem any more guys, i solved it. I did the simpliest thing, i restored the system to 9 o'clock yesterday before the changes happen, and it worked. Thank you very much for your help guys, and Tig thanks for the special help mate,
                              about the administrator options. 😄
