    ๐Ÿ›ฃ๏ธ Road Profile Builder | Generate roads, curbs and pavements easily Download
    [Plugin] Flattery papercraft tools
    91 Posts 41 Posters 87.0k Views 41 Watching
      Pumpkin Pirate
      Hello everyone!
      A while ago, I made a plugin for designing papercraft patterns. It allows you to unfold models into flat patterns, add tabs, and export them as SVGs. Just recently, I finally got around to polishing it up and putting it online. I call it Flattery, and you can get it here.[mod=:d3wg1npy]NOTE the latest version available from the PluginStore works in >= v2014 AND also earlier versions...
      .[/mod:d3wg1npy]http://sketchucation.com/pluginstore?pln=Flattery
      It's got three main tools for designing patterns.
      The Unfold tool unfolds models into flat patterns:
      http://www.pumpkinpirate.info/static/flattery/img/unfold.gif
      the Reunite Edges tool lets you adjust the layout of the patterns:
      http://www.pumpkinpirate.info/static/flattery/img/reunite.gif
      and the Add Tabs tool makes glue tabs:
      http://www.pumpkinpirate.info/static/flattery/img/tabs.gif
      It's also got an SVG export button so you can export your pattern to a program like Illustrator or Inkscape to color and print it.
      • EscapeArtistE Offline
        EscapeArtist
        Nice. This could also be used for simple sheet metal patterns. Thanks!
          Seems a true gem! ๐Ÿ˜ฒ ๐Ÿ˜Ž
            This is very cool! I know Jim has a plugin to unfold geometry but this seems to be a much more "advanced" tool!
            Then there is the Waybe plugin but then that's commercial.
            So this will definitely be a hit for many hobbyists and such! ๐Ÿ‘
            If you do not mind, I have "borrowed" some of your images for The Daily CatchUp. ๐Ÿ˜‰
            • X Offline
              xrok1
              very nice. it would be great if you could predefine the tab sizes or have all tabs after the first one be doubleclick to repeat size. also the option to have auto number tab and corresponding edge (one that appears red when creating tab). ๐Ÿ˜„
              โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
              • MALAISEM Offline
                MALAISE
                Thanks for this really usefull plugin. ๐Ÿ‘ ๐Ÿ‘ Pumpkin Pirate
                I like it.
                PAM
                La Connaissance n'a de valeur que partagรฉe
                  Pumpkin Pirate
                  Wow, no, I don't mind at all! In fact I'm thrilled!
                  A setting for the width of the double-click tabs seems like a pretty good idea. Not so sure about automatic numbering, though. It would be kind of difficult to get it into the SVG file in a reliable way, and I've generally found that it's hard to know the best order to glue tabs in until you've tried putting the model together a few times. I'll think about it though.
                  • X Offline
                    xrok1
                    thanks for considering it. with regards to the numbering, its not for the order of assembly, i was thinking more for organizing what goes where when gluing. (tab A glues to edge A) but you could glue tab Z to edge Z first it doesn't matter.
                    • utilerU Offline
                      utiler
                      Very cool mate; and very generous!!! ๐Ÿ‘
                      Welcome the the forum! ๐ŸŽ‰
                      Just Curious...
                        Not sure that I have patience to glue all the pieces ๐Ÿ’š
                        But very cool plug! ๐Ÿ˜Ž
                        • I Offline
                          ideas_arte
                          wonderful! very very very grateful to you.
                          This plugin has me very happy!
                          http://www.addemoticons.com/emoticon/animated/AddEmoticons04262.gif
                          Best wishes
                          su model
                          svg in Inkscape
                          export good, good editing
                          • Mike LuceyM Offline
                            Mike Lucey
                            Thanks Pumkin Pirate,
                            This plugin will prove to be very useful. BTW, I have made a donation and hope that others will do likewise to help you continue its development ๐Ÿ‘
                            Mike
                              Pumpkin Pirate
                              Mike
                              Wow, Thank you! I'm glad you found it useful. I'm going to do my best to keep it steadily improving.
                                tfdesign
                                Exactly my thoughts too! If bend radii could be specified too, as well as thickness (I haven't checked yet), this tool will be as powerful as the one in Solidworks!
                                A brilliant addition. Thanks very much!
                                Tom
                                • N Offline
                                  no8one
                                  Heyy !!
                                  plzz some help
                                  i downloaded this awesome plugin but when i put it in the plugins folder it's not shown in skitchup
                                  and i tired it on 2 computers
                                  plzz helpp ,,
                                  • Subsonic MikeS Offline
                                    Subsonic Mike
                                    I need help to.
                                    I do all that it says in the readme but it doesn't appear on sketchup
                                    Please help!
                                    Design Crash Learn
                                      @subsonic mike said:
                                      I need help to.
                                      Please help!
                                      Did you activate its Extension under Preferences ๐Ÿ˜•
                                        Subsonic Mike
                                        No, how?
                                        Design Crash Learn
                                        • mitcorbM Offline
                                          mitcorb
                                          In Sketchup: top line menu: Window>Preferences>Extensions Check box on plugin name.
                                            mozzie
                                            Did you copy the unzipped files?
                                            • 1 / 5
