    [Plugin] Elev45Shadows.rb
    43 Posts 14 Posters 31.7k Views 14 Watching
      arjunmax09
      @tig said:
      [qit's as if you have a sky-dome casting a shadow?
      Also see TT's recent comments on using it in v7 with a new skp+model_as_component, as it needs to change your location to get the right shadows - are you on free or pro ?
      πŸ˜•
      i'm using GSU 7.1.... and what are you referring to when asking "sky - dome casting a shadow"??
      elev experiment.skp
      when you fail at something....you haven't really failed...you've found one way the thing will not work out
        I said 'sky-dome' as a 'throw away remark' - one way to gets shadows cast like that - but that "couldn't be"...
        Here's your skp file back with the 45 degree shadows added - I had no problems doing it [v7 pro] - I added some extra details to show the effect better - like recesses and overhangs...
        I think it must be a free/pro thing ?elev experiment.skpelev experiment.png
          arjunmax09
          I think it must be a free/pro thing ?[attachment=1:2d4xr0rt]<!-- ia1 -->elev experiment.skp<!-- ia1 -->[/attachment:2d4xr0rt][attachment=0:2d4xr0rt]<!-- ia0 -->elev experiment.png<!-- ia0 -->[/attachment:2d4xr0rt]
          hmm... that's weird... when i opened your file.... the plugin worked fine... but when i created a new file and tried to do the shadow thing... the blackout still occurs... btw i'm using google sketchup pro 7.1
            Try changing/re-saving you Model Info > Location settings, then retry ?
              arjunmax09
              the location settings.. what change can i apply to them??
                Change the city, then back again ?
                What're you Location setting at the moment ?
                  arjunmax09
                  thanks tig... changed the setting to yugoslavia... earlier it was boulder, co usa workin fine now!! Thanks a lot
                  • O
                    orchard collie
                    Hi Guys
                    Have played with earlier versions of Shadows.rb (on Mac) and experienced the "blackout" problem. Found this post a few minutes ago, downloaded the latest version (thanks TIG). Set up model elevations as scene tabs and ran the script. Saved each scene with shadows on but it seems that the 45 degree shadows don't change direction for each elevation - the shadow direction is constant regardless of whether I save/update each scene with shadow settings on or off.
                    Any ideas what I'm doing wrong?
                    Cheers from Darwin Australia
                    Orch
                      @orchard collie said:
                      Hi Guys
                      Orch
                      Unfortunately with v7 you can't have multiple locations in the same model [Google-Earth compliance?] - but this tool has to reset the model's location to get the shadows to work right and it was developed for v5/6 !
                      What you have to do it in v7 is import the model into another empty elev-skp [as a component its location settings are forgotten], then set your required elevation scene tab and then the 45 shadows in that elev-skp - the model's location will adjust in that elev-skp [save to a scene-tab/style etc to 'freeze' the settings]. To make other elevations with different shadow directions [and therefore 'locations'] you can make copies of your elev-skp [with the same model inserted] and change the view/elevation and shadows to suit, in each one. If later on you change the model then its inserted version in these new elev-skp's will not change UNLESS you 'reload' it from the Component Browser then it'll then update but automatically keep the desired shadows...
                      πŸ’­
                      • O
                        orchard collie
                        Thanks TIG at least I know why I can't do it!
                        Many thanks
                        Orch
                          arjunmax09
                          I'm having a problem using Elev45shadows and vray for sketchup 1.5.30 combined....I need to change the location of my model to any city but not boulder to get 45 shadows io.....but vray doesn't accept this..It only remembers the default location settings that is of boulder colorado...what should i do to fix this......I'm using Sketchup Pro 7.1
                            I've never had problems with this in VfSU 1.05.30. I always worked with it where the location where set to Trondheim, Norway.
                            What do you mean it doesn't "accept" it?
                              arjunmax09
                              it means that vray uses the default settings i.e. boulder colorado......if i change my north axis by going to model info.....it also doesn't support the north.....for example if i rotated the north angle by 30 degrees ....vray will not know that the north direction has been rotated by 30 degrees
                                Not even if you reload the model?
                                  arjunmax09
                                  yes the problem persists even if i reload the model...have you ever experienced it i mean with boulder, colorado??
                                    martinez001
                                    TIG,
                                    I am trying to flip my shadows. I have the Ruby Console open and type in the values that you state and run the plug-in and nothing happens. Am I not running the ruby console properly?
                                      @martinez001 said:
                                      TIG,
                                      Open the Ruby Console and type $e45s=0 then press <enter> this changes the angle.
                                      And using $e45s=1 changes it back... πŸ˜•
                                      • pbacotP
                                        @martinez001 said:
                                        TIG,
                                        You can also flip shadows with the "enter North angle" tool under the Solar North tool palette--after using this EXCELLENT plugin. We always fudge on the north elevations (northern hemisphere) for presentations sake but I assume if the west elevation is wrong I'll hear from my clients!
                                        • C
                                          CGulland
                                          Anyone know if Elev45Shadows.rb will work in SU 2013? Or can direct me to an alternative plugin for creating 45 degree shadows for architectural elevations?
                                          Many thanks
                                            It should work πŸ˜• , but NOT with geolocation set, AND also you'll now need a separate SKP set up for each elevation - in earlier SketchUps you could have different locations in different Scenes...
                                            This tool has to set the location, time etc for each elevation in turn to achieve a proper 45 degree shadow []which obviously can't be done in a fixed geolocation - so it's not possible with just one fixed [geo]location...
                                            • 1 / 3
