    πŸ«› Lightbeans Update | Metallic and Roughness auto-applied in SketchUp 2025+ Download
    Why does my view shift in a saved scene?
    8 Posts 4 Posters 214 Views 4 Watching
      redfish-la
      I am using SU 7. When I save a scene for some reason it will shift in or out from time to time. This is frustrating because I rely on the scene being consistent for overlaying images I export.
      What causes this?
      • daleD Offline
        dale
        Yes I have noticed this as well.
          Does saving it to Scene Tab help keep consistency ?
          So for example if the view zooms slightly does clicking on the Scene Tab restore it to where it should be ?
          Are you using a mouse or a tablet ?
          Are you doing anything in particular when the view changes 'on its own' ?
            redfish-la
            I may be doing something unknowingly. I am defining a scene tab and then using it for an extended period of time switching back and forth to diffent tabs. Then at some point I will go back to the saved tab and the saved setting has changed slightly. It zooms in or out just very slightly.
            I am using a mouse.
              Do you resize the SUp window ?
              Safest to use it full-size ??
                redfish-la
                Thank you TIG! It was as simple as that. A tool bar moved and it resized the SU viewing area. Not realizing this, I kept doing to myself! I appreciate the help! 😍
                  The simplest solutions are often the hardest to find ! πŸ€“
                    Even changing the Toolbar icon size will affect the viewport.
                    I always ensure that I only have one row of small icons in my view - I'm kind of stuck with it due to the number of projects set up to match SU output and render output.
