    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 1.8m Views 329 Watching
    • Chris FullmerC Offline
      Well it sounds like you've got the basic idea. Probably the best thing to do at this point is to upload a small model that shows what you're trying to do and I'll take a look at it to see what might need to change.
        August
        @driven said:
        draw your line the same length as your arc line
        Not necessary, but you do need to allow in your planning for the fact that your guide line will be stretched or shrunk to match the target line, and your shape along with it.
        move your group so the line is centroid to it, edit group with move/copy and scale to match line length, remove at least one end, exposing the line
        Not necessary, and may not be what you want. If the guide line is centered, some parts of the shape will be compressed and some stretched, depending on what side of the guide line they start out on, but the guide line can be some distance from the shape. You just have to visualize the results properly so that you are not surprised.
        rotate your arc line (or copies) until it lies on the red plane and has both ends are parallel to the blue plane
        Neither part is necessary.
        See the attached image for a Target line that is in the Blue-Green plane with a guide line that is parallel to the Red axis, perpendicular to the plane of the Target line.
        off plane and off parallel will give less accurate 'real material' bends, ...
        I agree that to simulate bending of a solid material you may want to follow the rules you outlined like having the Guide Line and Target Line the same length and for the Guide Line to be centroid to the shape.
        But for a wide variety of problems that Shape Bender solves, and for an even wider variety of ways to play with it, it has nothing to do with trying to simulate bending a solid material.
        I hope this helps,
        August
        The Axes are marked since SU does not export them.
        β€œAn idea, like a ghost, must be spoken to a little before it will explain itself.”
        [floatr:v1mcbde2]-- Charles Dickens[/floatr:v1mcbde2]
          MarkEMark
          Hi All:
          I am trying to use Shape Bender to bend 2 flanges on a metal bracket that joins an engine mount to a wooden fuselage of an airplane.
          I have drawn the bracket as shown on the plans (attached). The bracket has 2 'ears' on the top and bottom of the bracket that are bent 90 degrees to wrap around the front end of the fuselage. I want to just bend the 'ear' parts, and not the larger rounded portion of the bracket which is the attachment point for the engine mount. I have removed the holes on the side portion of the bracket that will be used for the attachment to the wooden fuse sides, as I wish to place them after bending.
          My concern is that in the bending process with this plug in is that the entire front of the bracket gets bent 90 degrees and not simply the 'ear' portions. Can someone show me how this might work, or is there another script that would do this better?
          Thanks so much for the help!
          Mark
          My Pietenpol Build.skp
              MarkEMark
              Thanks TIG... I'll try that. I thought it might exceed the plug in's capability... Thanks again for the pic/explaination.
              Mark
                MarkEMark
                OK... this is embarrassing: I've forgotten how to cut the tabs off... Which command will sever them at the cut line..?
                  maxandvv
                  cool! I like it!!
                    albayzem
                    @ben ritter said:
                    Chris, I can hardly keep up with your wonderful scripts. Most importantly though, you are very much appreciated for your kindness to the SU community.
                      I thought I posted a reply to this... πŸ˜•
                      Read the notes in the image..................
                      Make sure that you draw lines all round the tabs so they select separately.
                      Then select all of the tab's geometry and group it, then rotate the group etc etc...
                        madorney
                        Hi - Can anyone help a poor soul find out how / where to download Shape Bender for Mac? Thanks!!!!
                          MarkEMark
                          Hey TIG:
                          Thanks again. You did send me a PM on this. I posted this question about how to cut the tabs off before I PMed you. I posted the question a couple of days before I sent you the PM. I apologize if it appeared that I was badgering ya!
                          The PM detailed how to do this perfectly. Thanks again!
                          Mark
                            Hi Mark, the download is in the very first message in this thread. so go back to page 1 and scroll down to the bottom of my first post. You will also need to install progressbar.rb from smustard. There is a link to that in my first post also. Good luck!
                              madorney
                              Hi Chris - I've managed to install the Shape Bender Plug-in, but it doesn't seem to work at all on my Mac. The tool clearly shows up under my Plugins menu, and I'm able to place the tool icon in my toolbar. But as I follow your video-tutorial to a tee, it's not working: I'm able to select the component, then the Shape Bender tool. But then I'm unable to select anything at all (nothing highlights). Help?
                              Thanks so much!
                                It sounds like maybe your straight line is not placed ont he red axis. And if your axis has been altered from its original orientation, then that will mess things up. So try resetting the global axis, then align the straight line to the red axis. See if that works. If not, could you upload a small test model?
                                  truffel50
                                  Wonderfull plugin! Very Thanx
                                  truffel, Netherlands
                                    berniedog
                                    Chris,
                                    This looks exciting. I guess I'm a noob,
                                    but I do not know where to download
                                    the shape bender plugin????
                                    Thank you so much!
                                    bob
                                      Chris,
                                      Thank you so much!
                                      bob
                                      At the end of the first post in this thread.
                                        berniedog
                                        Thanks Thomas for the quick reply!
                                        Found the link, I originally thought
                                        it was the french version- Cheers- bob
                                          christos88
                                          Just downloaded the Plugin, but when I tried it out it didnt work: When i selected the component I couldnt do anything else (says to highlight a line along the red axis, but still nothing happens).
                                          I've also tried using models users posted here, but still no go...
                                          Any ideas? I just have to shape a facade for a project, so if worse comes to worse could i perhaps post the model here and anybody shape it for me? (i've got the curve etc)
                                            Dummhamer
                                            Thank's for this super-mega plugin!
                                            • 60
                                            • 61
                                            • 62
                                            • 63
                                            • 64
                                            • 62 / 64
