    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.5m Views 329 Watching
      driven
      @chris fullmer said:
      '' So if his [Didier's] plugin is loaded, progressbar does not behave the way Todd wrote it, it behaves the way Didier [accidentally] changed it. ...
      @august said:
              ''The most likely cause of the problem is a variable name conflict.    August
      Cat among the pidgins here,
      as you may be aware, I've had problems with ShapeBender and VWS clashing on the Mac, so (considering this CompoSpray discussion) I ran both through my editor looking for the words 'ProgressBar' and it was indeed in 7 of the VWS rubies, and as it does not require"ProgressBar.rb" I renamed all to vwsProgressBar and the problems have disappeared...
      I then got to thinking that I have CompoSpray installed through SCFPowerToolbar but haven't had any problems from it, so I did a test, and it 'CS' wasn't working??? I don't actually have it as a separate ruby and it's encoded and called "cd_power_m.rb" which fails to load due to a line code error on the Mac, so can't hurt anything....
      to make long story, longer. I removed all references to "cd_power_m.rb" from SCFPB and download CompoSpray and installed it, and now all of them work together properly...
      maybe others have two copies of CompoSpray, the SCFTB one of which has a code error??
      hope that helps someone....
      NB. pidgin |ˈpijən| noun [often as adj. ]
      a grammatically simplified form of a language, used for communication between people not sharing a common language.
      • Chris FullmerC
        Hehe, man that sounds confusing. But it is probably accurate soemhow. Todd had looked over Didier's code and found the error. Didied fixed it at some point. But I think that he might have released a new version since then and possibly reverted back to a tainted file. That is my best guess. So since that toolbar you have installs its own version of CompSpray it probably grabbed a version before Didier added his neat timer interrupt (which is the thing that breaks progressbar in his script).
          jamma-pcb
          And could anyone provide a step by step instructions to this plugin.
          So far
          I have a group which has a straight circlular springy tube. I have a seperate line path of multiple bends for piping.
          For some reason It just wont work.
          Oh by the way if you change the AXIS make sure you reset it before using this plugin. Otherwise all you will get is "please select line on red axis"
          Version SU 7.1
          Anyone got any ideas
          • C
            Click Draw
            Hi there,
            Right in Chris's first post of this script there is a video.
            Cheers,
            Jeff
            Have I mentioned how much of a laugh I get out of some of the Signatures on here!
              jamma-pcb
              For some reason it doesnt work... Maybe something is wrong with the shape.
                jamma-pcb
                ok its all working now. Thanks
                  driven
                  some pointers,
                  draw your line the same length as your arc line
                  move your group so the line is centroid to it, edit group with move/copy and scale to match line length, remove at least one end, exposing the line
                  rotate your arc line (or copies) until it lies on the red plane and has both ends are parallel to the blue plane
                  off plane and off parallel will give less accurate 'real material' bends, but you may want that, so play around with copies of the arc line
                  First line centroid to tube...play around with line lengths, positions and arc segment counts as well
                    sbolduc
                    Hey,
                    I'm having some trouble with the selection of the line lying on the red axis, following the selection of the grouped shape to be bent. Any suggestions?
                    • Chris FullmerC
                      Well it sounds like you've got the basic idea. Probably the best thing to do at this point is to upload a small model that shows what you're trying to do and I'll take a look at it to see what might need to change.
                        August
                        Not necessary, but you do need to allow in your planning for the fact that your guide line will be stretched or shrunk to match the target line, and your shape along with it.
                        Not necessary, and may not be what you want. If the guide line is centered, some parts of the shape will be compressed and some stretched, depending on what side of the guide line they start out on, but the guide line can be some distance from the shape. You just have to visualize the results properly so that you are not surprised.
                        Neither part is necessary.
                        See the attached image for a Target line that is in the Blue-Green plane with a guide line that is parallel to the Red axis, perpendicular to the plane of the Target line.
                        off plane and off parallel will give less accurate 'real material' bends, ...
                        I agree that to simulate bending of a solid material you may want to follow the rules you outlined like having the Guide Line and Target Line the same length and for the Guide Line to be centroid to the shape.
                        But for a wide variety of problems that Shape Bender solves, and for an even wider variety of ways to play with it, it has nothing to do with trying to simulate bending a solid material.
                        I hope this helps,
                        August
                        The Axes are marked since SU does not export them.
                        “An idea, like a ghost, must be spoken to a little before it will explain itself.”
                        [floatr:v1mcbde2]-- Charles Dickens[/floatr:v1mcbde2]
                          MarkEMark
                          Hi All:
                          I am trying to use Shape Bender to bend 2 flanges on a metal bracket that joins an engine mount to a wooden fuselage of an airplane.
                          I have drawn the bracket as shown on the plans (attached). The bracket has 2 'ears' on the top and bottom of the bracket that are bent 90 degrees to wrap around the front end of the fuselage. I want to just bend the 'ear' parts, and not the larger rounded portion of the bracket which is the attachment point for the engine mount. I have removed the holes on the side portion of the bracket that will be used for the attachment to the wooden fuse sides, as I wish to place them after bending.
                          My concern is that in the bending process with this plug in is that the entire front of the bracket gets bent 90 degrees and not simply the 'ear' portions. Can someone show me how this might work, or is there another script that would do this better?
                          Thanks so much for the help!
                          Mark
                          My Pietenpol Build.skp
                              MarkEMark
                              Thanks TIG... I'll try that. I thought it might exceed the plug in's capability... Thanks again for the pic/explaination.
                              Mark
                                MarkEMark
                                OK... this is embarrassing: I've forgotten how to cut the tabs off... Which command will sever them at the cut line..?
                                  maxandvv
                                  cool! I like it!!
                                    albayzem
                                    @ben ritter said:
                                    Chris, I can hardly keep up with your wonderful scripts. Most importantly though, you are very much appreciated for your kindness to the SU community.
                                      I thought I posted a reply to this... 😕
                                      Read the notes in the image..................
                                      Make sure that you draw lines all round the tabs so they select separately.
                                      Then select all of the tab's geometry and group it, then rotate the group etc etc...
                                        madorney
                                        Hi - Can anyone help a poor soul find out how / where to download Shape Bender for Mac? Thanks!!!!
                                          MarkEMark
                                          Hey TIG:
                                          Thanks again. You did send me a PM on this. I posted this question about how to cut the tabs off before I PMed you. I posted the question a couple of days before I sent you the PM. I apologize if it appeared that I was badgering ya!
                                          The PM detailed how to do this perfectly. Thanks again!
                                          Mark
                                          • Chris FullmerC
                                            Hi Mark, the download is in the very first message in this thread. so go back to page 1 and scroll down to the bottom of my first post. You will also need to install progressbar.rb from smustard. There is a link to that in my first post also. Good luck!
