    Help Me Draw A Dome [TUTORIAL]
    322 Posts 10 Posters 85.0k Views 10 Watching
      On the topic of Volume...
      There are two volume tools - v1.8 is a slow but reliable method, using 'integration' of slices - this has 'accuracy' settings; and v2 which uses a whizzy topographical method that's quick but requires a 'perfect' set of 'manifold' faces enclosing the volumes...
      You are trying the 'sensitive' one !
      Your shapes must have internal 'partitions' which it won't like...
      Make a copy of what you need to get the volume from, off to one side.
      Explode the parts and re-group them into one thing, to get its volume...
      Try using Xray mode, section-cuts etc to find, access and remove internal 'partitions'.
      Also ensure there are no 'holes in the faces as the volume will 'leak out' [just like water would] and fail...
      If you can publish your skp I'll look at it...
        I need the SKP not a PDF ?
        πŸ˜’
        • GaieusG
          @d0me said:
          Hi Gaieus
          Ok lets break my request down.
          Can we firstly slice my entrance in equal halves where the seams of the 2 dome slice and entrance meet?
          Then, if we look at the dome from the front view, I need the 1 slice of the entrance and the 1 back slice of the behind that same entrance printed with their hidden geometry on.
          I have attached a Jpeg of the 2 slices I require including the entrance. Once the entrance is split, it will make a little more sense.
          Sorry dome I still do not get it. Are you talking about section cuts? Why don't you place one (just roughly) and orient your model in a view I can understand and can do the printout?
            D0me
            Hi Gaieus
            Then, if we look at the dome from the front view, I need the 1 slice of the entrance and 1 back slice of behind that same entrance printed with their hidden geometry on.
            TIG, I have attached my latest version of the model which Gaieus has helped me build.
            Thanks guys
            Regards
            D0me
            Dome V2 Final redone.pdf
              D0me
              Hi Guys
              TIG: Sorry about that. I got so many files for this model that i get confused.
              SKP is now attached.
              Gaieus: It's not the Section Cut, its the dome model itself. I have printed what I require to PDF. Currently its on a 1:5 scale. I require it to be on a 1:1 scale.
              Regards
              D0me
              Dome V2 Final redone.skp
              Dome + Hidden Geometry.pdf
              • GaieusG
                And in this perspective format or orthogonal? (Perspective cannot be printed to scale). Also, no grey dome then? (Above you said brown and grey). And in colour or B&W?
                  D0me
                  Hi Gaieus
                  Orthogonal is fine. The Grey dome will need to be printed on a separate page. Black and White is perfect.
                  Edit: Sorry Gaieus, can I ask for 1 more favor? Can you give me 3 views of each of the domes. I need the Right , Back and Top view if possible.
                  Regards
                  D0me
                    Here's a SKP with the Volumes done by Integration.
                    I separated the colored parts. I thought you might want them like that ?
                    There's also a total...
                    I had to combine the pieces and then remove some internal partitions etc...Dome V2 Final redone [Volume].pngDome V2 Final redone [Volume].skp
                    • chrisglasierC
                      chrisglasier
                      So TIG it seems you made Stinkie's head gear as well ...
                      • GaieusG
                        Okay, here is one of the Brown dome on 3 pages. It actually fit on an A1 paper but the bigger ones will not fit for sure. Shall I rather export this on an A3 instead?
                        Dome_HiddenGeometry3View.pdf
                          D0me
                          Hi Gaieus
                          Thanks for printing me the Requested views. Sorry, forgot to tell to turn off the Grids. Please can you reprint it and you mentioned that you can print it to A3. That should be fine as long as it fits 1:1 scale on this page size.
                          I'm sorry to trouble you again but I need some other prints as well as some adjustments to the model if possible.
                          Print outs are as follows.
                          1. As mentioned above, the brown dome you just printed but with the Grids Turned off.
                          2. The Grey dome to be printed the same as the brown dome.
                          3. The entrance of the dome (front view) in the same manner that the domes in (1) and (2) have been printed. Difference here is there is only one view unlike the domes which have 3 views.
                          4. Lastly, this next request refers to the section cut. Is it possible to print out on separate pages, each dome separately on a 1:1 scale. I have attached an image of what I mean.
                          Below is the Brown Dome Only
                          Below is the gray Dome only.
                          With regards to the adjustments, if its too complicated and may affect the dimensions by large amounts, then we can skip it and I will work around it.
                          I have attached an image of what adjustments I would like to make.
                          Regards
                          D0me
                          • GaieusG
                            No, sorry, I really meant A0 no A3. That's a typo. So this smallest dome can fit on an A1 but the rest won't. So the question is - shall I print this one on an A1 and the others on A0'a or should all be the same (A0) instead?
                              D0me
                              Hi Gaieus
                              All can be on A0.
                              Regards
                              D0me
                              • GaieusG
                                OK, I will do then.
                                πŸ˜‰
                                  D0me
                                  Hi Gaieus
                                  How are you?
                                  Just thought I'd pop in and see how those print outs are coming along.
                                  Regards
                                  D0me
                                  • GaieusG
                                    Hi d0ome,
                                    Sorry but indeed I totally abandoned you. 😳
                                    I promise I will do those exports but I had a whole sh***tload of things to deal with during the week-end (and still have things to do).
                                      D0me
                                      @gaieus said:
                                      Hi d0ome,
                                      No Problem Gaieus.
                                      Whenever you have the time.
                                      I just realized a huge error of mine. The 48mm radius pipe in the centre of my dome was supposed to be 24mm radius. I should have paid more attention to math class because I just confused radius and diameter.
                                      I tried all morning to resolve it but couldn't entirely. I managed to fill the 48mm bunghole but now I need to fuse it back with my dome pieces and then intersect my 24mm pipe.
                                      The other solution is, as my usual self. I can redo the domes, intersect with 24mm pipe and then copy the entrance from my current model though I don't really know how to put this into practice on SU. Personally, the entrace is most time consuming, so redoing the dome will be easiest.
                                      Well these are the only 2 solutions I can think of but I guess you have something in mind that's less complicated and time consuming.
                                      Look forward to hearing from you
                                      Regards
                                      D0me
                                      • GaieusG
                                        πŸ˜›
                                        Good I didn't start exporting!
                                        Well, if that top is missing, it would be more to fiddle around filling it (and then reopening a smaller) than redoing it IMO. That entrance is not that hard - last time you skipped it anyway so now you can make it.
                                        πŸ˜‰
                                          D0me
                                          Hi Gaieus
                                          I have started redoing my model with the correct pipe size.
                                          I have already completed my domes. Now starting to slice up my melon and then proceed from there.
                                          Yep, I did skip the entrance the last time so this is my chance to it properly.
                                          Thanks and will keep you informed
                                          Regards
                                          D0me
                                            D0me
                                            Hi Gaieus
                                            Hope you are well.
                                            I have completed my model.
                                            It now has bunghole of 48mm Diameter.
                                            Can you export the model for me on a 1:1 scale in the following way?
                                            1. Print the section cut as is with grids turned off
                                            2. Print the entrance from the right camera view as is
                                            Also, can you show me a Step by Step of how to export as I will probably download the pro version of SU tonight and I would love to play around with this cool feature of SU.
                                            Regards
                                            D0me
                                            5 X Domes Final V3.skp
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 15 / 17
