    Help Me Draw A Dome [TUTORIAL]
    322 Posts 10 Posters 102.2k Views 10 Watching
    • GaieusG
      I can export it into pdf with or without a grid of any custom spacing if you wish.
      That is from LayOut. See below - the major grid is 4 cm apart and the minor is 1 cm.
      dome.pdf
        D0me
        Hi Gaieus
        Good News.
        I've found a way to split the A0 1:1 scale print of the model into multiple A4 pages, 12 pages to be exact.
        I've attached the PDF of the 12 pages. Please have a look and see if it look OK.
        In one of your previous posts, you mentioned about DPI. What should the DPI be of this particular PDF?
        Regards
        D0me
        Dome V2 Final A0 into A4.pdf
        • GaieusG
          Well, from a given dpi you cannot make "better" resolution by simply "upping" the number. 200 dpi (that I sent) is way enough I think so if you keep that, you will be fine. 300 dpi is something prints demand for nice, quality colour picture books. But since I exported with vector settings, that must be fine for B&W line output.
          I had a look at the pdf file. I cannot really say much as I should print it out to see how the parts fit and I do not have a printer.
          πŸ˜„
            D0me
            Thanks for the info on DPI.
            I will print the model today and see how I can puzzle it together.
            Wish me luck. Hope all goes well.
            Thanks again for printing it to A0. As I said previously, anything I can get my hands on will really help and that's exactly what happened. It really did help with the A0 print.
            Take Care
            Regards
            D0me
              D0me
              Hi Gaieus
              Hope you are well.
              I have printed my model on A4 and I'm happy to report that I puzzled the A4 pages together and it fitted perfectly. The model dimensions were Spot On.
              2 Questions.
              1. How do I now print the model onto an A0 page myself just the way you have done? I know you did mention something about layout but I didn't quite understand what it is?
              2. Is it possible to print my model with hidden geometry on. I have some ideas in mind and it's got to do with Hidden Geometry being on, in the model and I want to print and see if it makes any sense.
              Regards
              D0me
              • GaieusG
                Well, LayOut is an additional program (for 2D presentation and drafting) that comes with SU Pro. You can also install SU Pro if you want and have 8 full working hours with it and its full, unlimited features. After those 8 hours, it will simply revert to the functions of the free version and you can continue working wits SU as before.
                Or I can export it for you from my LO as before. πŸ˜‰
                And surely it is possible to export with hidden geometry on - however for some reason, when I change the rendering method from raster to either hybrid or vector, hidden geometry is not displayed in LO. I hope that the raster output will be good enough quality for you to print - see attached below.
                Dome_HiddenGeometry.pdf
                • chrisglasierC
                  chrisglasier
                  I hate to say this but if you really want to use a grid, it should overlay the model so that you can see where it intersects the models lines. As I said a grid is unnecessary here but you should bear it in mind for free-form designs when it would be almost essential.
                  Sorry.
                    D0me
                    Hi Gaieus
                    I'm tempted to download SU pro to test these cool features but 8 Hours is a short time so I would have to allocated enough time for me to make full use of the 8 Hours that's allows.
                    Thanks for printing the model for me but is it possible to print it out in the following way.
                    I require both the brown and grey dome only. The printout is not the section cut but the model itself.
                    Both domes are required from a Top and Bottom view of only 2 slices of each dome with the hidden geometry on. The 2 slices are the slice with the entrance and one of the back slices. I have attached an image of the brown dome as an example indicating which portion of the dome I require.
                    Thanks for your help.
                    Much appreciated
                    Regards
                    D0me
                    • GaieusG
                      @chrisglasier said:
                      ...if you really want to use a grid, it should overlay the model so that you can see where it intersects the models lines...
                      Here is a version with the grid lines overlaid.
                      Dome_HiddenGeometryGridOverlay.pdf
                      Hm... I don't really get this I am afraid. What you write is not exactly what's in the pictures.
                      As for the eight hours - they are pure, real working hours so it doesn't mean that if you install the program in the morning and go for a walk, it will expire by the afternoon.
                      • chrisglasierC
                        chrisglasier
                        V quick.
                        Looking at it makes me dizzy!
                          On the topic of Volume...
                          There are two volume tools - v1.8 is a slow but reliable method, using 'integration' of slices - this has 'accuracy' settings; and v2 which uses a whizzy topographical method that's quick but requires a 'perfect' set of 'manifold' faces enclosing the volumes...
                          You are trying the 'sensitive' one !
                          Your shapes must have internal 'partitions' which it won't like...
                          Make a copy of what you need to get the volume from, off to one side.
                          Explode the parts and re-group them into one thing, to get its volume...
                          Try using Xray mode, section-cuts etc to find, access and remove internal 'partitions'.
                          Also ensure there are no 'holes in the faces as the volume will 'leak out' [just like water would] and fail...
                          If you can publish your skp I'll look at it...
                            I need the SKP not a PDF ?
                            πŸ˜’
                            • GaieusG
                              @d0me said:
                              Hi Gaieus
                              Ok lets break my request down.
                              Can we firstly slice my entrance in equal halves where the seams of the 2 dome slice and entrance meet?
                              Then, if we look at the dome from the front view, I need the 1 slice of the entrance and the 1 back slice of the behind that same entrance printed with their hidden geometry on.
                              I have attached a Jpeg of the 2 slices I require including the entrance. Once the entrance is split, it will make a little more sense.
                              Sorry dome I still do not get it. Are you talking about section cuts? Why don't you place one (just roughly) and orient your model in a view I can understand and can do the printout?
                                D0me
                                Hi Gaieus
                                Then, if we look at the dome from the front view, I need the 1 slice of the entrance and 1 back slice of behind that same entrance printed with their hidden geometry on.
                                TIG, I have attached my latest version of the model which Gaieus has helped me build.
                                Thanks guys
                                Regards
                                D0me
                                Dome V2 Final redone.pdf
                                  D0me
                                  Hi Guys
                                  TIG: Sorry about that. I got so many files for this model that i get confused.
                                  SKP is now attached.
                                  Gaieus: It's not the Section Cut, its the dome model itself. I have printed what I require to PDF. Currently its on a 1:5 scale. I require it to be on a 1:1 scale.
                                  Regards
                                  D0me
                                  Dome V2 Final redone.skp
                                  Dome + Hidden Geometry.pdf
                                  • GaieusG
                                    And in this perspective format or orthogonal? (Perspective cannot be printed to scale). Also, no grey dome then? (Above you said brown and grey). And in colour or B&W?
                                      D0me
                                      Hi Gaieus
                                      Orthogonal is fine. The Grey dome will need to be printed on a separate page. Black and White is perfect.
                                      Edit: Sorry Gaieus, can I ask for 1 more favor? Can you give me 3 views of each of the domes. I need the Right , Back and Top view if possible.
                                      Regards
                                      D0me
                                        Here's a SKP with the Volumes done by Integration.
                                        I separated the colored parts. I thought you might want them like that ?
                                        There's also a total...
                                        I had to combine the pieces and then remove some internal partitions etc...Dome V2 Final redone [Volume].pngDome V2 Final redone [Volume].skp
                                        • chrisglasierC
                                          chrisglasier
                                          So TIG it seems you made Stinkie's head gear as well ...
                                          • GaieusG
                                            Okay, here is one of the Brown dome on 3 pages. It actually fit on an A1 paper but the bigger ones will not fit for sure. Shall I rather export this on an A3 instead?
                                            Dome_HiddenGeometry3View.pdf
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 15 / 17
